查看: 23522|回复: 47
[每日一码] 【源码分享之自由系列2】可代替CTRL+V的“自由粘贴”程序----V1.0
 火 [复制链接]
发表于 2013-6-24 13:51:17 | 显示全部楼层 |阅读模式
   程序实现CTRL+V过程中动态的进行镜像、旋转、放大、缩小、对齐、改基点、改转角及记忆粘贴。
        “自由粘贴”为“自由复制”的姊妹篇
程序现在已基本成型。 先将程序分享出来。希望对你有用(本人使用天正的,哈哈)
希望有兴趣的朋友自己来完善此程序,本人水平精力有限。(如您完善了此程序,记得发表哦 ,以便供我学习)
[sell];;;==================={ 自由粘贴V1.0 BY wowan1314 }================================;;;
;;;功能:实现粘贴的过程中镜像、旋转、放大、缩小、对齐、改基点、改转角、记忆复制。  ;;;
;;;                特别鸣谢: G版 不死猫 xshrimp                                    ;;;
;;;特别说明:左键点取位置,右键退出,F3开关捕捉,F8开关正交,距离可直接输入无需按键    ;;;
;;;          量取Z的意思是:复制距离可由屏幕两点来确认,方便后面空格来默认距离     ;;;
(DEFUN C:YY-CTRLV (/                      PT          SIZE         OLDOS        BB     PT1    NEARPT
             G2            H           D          LST         PTX        PTY    PTT1   PTT2
             PTT3   PTT4   AERROR Aerror_end        olderr PT0    SS0
             APT1   JULI   zhuyi1 zhuyi2 F3        F8     pt0x   pt0y
             STARTPT WS ASC REAL  SS
  (defun Aerror        (x)
    (Aerror_end)
    (vl-cmdf "_.ERASE" SS "")
    (prinC X)
  (defun Aerror_end ()
    (setq *error* olderr)
    (if        oldos
      (setvar "osmode" oldos)
    (if        oldCM
      (setvar "cmdecho" oldCM)
    (command "_.undo" "e")
    (REDRAW)
      (setq olderr  *error*
            *error* Aerror
      (setq oldos (getvar "osmode")
            oldCM (getvar "cmdecho")
      (setq F8 (getvar "ORTHOMODE")
            F3 T ws  (vlax-Create-Object "WScript.Shell")
      (setvar "osmode" 0)
      (setvar "cmdecho" 0)
      (setvar "nomutt" 0)
      (setq zhuyi1 "\n点取位置或\n[转90度(A)/左右翻(D)/上下翻(S)/对齐(F)/改转角(R)/改基点(T)/大1倍(+)/小一倍(-)/量取(Z)/默认<"
            zhuyi2 "mm>(空格)]<退出>"
      (command "_.undo" "be")
      (IF *JULI2*
        (setq juli *JULI2*)
        (setq juli 100)
        (SETQ ENT (ENTLAST) PT0 '(0 0 0))
        (VL-CMDF "_pasteclip" PT0)
      (SETQ SS (last_ent ENT))
      (WHILE pt0
        (if pt1
          (setq        pt   pt1
                pt0  pt1
                PT0X (mapcar '+ pt0 '(1 0 0))
                PT0y (mapcar '+ pt0 '(0 1 0))
          (setq        pt   pt0
         (IF PT1 (command "_.copy" SS "" "0,0" "@"))
        (PRINC (strcat zhuyi1 (rtos juli 2) zhuyi2))
        (while PT
          (setq        BB        (grread T 5 1)
                STARTPT        (CADR BB)
          (cond
            ((= (car BB) 5)
             (SETQ PT1 STARTPT)
             (redRaw)
             (setq size (* (getvar "viewsize") 2))
             (if (AND F3
                      (gxl-Sel-ReDrawSel SS 2)
                      (setq
                        nearpt (osnap PT1 "_ENDP,_MID,_INT,NEA")
                 )                        ; 取得的捕捉点,端点,中点,交点,最近点.
               (PROGN
                 (setq g2 nearpt)
                 (setq h   (/ (getvar "viewsize")
                              (cadr (getvar "screensize"))
                       d   (getvar "pickbox")
                       lst (list (* d h) (* (- d 0.5) h) (* (+ d 0.5) h))
                       ptx (car g2)
                       pty (cadr g2)
                 (foreach x lst
                   (setq ptt1 (list (- ptx x) (- pty x))
                         ptt2 (list (+ ptx x) (- pty x))
                         ptt3 (list (+ ptx x) (+ pty x))
                         ptt4 (list (- ptx x) (+ pty x))
                   (grvecs
                     (list 2 ptt1 ptt2 ptt2 ptt3 ptt3 ptt4 ptt4 ptt1)
                 (setq pt1 g2)
                 (gxl-Sel-ReDrawSel SS 1)
             (IF (AND (= G2 NIL) (= F8 1))
               (PROGN
                 (setq PT1 STARTPT)
                 (IF
                   (OR (< (* pi 0.25) (ANGLE PT1 PT0) (* pi 0.75))
                       (< (* pi 1.25) (ANGLE PT1 PT0) (* pi 1.75))
                    (SETQ PT1
                           (inters pt1
                                   (polar pt1
                                          (+ (angle pt0 pt0Y) (* pi 0.5))
                                          1.0
                                   pt0
                                   pt0Y
                                   nil
                    (SETQ PT1
                           (inters pt1
                                   (polar pt1
                                          (+ (angle pt0 pt0X) (* pi 0.5))
                                          1.0
                                   pt0
                                   pt0X
                                   nil
             (GRVECS
               (LIST
                     1314
                     STARTPT
                     (mapcar '+ (LIST size 0 0) STARTPT)
                     1314
                     STARTPT
                     (mapcar '- STARTPT (LIST size 0 0))
                     1314
                     STARTPT
                     (mapcar '- STARTPT (LIST 0 size 0))
                     1314
                     STARTPT
                     (mapcar '+ (LIST 0 size 0) STARTPT)
             (VL-CMDF "MOVE" SS "" PT PT1)
             (SETQ PT PT1
                   G2 NIL
            ((= (car BB) 3) (SETQ PT NIL))
            ((member (car BB) '(11 25)) (SETQ pt0 NIL) (COMMAND "_.ERASE" SS "") (EXIT))
            ((member BB '((2 97) (2 65)))
             (COMMAND "ROTATE" SS "" PT1 90)
            ((member BB '((2 82) (2 114)))
             (redraw)
             (COMMAND "ROTATE" SS "" PT1 pause)
            ((member BB '((2 70) (2 102)))
             (REDRAW)
             ;;对齐
             (initget 1)
             (IF (SETQ APT1 (getpoint "\n选择第一个源点:"))
               (PROGN
                 (COMMAND "align" SS "" APT1)
                 (princ "\n选择第一个目标点:")
                 (COMMAND pause)
                 (princ "\n选择第二个源点:")
                 (COMMAND pause)
                 (princ "\n选择第二个目标点:")
                 (COMMAND pause)
                 (COMMAND "" "N")
                 (REDRAW)
                 (setvar "osmode" 0)
            ((member BB '((2 115) (2 83)))
             (COMMAND "mirror" SS "" PT1 (mapcar '- pt1 '(1 0)) "Y")
            ((member BB '((2 32)))
             (IF JULI
               (progn (setq pt1 (polar PT0 (ANGLE PT0 PT1) JULI))
                      (COMMAND "MOVE" SS "" PT PT1)
                      (SETQ PT nil)
            ((member BB
                     '((2 46)
                       (2 49)
                       (2 48)
                       (2 50)
                       (2 51)
                       (2 52)
                       (2 53)
                       (2 54)
                       (2 55)
                       (2 56)
                       (2 57)
             (redraw)
             (setq
                   ASC (CADR BB)
             (setq real
                    (getreal
                      (car
                        (list ""
                              (vlax-invoke-method ws 'sendkeys (chr asc))
             (setq pt1 (polar PT0 (ANGLE PT0 PT1) real))
             (COMMAND "MOVE" SS "" pt PT1)
             (SETQ *JULI2* real
                   JULI        *JULI2*
                   PT NIL
            ((member BB '((2 90) (2 122)))
             (redraw)
             (setq
               juli (getdist
                      (strcat "\n输入复制距离<" (rtos juli 2) ">:")
             (SETQ PT nil
                   *JULI2* JULI
            ((member BB '((2 100) (2 68)))
             (COMMAND "mirror" SS "" PT1 (mapcar '- pt1 '(0 1)) "Y")
            ((member BB '((2 43) (2 61)))
             (COMMAND "scale" SS "" PT1 "2")
            ((member BB '((2 116) (2 84)))
             (redRaw)
             (IF (setq pt (getpoint "\n请选择新基点:"))
               (exit)
             (setvar "osmode" 0)
            ((equal BB '(2 45))
             (COMMAND "scale" SS "" PT1 "0.5")
            ((equal BB '(2 6))
             (if (= f3 NIL)
               (progn (setq f3 T) (prompt "\n<对象捕捉 开>"))
               (progn (setq f3 NIL) (prompt "\n<对象捕捉 关>"))
             (redraw)
            ((equal BB '(2 15))
             (if (= f8 0)
               (progn (setq f8 1) (prompt "\n<正交 开>"))
               (progn (setq f8 0) (prompt "\n<正交 关>"))
             (setvar "orthomode" f8)
             (redraw)
        ;;END 内WHILE
      ;;END 外WHILE
  (Aerror_end)
;;gxl-Sel-ReDrawSel 重画选择集中的对象,Sel 为选择集或图元名 mode 为方式码
;;;重画选择集中的对象,mode 为方式码,
;;;方式码 1 在屏幕重画该选择集对象
;;;方式码 2 隐藏该选择集对象
;;;方式码 3 “醒目显示”该选择集对象
;;;方式码 4 取消“醒目显示”该选择集对象--------BY G版
(defun gxl-Sel-ReDrawSel (Sel mode / m n)
  (if sel
    (progn
      (cond ((= 'pickset (type Sel))
             (setq m (sslength Sel)
                   n 0
             (repeat m
               (redraw (ssname Sel n) mode)
               (setq n (1+ n))
            ((= 'ename (type Sel))
             (redraw Sel mode)
  T
;;;======================函数取得EN之后生成的所有图元的选择集
(defun last_ent (en / ss)
   (if en
     (progn
       (setq ss (ssadd))
       (while (setq en (entnext en))
         (if (not (member (cdr (assoc 0 (entget en)))
                          '("ATTRIB" "VERTEX" "SEQEND")
           (ssadd en ss)
         );if
       );while
       (if (zerop (sslength ss)) (setq ss nil))
       ss
     );progn
     (ssget "_x")
   );if
)[/sell]
评分
参与人数 5威望 +1 D豆 +35 贡献 +2 收起 理由
xshrimp + 5 很给力!经验;技术要点;资料分享奖!
liuchong1988 + 10 很给力!经验;技术要点;资料分享奖!
XDSoft + 1 + 10 很给力!经验;技术要点;资料分享奖!
炫翔 + 5 + 1 很给力!经验;技术要点;资料分享奖!
牢固 + 5 + 1 很给力!经验;技术要点;资料分享奖!
查看全部评分
本帖被以下淘专辑推荐:
 楼主| 发表于 2013-6-24 14:02:23 | 显示全部楼层
在制作过程中遇到几个难点,均是从他们的帖子中学到的解决办法。 感谢
已领礼包: 1268个
发表于 2013-6-24 14:11:50 | 显示全部楼层
站个座,支持一下
已领礼包: 2476个
发表于 2013-6-25 10:54:07 | 显示全部楼层
老大,自由复制和自由粘贴的区别在哪??
发表于 2013-6-25 12:40:43 | 显示全部楼层
就是捕捉不是很好用!如果能像CAD本身的捕捉那就非常强大了!天正的捕捉跟CAD的一样!!
已领礼包: 2670个
财富等级: 家财万贯
发表于 2013-6-25 14:09:16 | 显示全部楼层
nice program
发表于 2013-6-26 02:17:15 | 显示全部楼层
很好的程序,非常实用,就是捕捉不给力!
发表于 2013-6-26 03:15:53 | 显示全部楼层
貌似好强大!!!!!!!
发表于 2013-7-4 19:36:35 | 显示全部楼层
顶楼主,不错的工具,确实带来很多方便!
发表于 2013-11-18 13:38:20 | 显示全部楼层
谢谢楼主的程序
已领礼包: 34个
发表于 2013-12-5 12:48:49 | 显示全部楼层
支持下,还是不错的
发表于 2013-12-7 11:43:58 | 显示全部楼层
看看 学习学习下
已领礼包: 41个
发表于 2014-1-17 16:27:44 | 显示全部楼层
老大,自由复制和自由粘贴的区别在哪
发表于 2014-3-14 22:37:03 | 显示全部楼层
试了一下,老是设置我的文字样式!
发表于 2014-3-15 17:23:00 | 显示全部楼层
谢谢分享啊:)
GMT+8, 2026-11-3 04:03 , Processed in 0.614225 second(s), 67 queries , Gzip On.
