查看: 1663|回复: 0
[分享] Changing the colour of nested AutoCAD entities through .NET
发表于 2013-5-27 00:10:18 | 显示全部楼层 |阅读模式
Changing the colour of nested AutoCAD entities through .NET                                                        Someone asked me earlier today how to iteratively change the color of entities inside blocks.
The following code uses a recursive helper function to iterate down through the contents of a block, changing the various entities (other than block references, for which we simply recurse) to a specified colour.
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.DatabaseServices;
  3. using Autodesk.AutoCAD.EditorInput;
  4. using Autodesk.AutoCAD.Runtime;
  5. using Autodesk.AutoCAD.Colors;
  6. namespace BlockTest
  7. {
  8.   public class BlockCmds
  9.   {
  10.     [CommandMethod("CC")]
  11.     public void ChangeColor()
  12.     {
  13.       Document doc =
  14.         Application.DocumentManager.MdiActiveDocument;
  15.       Database db = doc.Database;
  16.       Editor ed = doc.Editor;
  17.       PromptIntegerResult pr =
  18.         ed.GetInteger(
  19.           "\nEnter color index to change all entities to: "
  20.         );
  21.       if (pr.Status == PromptStatus.OK)
  22.       {
  23.         short newColorIndex = (short)pr.Value;
  24.         ObjectId msId;
  25.         Transaction tr =
  26.           doc.TransactionManager.StartTransaction();
  27.         using (tr)
  28.         {
  29.           BlockTable bt =
  30.             (BlockTable)tr.GetObject(
  31.               db.BlockTableId,
  32.               OpenMode.ForRead
  33.             );
  34.           msId =
  35.             bt[BlockTableRecord.ModelSpace];
  36.           // Not needed, but quicker than aborting
  37.           tr.Commit();
  38.         }
  39.         int count =
  40.           ChangeNestedEntitiesToColor(msId, newColorIndex);
  41.         ed.Regen();
  42.         ed.WriteMessage(
  43.           "\nChanged {0} entit{1} to color {2}.",
  44.           count,
  45.           count == 1 ? "y" : "ies",
  46.           newColorIndex
  47.         );
  48.       }
  49.     }
  50.     private int ChangeNestedEntitiesToColor(
  51.       ObjectId btrId, short colorIndex)
  52.     {
  53.       int changedCount = 0;
  54.       Document doc =
  55.         Application.DocumentManager.MdiActiveDocument;
  56.       Database db = doc.Database;
  57.       Editor ed = doc.Editor;
  58.       Transaction tr =
  59.         doc.TransactionManager.StartTransaction();
  60.       using (tr)
  61.       {
  62.         BlockTableRecord btr =
  63.           (BlockTableRecord)tr.GetObject(
  64.             btrId,
  65.             OpenMode.ForRead
  66.           );
  67.         foreach (ObjectId entId in btr)
  68.         {
  69.           Entity ent =
  70.             tr.GetObject(entId, OpenMode.ForRead)
  71.             as Entity;
  72.           if (ent != null)
  73.           {
  74.             BlockReference br = ent as BlockReference;
  75.             if (br != null)
  76.             {
  77.               // Recurse for nested blocks
  78.               changedCount +=
  79.                 ChangeNestedEntitiesToColor(
  80.                   br.BlockTableRecord,
  81.                   colorIndex
  82.                 );
  83.             }
  84.             else
  85.             {
  86.               if (ent.ColorIndex != colorIndex)
  87.               {
  88.                 changedCount++;
  89.                 // Entity is only open for read
  90.                 ent.UpgradeOpen();
  91.                 ent.ColorIndex = colorIndex;
  92.                 ent.DowngradeOpen();
  93.               }
  94.             }
  95.           }
  96.         }
  97.         tr.Commit();
  98.       }
  99.       return changedCount;
  100.     }
  101.   }
  102. }
GMT+8, 2026-11-22 08:34 , Processed in 0.434578 second(s), 10 queries , Gzip On, File On.
