查看: 1788|回复: 0
[分享] 用 AutoCAD.NET 设置 pick first 选择集
已领礼包: 593个
发表于 2013-5-28 00:01:37 | 显示全部楼层 |阅读模式
Setting pick first selection set from using AutoCAD.NET                                                        By Virupaksha Aithal
You can use “Editor. SetImpliedSelection” API to set the pick first (selection with grips) selection set. The code below is a code for sample command, which prompts for entity selection and places it to pick first selection set. Please note it's necessary to specify command flags for commands, which access pick first selection set.
  1. [CommandMethod("SelectTest", CommandFlags.UsePickSet |
  2.                         CommandFlags.Redraw | CommandFlags.Modal)]
  3. static public void SelectTest()
  4. {
  5.     Document doc = Application.DocumentManager.MdiActiveDocument;
  6.     Editor ed = doc.Editor;
  7.     try
  8.     {
  9.         PromptSelectionResult result = ed.GetSelection();
  10.         if (result.Status != PromptStatus.OK)
  11.             return;
  12.         ed.SetImpliedSelection(result.Value.GetObjectIds());
  13.     }
  14.     catch(System.Exception ex)
  15.     {
  16.         ed.WriteMessage(ex.Message);
  17.     }
  18. }
GMT+8, 2026-11-3 02:12 , Processed in 0.426332 second(s), 32 queries , Gzip On.
