查看: 1327|回复: 0
[他山之石] Creating a Layout using Visual LISP in AutoCAD
已领礼包: 1268个
发表于 2013-7-13 17:41:21 | 显示全部楼层 |阅读模式
Creating a Layout using Visual LISP in AutoCADby Fenton Webb
Here’s a nice example that shows how to add a Layout using Visual LISP. It also shows how to set a Plot Style configuration and the Paper Size, and then make the new Layout active…
(defun c:addMyLayout ()
  (vl-load-com)
  (setq acadApp (vlax-get-Acad-object))
  (setq acadDoc (vla-get-ActiveDocument acadApp))
  (setq layouts (vla-get-Layouts acadDoc))
  ;; Delete the layout named "Test" if it exists
  (vlax-for objLayout layouts
    (if (= (vla-get-name objLayout) "Test")
      (progn
        (princ
          (strcat "\nDeleted Layout named "
              (vla-get-name objLayout) "..."
        (vla-delete objLayout) ;delete the Layout
        (vlax-release-object objLayout) ; release the Layout Object
      );progn
    );if
  ) ;vlax-for
  (setq layoutObj (vla-add layouts "Test"))
;; Assign Grayscale.CTB to the Layout
  (vla-put-StyleSheet layoutObj "Grayscale.ctb")
  ;; Assign DWF configuration to the Layout
  (if (= (substr (vlax-variant-value (vla-getvariable acadDoc "ACADVER")) 1 2) "15")
    (vla-put-configname layoutObj "PublishToWeb DWF.pc3")
    (vla-put-configname layoutObj "DWF6 ePlot.pc3")
  ) ;if
;; Assign Paper Size B to the Layout
  (vla-put-canonicalmedianame
    layoutObj
    "ANSI_expand_B_(11.00_x_17.00_Inches)"
  ;; Make the new Layout Active
  (vla-put-activelayout acadDoc layoutObj)
  ;; Example getting StyleSheet and Configname, not doing anything
  ;; with them here however
  (setq currPStyle (vla-Get-StyleSheet layoutObj))
  (setq currConfig (vla-Get-configname layoutObj))
  (princ)
GMT+8, 2026-11-6 20:47 , Processed in 0.365597 second(s), 33 queries , Gzip On.
