查看: 2635|回复: 0
[分享] 通过.Net修改AutoCAD support 路径
发表于 2013-5-28 12:06:31 | 显示全部楼层 |阅读模式
Modifying AutoCAD support Path through .NETBy Virupaksha Aithal
You can use AutoCAD ActiveX API to manipulate the AutoCAD support path. Refer below code. As usual below code uses late binding technique while accessing ActiveX API.
  1. [CommandMethod("AddSupportPath")]
  2. static public void AddSupportPath()
  3. {
  4.     object acadObject = Application.AcadApplication;
  5.     object preferences =
  6.             acadObject.GetType().InvokeMember("Preferences",
  7.             BindingFlags.GetProperty,
  8.             null, acadObject, null);
  9.     //get the files
  10.     object files =
  11.             preferences.GetType().InvokeMember("Files",
  12.             BindingFlags.GetProperty,
  13.             null, preferences, null);
  14.     //get the support path SupportPath
  15.     string supportPath =
  16.             (string)files.GetType().InvokeMember("SupportPath",
  17.             BindingFlags.GetProperty,
  18.             null, files, null);
  19.     Document doc = Application.DocumentManager.MdiActiveDocument;
  20.     Editor ed = doc.Editor;
  21.     if (!supportPath.Contains("C:\\BatchPublish"))
  22.     {
  23.         supportPath = supportPath + ";" + "C:\\BatchPublish";
  24.         object[] dataArry = new object[1];
  25.         dataArry[0] = supportPath;
  26.         files.GetType().InvokeMember("SupportPath",
  27.                          BindingFlags.SetProperty,
  28.                          null, files, dataArry);
  29.         ed.WriteMessage(supportPath + "\n");
  30.     }
  31.     else
  32.     {
  33.         ed.WriteMessage("Support path already present\n");
  34.     }
  35. }
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 资料分享奖!
查看全部评分
GMT+8, 2026-11-22 08:35 , Processed in 0.416490 second(s), 10 queries , Gzip On, File On.
