查看: 1631|回复: 1
[每日一码] Colour Conversion Functions
已领礼包: 2672个
财富等级: 家财万贯
发表于 2013-6-7 21:20:14 | 显示全部楼层 |阅读模式
Here I present a collection of functions to convert between various colour enumerations, such as RGB Colour, HSL Colour, OLE Colour, True Colour & ACI Colour (AutoCAD Index Colour).
Information about each subfunction and its required arguments is detailed in the function headers. Note that conversion to ACI will yield an approximation to the supplied colour.
RGB & OLE
  1. ;; RGB -> OLE  -  Lee Mac
  2. ;; Args: r,g,b - [int] Red, Green, Blue values
  3. (defun LM:RGB->OLE ( r g b )
  4.     (+  (fix r)
  5.         (lsh (fix g) 08)
  6.         (lsh (fix b) 16)
  7.     )
  8. )
  9. ;; OLE -> RGB  -  Lee Mac
  10. ;; Args: c - [int] OLE Colour
  11. (defun LM:OLE->RGB ( c )
  12.     (list
  13.         (lsh (lsh (fix c) 24) -24)
  14.         (lsh (lsh (fix c) 16) -24)
  15.         (lsh (lsh (fix c) 08) -24)
  16.     )
  17. )
RGB & True
  1. ;; RGB -> True  -  Lee Mac
  3. (defun LM:RGB->True ( r g b )
  4.     (+  (lsh (fix r) 16)
  5.         (lsh (fix g) 08)
  6.         (fix b)
  7.     )
  8. )
  9. ;; True -> RGB  -  Lee Mac
  10. ;; Args: c - [int] True Colour
  11. (defun LM:True->RGB ( c )
  12.     (list
  13.         (lsh (lsh (fix c) 08) -24)
  15.         (lsh (lsh (fix c) 24) -24)
  16.     )
  17. )
RGB & ACI
  1. ;; RGB -> ACI  -  Lee Mac
  3. (defun LM:RGB->ACI ( r g b / o r )
  4.     (if (setq o (vla-getinterfaceobject (LM:acapp) (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2))))
  5.         (progn
  6.             (vl-catch-all-apply
  7.                '(lambda ( )
  8.                     (vla-setrgb o r g b)
  9.                     (setq r (vla-get-colorindex o))
  10.                 )
  11.             )
  12.             (vlax-release-object o)
  13.             r
  14.         )
  15.     )
  16. )
  17. ;; ACI -> RGB  -  Lee Mac
  18. ;; Args: c - [int] ACI (AutoCAD Colour Index) Colour (1<=c<=255)
  19. (defun LM:ACI->RGB ( c / o r )
  20.     (if (setq o (vla-getinterfaceobject (LM:acapp) (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2))))
  21.         (progn
  22.             (vl-catch-all-apply
  23.                '(lambda ( )
  24.                     (vla-put-colorindex (list o c))
  25.                     (setq r (list (vla-get-red o) (vla-get-green o) (vla-get-blue o)))
  26.                 )
  27.             )
  28.             (vlax-release-object o)
  29.             r
  30.         )
  31.     )
  32. )
  33. ;; Application Object  -  Lee Mac
  34. ;; Returns the VLA Application Object
  35. (defun LM:acapp nil
  36.     (eval (list 'defun 'LM:acapp 'nil (vlax-get-acad-object)))
  37.     (LM:acapp)
  38. )
RGB & HSL
  1. ;; RGB -> HSL  -  Lee Mac
  3. (defun LM:RGB->HSL ( r g b / d h l m n s )
  4.     (setq r (/ r 255.0)
  5.           g (/ g 255.0)
  6.           b (/ b 255.0)
  7.           n (min r g b)
  8.           m (max r g b)
  9.     )
  10.     (if (zerop (setq d (- m n)))
  11.         (list 0 0 (fix (+ 0.5 (* m 100))))
  12.         (progn
  13.             (if (< (setq l (/ (+ m n) 2.0)) 0.5)
  14.                 (setq s (/ d (+ m n)))
  15.                 (setq s (/ d (- 2.0 m n)))
  16.             )
  17.             (cond
  18.                 (   (= g m) (setq h (+ (/ (- b r) d) 2)))
  19.                 (   (= b m) (setq h (+ (/ (- r g) d) 4)))
  20.                 (   (setq h (/ (- g b) d)))
  21.             )
  22.             (list
  23.                 (fix (+ 0.5 (rem (+ 360 (* h 60)) 360)))
  24.                 (fix (+ 0.5 (* s 100)))
  25.                 (fix (+ 0.5 (* l 100)))
  26.             )
  27.         )
  28.     )
  29. )
  30. ;; HSL -> RGB  -  Lee Mac
  31. ;; Args: [int] 0<=h<=360, 0<=s<=100, 0<=l<=100
  32. (defun LM:HSL->RGB ( h s l / u v )
  33.     (setq h (/ h 360.0)
  34.           s (/ s 100.0)
  35.           l (/ l 100.0)
  36.     )
  37.     (cond
  38.         (   (zerop s)
  39.             (setq l (fix (+ 0.5 (* 255.0 l))))
  40.             (list l l l)
  41.         )
  42.         (   (zerop l)
  43.            '(0 0 0)
  44.         )
  45.         (   (if (< l 0.5)
  46.                 (setq v (* l (1+ s)))
  47.                 (setq v (- (+ l s) (* l s)))
  48.             )
  49.             (setq u (- (* 2.0 l) v))
  50.             (mapcar
  51.                 (function
  52.                     (lambda ( h )
  53.                         (setq h (rem (1+ h) 1))
  54.                         (cond
  55.                             (   (< (* 6.0 h) 1.0)
  56.                                 (fix (+ 0.5 (* 255.0 (+ u (* 6.0 h (- v u))))))
  57.                             )
  58.                             (   (< (* 2.0 h) 1.0)
  59.                                 (fix (+ 0.5 (* 255.0 v)))
  60.                             )
  61.                             (   (< (* 3.0 h) 2.0)
  62.                                 (fix (+ 0.5 (* 255.0 (+ u (* 6.0 (- (/ 2.0 3.0) h) (- v u))))))
  63.                             )
  64.                             (   (fix (+ 0.5 (* 255.0 u))))
  65.                         )
  66.                     )
  67.                 )
  68.                 (list (+ h (/ 1.0 3.0)) h (- h (/ 1.0 3.0)))
  69.             )
  70.         )
  71.     )
  72. )
OLE & True
  1. ;; OLE -> True  -  Lee Mac
  2. ;; Args: c - [int] OLE Colour
  3. (defun LM:OLE->True ( c )
  4.     (+  (lsh (lsh (lsh (fix c) 24) -24) 16)
  5.         (lsh (lsh (lsh (fix c) 16) -24) 08)
  6.         (lsh (lsh (fix c) 08) -24)
  7.     )
  8. )
  9. ;; True -> OLE  -  Lee Mac
  11. (defun LM:True->OLE ( c )
  12.     (+  (lsh (lsh (fix c) 08) -24)
  13.         (lsh (lsh (lsh (fix c) 16) -24) 08)
  14.         (lsh (lsh (lsh (fix c) 24) -24) 16)
  15.     )
  16. )
OLE & ACI
  1. ;; OLE -> ACI  -  Lee Mac
  3. (defun LM:OLE->ACI ( c )
  4.     (apply 'LM:RGB->ACI (LM:OLE->RGB c))
  5. )
  6. ;; ACI -> OLE  -  Lee Mac
  7. ;; Args: c - [int] ACI (AutoCAD Colour Index) Colour (1<=c<=255)
  8. (defun LM:ACI->OLE ( c )
  9.     (apply 'LM:RGB->OLE (LM:ACI->RGB c))
  10. )
OLE & HSL
  1. ;; OLE -> HSL  -  Lee Mac
  3. (defun LM:OLE->HSL ( c )
  4.     (apply 'LM:RGB->HSL (LM:OLE->RGB c))
  5. )
  6. ;; HSL -> OLE  -  Lee Mac
  7. ;; Args: [int] 0<=h<=360, 0<=s<=100, 0<=l<=100
  8. (defun LM:HSL->OLE ( h s l )
  9.     (apply 'LM:RGB->OLE (LM:HSL->RGB h s l))
  10. )
True & ACI
  1. ;; True -> ACI  -  Lee Mac
  2. ;; Args: c - [int] True Colour
  3. (defun LM:True->ACI ( c / o r )
  4.     (apply 'LM:RGB->ACI (LM:True->RGB c))
  5. )
  6. ;; ACI -> True  -  Lee Mac
  8. (defun LM:ACI->True ( c / o r )
  9.     (apply 'LM:RGB->True (LM:ACI->RGB c))
  10. )
True & HSL
  1. ;; True -> HSL  -  Lee Mac
  3. (defun LM:True->HSL ( c )
  4.     (apply 'LM:RGB->HSL (LM:True->RGB c))
  5. )
  6. ;; HSL -> True  -  Lee Mac
  8. (defun LM:HSL->True ( h s l )
  9.     (apply 'LM:RGB->True (LM:HSL->RGB h s l))
  10. )
ACI & HSL
  1. ;; ACI -> HSL  -  Lee Mac
  2. ;; Args: c - [int] ACI (AutoCAD Colour Index) Colour (1<=c<=255)
  3. (defun LM:ACI->HSL ( c )
  4.     (apply 'LM:RGB->HSL (LM:ACI->RGB c))
  5. )
  6. ;; HSL -> ACI  -  Lee Mac
  8. (defun LM:HSL->ACI ( h s l )
  9.     (apply 'LM:RGB->ACI (LM:HSL->RGB h s l))
  10. )
评分
参与人数 1D豆 +10 收起 理由
XDSoft + 10 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 1632个
财富等级: 堆金积玉
发表于 2013-6-7 21:35:57 | 显示全部楼层
Dear Sir,
  I wonder if this color conversion function can be used in those areas, can explain in detail.
GMT+8, 2026-11-6 21:49 , Processed in 0.431834 second(s), 39 queries , Gzip On.
