查看: 2148|回复: 0
[分享] Changing block definition of an Block reference
发表于 2013-5-25 02:45:47 | 显示全部楼层 |阅读模式
  1. [CommandMethod("chageBlock")]
  2. public static void chageBlock()
  3. {
  4.     Document doc = Application.DocumentManager.MdiActiveDocument;
  5.     Database db = doc.Database;
  6.     Editor ed = doc.Editor;
  7.     PromptEntityOptions options =
  8.         new PromptEntityOptions("\nSelect block reference");
  9.     options.SetRejectMessage("\nSelect only block reference");
  10.     options.AddAllowedClass(typeof(BlockReference), false);
  11.     PromptEntityResult acSSPrompt = ed.GetEntity(options);
  12.     if (acSSPrompt.Status != PromptStatus.OK)
  13.         return;
  14.     using (Transaction Tx = db.TransactionManager.StartTransaction())
  15.     {
  16.         //get the reference
  17.         BlockReference blockRef = Tx.GetObject(acSSPrompt.ObjectId,
  18.                                OpenMode.ForRead) as BlockReference;
  19.         //block table record...
  20.         BlockTable blockTable = Tx.GetObject(db.BlockTableId,
  21.                                     OpenMode.ForRead) as BlockTable;
  22.         //set the test as new block if present
  23.         if (blockTable.Has("TEST"))
  24.         {
  25.             blockRef.UpgradeOpen();
  26.             //set the id of the test block
  27.             blockRef.BlockTableRecord = blockTable["TEST"];
  28.         }
  29.         Tx.Commit();
  30.     }
  31. }
Changing block definition of an Block reference By Virupaksha Aithal
Below code shows the procedure to modify the block definition for block reference. Code, prompts the user to select a block reference and changes its definition so that block reference becomes reference for new block definition,
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 很给力!资料分享奖!
查看全部评分
GMT+8, 2026-11-22 08:09 , Processed in 0.241402 second(s), 10 queries , Gzip On, File On.
