查看: 2651|回复: 0
[分享] a better random generator
发表于 2013-6-1 23:21:58 | 显示全部楼层 |阅读模式
a better random generator                 //  random.hpp
//  Copyright (C) 2008  Chipset
//  This program is free software: you can redistribute it and/or modify
//  it under the terms of the GNU Affero General Public License as
//  published by the Free Software Foundation, either version 3 of the
//  License, or (at your option) any later version.
//  but WITHOUT ANY WARRANTY; without even the implied warranty of
//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
//  GNU Affero General Public License for more details.
//  You should have received a copy of the GNU Affero General Public License
//  along with this program. If not, see <http://www.gnu.org/licenses/>.
#ifndef RANDOM_HPP_
#define RANDOM_HPP_
#include
<ctime>
class random
public:
explicit random(unsigned long s = 0) : seed(s)
if (0 == seed) seed = std::time(0);
    randomize();
void reset(unsigned long s = 0)
    seed
= s;
    randomize();
  unsigned
long rand()
//returns a random integer in the range [0, -1UL)
    randomize();
return seed;
double real()
//returns a random real number in the range [0.0, 1.0)
    randomize();
return double(seed) / -1UL;
private:
  unsigned
long seed;
void randomize() { seed = 1103515245UL * seed + 12345UL; }
class rand_help
static random r;
public:
  rand_help() {}
void operator()(unsigned long s) { r.reset(s); }
  unsigned
long operator()() const { return r.rand(); }
double operator()(double) { return r.real(); }
random rand_help:: r;
extern
void srandom(unsigned long ns = 0) { rand_help()(ns); } //reset seed
extern unsigned long irand() { return rand_help()(); }         //negative numbers disallowed
extern double drand() { return rand_help()(1.0); }             //for real numbers
#endif  // RANDOM_HPP_
//以上随机数产生器产生的随机数比rand()产生的随机数更加随机(可以用数学方法检验),
//范围更大(一目了然),速度更快(测试一下便知,稍加修改我还可以让它再快一些,如果有必要)。
/*假设随机数均匀分布为理想分布, 粗略估计随机性*/
#include <iostream>
#include <vector>
#include <iomanip>
#include "random.hpp"
int main()
  srand(time(0));
  //SZ分别取值2^3, 2^4, 0.jpg , 2^15进行测试
  const size_t SZ = 1 << 15;
  std::vector<unsigned> v1(SZ), v3(SZ);
  std::vector<unsigned> v2(SZ), v4(SZ);
  for(size_t i = 0; i < SZ; ++i)
    ++v1[rand() % SZ];//对应元素计数 ,理论上v1[0] ~ v1[SZ - 1]之间每个都应该是1
    ++v2[irand() % SZ];
    ++v3[v1]; //统计频度
    ++v4[v2];
  //假设[0, SSZ)之间不存在间断点, (即使有间断点也无所谓,我们只做粗略模糊统计,因为没有必要那么精确)
  //最理想的显示结果应该是0:    0,   1:   SZ,    2:    0,   3:    0,   4:    0,   other:    0
  //0:表示间断,1:表示均匀,2:, 3:, 4:, other: 都表示不同程度的重复
  const size_t SSZ = 5;
  std::cout.fill(' ');
  for(size_t i = 0; i < SSZ; ++i)
    std::cout << i << ": " << std::setw(SSZ) << v3 << ",   ";
  std::cout << "other: " << std::setw(SSZ)
            << v3.size() - v3[0] - v3[1] - v3[2] - v3[3] - v3[4] << '\n';
    std::cout << i << ": " << std::setw(SSZ) << v4 << ",   ";
            << v4.size() - v4[0] - v4[1] - v4[2] - v4[3] - v4[4] << '\n';
  system("pause");
//做速度测试
#include <iostream>
#include
<ctime>
#include
<cstdlib>
#include
<windows.h>
#include
"random.hpp"
int main()
const size_t SZ = 1 << 27;
  std::cout
<< "generating random numbers in progress 1.jpg \n";
  std::cout
<< SZ << " random numbers generated.\n";
  std::cout
<< "random used: ";
  Sleep(
1000);
  std::clock_t time
= clock();
    irand();
  std::cout
<< clock() - time << "ms, ";
  std::cout
<< "rand() used: ";
  Sleep(
1000);
  std::srand(std::time(
0));
  std::clock_t t
= clock();
    std::rand();
  std::cout
<< clock() - t << "ms\n";
  std::system(
"PAUSE");
return 0;
GMT+8, 2026-11-22 07:56 , Processed in 0.162337 second(s), 13 queries , Gzip On, File On.
