查看: 2385|回复: 0
[分享] Return nil to indicate an error condition in a .NET LispFunction
发表于 2013-5-27 23:35:13 | 显示全部楼层 |阅读模式
Return nil to indicate an error condition in a .NET LispFunction                                                        By Wayne Brill
  Issue
  I am implementing functionality in .NET that I am using from AutoLISP. How can I return an error condition from the .NET function?
  Solution
  One suggestion is to return nil from the .NET function using the LispDataType. If the function does return nil you could then handle that appropriately. (Or you could return an integer and respond to that value in the LISP function)
  Here is an excerpt from the AutoCAD .NET Managed Class Reference guide for the LispDataType:
  1. Public Enum LispDataType
  2.   Angle = &H138c
  3.   DottedPair = &H139a
  4.   Double = &H1389
  5.   Int16 = &H138b
  6.   Int32 = &H1392
  7.   ListBegin = &H1398
  8.   ListEnd = &H1399
  9.   Nil = &H139b
  10.   None = &H1388
  11.   ObjectId = &H138e
  12.   Orientation = &H1390
  13.   Point2d = &H138a
  14.   Point3d = &H1391
  15.   SelectionSet = &H138f
  16.   T_atom = &H139d
  17.   Text = &H138d
  18.   Void = &H1396
  19. End Enum
复制代码
Here is a VB example. Notice that if the entity is not selected ok, the routine returns nil.
  1. <LispFunction("getId")>
  2. Public Function test _
  3.   (ByVal myLispArgs As ResultBuffer) As ResultBuffer
  4.     ' This example asks the user to select
  5.     ' an(entity) The object id of the entity is
  6.     ' returned to the calling lisp function
  7.     Dim rbfResult As ResultBuffer
  8.     Dim ed As Autodesk.AutoCAD.EditorInput.Editor
  9.     ed = Autodesk.AutoCAD.ApplicationServices. _
  10.                   Application.DocumentManager. _
  11.                         MdiActiveDocument.Editor
  12.     Dim prmptEntOpts As New PromptEntityOptions _
  13.                                   ("Select Entity")
  14.     Dim prmptEntRes As PromptEntityResult
  15.     ' Get the entity from the users selection
  16.     prmptEntRes = ed.GetEntity(prmptEntOpts)
  17.     ' Make sure the entity was selected ok
  18.     If prmptEntRes.Status <> PromptStatus.OK Then
  19.         rbfResult = New ResultBuffer _
  20.               (New TypedValue(LispDataType.Nil))
  21.         Return rbfResult
  22.     End If
  23.     ' Return the ObjectId to the Lisp function
  24.     Dim objId As ObjectId
  25.     objId = prmptEntRes.ObjectId
  26.     rbfResult = New ResultBuffer _
  27.       (New TypedValue(LispDataType.ObjectId, objId))
  28.     Return rbfResult
  29. End Function
Here is a LISP function that uses the .NET function:
  1. (defun c:testID ( / objId nilTest ent)
  2.     (setq objId (getId))
  3.     (setq nilTest (nth 0 objId))
  4.     (if (= nilTest nil)
  5.         (princ "Entity not selected")
  6.       )
  7.      (if (/= nilTest nil)
  8.      (progn
  9.           (vl-load-com);ensure COM API is available
  10.         (setq ent (vlax-ename->vla-object (nth 0 objId)));the 0 element is an ename
  11.       (vla-highlight ent :vlax-true); highlight the entity using COM call
  12.      );progn
  13.     );if
  14.     (princ)
  15.     )
GMT+8, 2026-11-22 08:13 , Processed in 0.530623 second(s), 10 queries , Gzip On, File On.
