查看: 2181|回复: 1
[每日一码] Extracting attribute tag strings from a block insert using ObjectARX
发表于 2014-12-14 17:28:55 | 显示全部楼层 |阅读模式
Question
How to extract attribute tag strings from a block insert using ObjectARX ?
Answer
Open the block reference object and then create a recursive or looping function
to traverse through all of the attributes tags in a block insertion. See the
following code example.
Array,本帖隐藏的内容需要发帖数高于 30 才可浏览,你当前发帖数为
NOTE: This sample code does not extract the constant attribute's value. The same
can be accessed from the attribute definition.
已领礼包: 38个
发表于 2015-5-10 15:15:18 | 显示全部楼层
本帖隐藏的内容需要发帖数高于 30 才可浏览,你当前发帖数为 11!!!!12?
GMT+8, 2026-11-2 22:52 , Processed in 0.654525 second(s), 34 queries , Gzip On.
