查看: 1953|回复: 0
[他山之石] Detecting if cancel was pressed in DCL dialog boxes
发表于 2013-7-13 17:53:00 | 显示全部楼层 |阅读模式
Detecting if cancel was pressed in DCL dialog boxes                         By Gopinath Taget
Its pretty rare to encounter DCL dialogs in AutoCAD now a days but if you do, here is some info that you might find useful.
Lets say you are using command reactors to detect when certain commands are cancelled, yet when the command has a dialog box, there is no difference if a user presses Cancel or OK (only the Editor reactor commandEnded() is called). So, how can you detect the difference between OK and Cancel when selected from a dialog box?
This a known issue with the AutoCAD DCL dialog implementation. A workaround for commands that use the DCL dialog is to read the AutoCAD system variable DIASTAT in the commandEnded() function. DIASTAT is set to 0 if the user has pressed Cancel, and set to 1 if the user presses OK. For AutoCAD MFC based commands, there is no solution at this time.
评分
参与人数 1D豆 +1 收起 理由
/db_自贡黄明儒_ + 1 很给力!经验;技术要点;资料分享奖!
查看全部评分
GMT+8, 2026-11-22 08:06 , Processed in 0.380659 second(s), 11 queries , Gzip On, File On.
