查看: 3472|回复: 4
[每日一码] Change Block Base Point
发表于 2013-6-7 15:22:13 | 显示全部楼层 |阅读模式
Program Description
This program allows the user to change the base point for all block references of a block definition in a drawing.
The program offers two commands:
CBP: Change Base Point
This command will retain the insertion point coordinates for all references of the selected block. Hence visually, the block components will be moved around the insertion point when the base point is changed.
CBPR: Change Base Point retain Reference position
This command will retain the position of the each block reference of the selected block. Hence, each block reference will be moved to retain the visual position when the base point is changed.
Upon issuing one of the above commands at the AutoCAD command-line, the program will prompt the user to select a block for which to change the base point.
Following a valid selection, the user is then prompted to specify a new base point relative to the selected block.
The block definition (and block reference depending on the command used) will then be modified to reflect the new block base point.
If the selected block is attributed, an ATTSYNC operation will also be performed to ensure all attributes are in the correct positions relative to the new base point.
Finally, the active viewport is regenerated to reflect the changes throughout all references of the block.
The program will furthermore perform successfully with rotated & scaled block references, constructed in any UCS plane.
Please Note: A REGEN is required if the UNDO command is used to undo the operations performed by this program.
文件名称:ChangeBlockBasePointV1-4.lsp
下载次数:1248  文件大小:11.58 KB
评分
参与人数 1D豆 +5 收起 理由
sicky111 + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2013-6-7 15:43:43 | 显示全部楼层
谢谢提供思路。
发表于 2013-6-7 17:53:25 | 显示全部楼层
太棒了,给力。
发表于 2013-6-7 19:16:23 来自手机 | 显示全部楼层
可以用矩阵,也可以用矢量的概念move
发表于 2022-5-2 08:25:08 | 显示全部楼层
想法不错!
GMT+8, 2026-11-23 22:10 , Processed in 0.244204 second(s), 21 queries , Gzip On, File On.
