查看: 2079|回复: 0
[他山之石] The STARTUP system variable and the StartUpType environment variable
发表于 2013-7-13 18:06:50 | 显示全部楼层 |阅读模式
The STARTUP system variable and the StartUpType environment variableBy Gopinath Taget
With the value of the STARTUP system variable set to 0, the user is only given the option of using a template.  If it was set to 1, this would enable a user to
1) start a drawing from scratch,
2) use a template, or
3) use a wizard.  You can of course control this programatically.
  1. (defun-q MyStartup ( / app doc)
  2.    (vl-load-com)
  3.    (setq app (vlax-get-acad-object)
  4.            doc (vla-get-activedocument app)
  5.    ) ;setq
  6.    (if (= (substr (vlax-variant-value
  7.    (vla-getvariable doc "ACADVER")) 1 2) "17")
  8.       (vla-setvariable doc "STARTUP"
  9.        (vlax-make-variant 1 vlax-vbInteger))
  10.    )
  11.    (princ)
  12. )
  13. (setq S::STARTUP (append S::STARTUP MYSTARTUP))
You can change the default option for the dialog by setting the StartUpType variable as shown below:
  1. ;To start from Scratch
  2. (setenv "StartUpType" "Scratch")
  3. ;To use a Template
  4. (setenv "StartUpType" "T?emplate")
  5. ;To use a Wizard
  6. (setenv "StartUpType" "Wizard")
复制代码
评分
参与人数 1D豆 +1 收起 理由
/db_自贡黄明儒_ + 1 很给力!经验;技术要点;资料分享奖!
查看全部评分
GMT+8, 2026-11-22 08:11 , Processed in 0.244303 second(s), 12 queries , Gzip On, File On.
