查看: 3230|回复: 1
[分享] Block reference selection using selection filter
发表于 2013-5-25 02:58:49 | 显示全部楼层 |阅读模式
Block reference selection using selection filterBy Virupaksha Aithal
This example will prompt the user to select some entities and then filter all the block references named "ABC". It then iterates through the selection set and calls erase() method on each blockReference
  1. [CommandMethod("delABC")]
  2. public void delABC()
  3. {
  4.     Document doc = Application.DocumentManager.MdiActiveDocument;
  5.     Database db = doc.Database;
  6.     Editor ed = doc.Editor;
  7.     try
  8.     {
  9.         using (Transaction tr =
  10.             db.TransactionManager.StartTransaction())
  11.         {
  12.             BlockTable BT =
  13.                 (BlockTable)tr.GetObject(db.BlockTableId,
  14.                                         OpenMode.ForRead);
  15.             TypedValue[] filterlist = new TypedValue[2];
  16.             filterlist[0] = new TypedValue(0, "INSERT");
  17.             filterlist[1] = new TypedValue(2, "ABC");
  18.             SelectionFilter filter =
  19.                         new SelectionFilter(filterlist);
  20.             PromptSelectionOptions opts =
  21.                             new PromptSelectionOptions();
  22.             opts.MessageForAdding = "Select entities: ";
  23.             PromptSelectionResult selRes =
  24.                             ed.GetSelection(opts, filter);
  25.             if (selRes.Status != PromptStatus.OK)
  26.             {
  27.                 ed.WriteMessage(
  28.                     "\nNo ABC block references selected");
  29.                 return;
  30.             }
  31.             if (selRes.Value.Count != 0)
  32.             {
  33.                 SelectionSet set = selRes.Value;
  34.                 foreach (ObjectId id in set.GetObjectIds())
  35.                 {
  36.                        BlockReference oEnt =
  37.                                 (BlockReference)tr.GetObject(id,
  38.                                                 OpenMode.ForWrite);
  39.                         oEnt.Erase();
  40.                 }
  41.             }
  42.             tr.Commit();
  43.         }
  44.     }
  45.     catch (System.Exception ex)
  46.     {
  47.         ed.WriteMessage(ex.ToString());
  48.     }
  49. }
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 很给力!资料分享奖!
查看全部评分
发表于 2013-5-25 14:37:31 | 显示全部楼层
典型的选择集过滤用法, 谢谢分享
GMT+8, 2026-11-22 08:09 , Processed in 0.405773 second(s), 12 queries , Gzip On, File On.
