查看: 2022|回复: 0
[分享] Editor.SelectAll with entity and layer selection filter
发表于 2013-5-27 23:57:07 | 显示全部楼层 |阅读模式
Editor.SelectAll with entity and layer selection filter                                                        By Virupaksha Aithal
While using “Editor.SelectAll” API, you can provide “SelectionFilter” to filter out the unwanted entities. Below code shows a simple example which only gets the Lines and circles from a specified layer only (0, Layer1, Layer2).
  1. [CommandMethod("LayerSelection")]
  2. public void LayerSelection()
  3. {
  4.     Document doc = Application.DocumentManager.MdiActiveDocument;
  5.     Database db = doc.Database;
  6.     Editor ed = doc.Editor;
  7.     TypedValue[] filterlist = new TypedValue[2];
  8.     //select circle and line
  9.     filterlist[0] = new TypedValue(0, "CIRCLE,LINE");
  10.     //8 = DxfCode.LayerName
  11.     filterlist[1] = new TypedValue(8, "0,Layer1,Layer2");
  12.     SelectionFilter filter =
  13.                             new SelectionFilter(filterlist);
  14.     PromptSelectionResult selRes = ed.SelectAll(filter);
  15.     if (selRes.Status != PromptStatus.OK)
  16.     {
  17.         ed.WriteMessage(
  18.                     "\nerror in getting the selectAll");
  19.         return;
  20.     }
  21.     ObjectId[] ids = selRes.Value.GetObjectIds();
  22.     ed.WriteMessage("No entity found: "
  23.                            + ids.Length.ToString() + "\n");
  24. }
GMT+8, 2026-11-22 08:35 , Processed in 0.392494 second(s), 10 queries , Gzip On, File On.
