查看: 2229|回复: 0
[分享] 在同一个图形中“克隆" dynamic block
发表于 2013-5-28 11:38:15 | 显示全部楼层 |阅读模式
Clone the dynamic block in the same drawing file.By Virupaksha Aithal
Below code shows the procedure to clone the dynamic block with all its properties to same drawing file.
Steps:
Wblock the present dynamic block to new database using “wblock”.
Use “Insert” API to insert the database (generated in step1) with new block name
  1. [CommandMethod("cloneDynamic")]
  2. static public void cloneDynamic() // This method can have any name
  3. {
  4.     Document doc = Application.DocumentManager.MdiActiveDocument;
  5.     Editor ed = doc.Editor;
  6.     Database db = doc.Database;
  7.     using (Transaction tr =
  8.         db.TransactionManager.StartTransaction())
  9.     {
  10.         BlockTable tb = tr.GetObject(db.BlockTableId,
  11.                         OpenMode.ForRead) as BlockTable;
  12.         BlockTableRecord dynamic = tr.GetObject(tb["DynamicBlock"],
  13.                             OpenMode.ForRead) as BlockTableRecord;
  14.         Database temDB = db.Wblock(dynamic.ObjectId);
  15.         ObjectId copyId = ObjectId.Null;
  16.         using (temDB)
  17.         {
  18.             copyId = db.Insert("DynamicBlockCopy", temDB, true);
  19.         }
  20.         tr.Commit();
  21.     }
  22. }
GMT+8, 2026-11-22 08:17 , Processed in 0.321239 second(s), 11 queries , Gzip On, File On.
