查看: 1759|回复: 1
[他山之石] Creating a gradient hatch using VLisp
发表于 2013-7-20 00:20:19 | 显示全部楼层 |阅读模式
Creating a gradient hatch using VLispBy Balaji Ramamoorthy
Here is a Visual Lisp example that adds a circle to model space and fill it with a gradient hatch.
(defun c:addGHat (/       acadObject  acaddocument
      mspace      mycircle   myloop      myhatch
      col1       col2
    (vl-load-com)
    (setq acver (substr (getvar "acadver")1 2))
    (SetQ acadobject   (VLAX-Get-ACAD-Object)
   acaddocument (VLA-Get-ActiveDocument acadobject)
   mspace      (VLA-Get-ModelSpace acaddocument)
    (SetQ mycircle (VLA-AddCircle
       mspace
       (VLAX-3D-Point '(50.0 50.0 0.0))
       150.0
    (SetQ myloop (VLAX-Make-SafeArray vlax-vbObject '(0 . 0)))
    (VLAX-SafeArray-Put-Element
      myloop
      0
      mycircle
   (SetQ myhatch (VLA-AddHatch
      mspace
      acPreDefinedGradient
      "LINEAR"
      :vlax-true
      acGradientObject
   (setq col1 (vla-GetInterfaceObject
          (vlax-get-acad-object)
          (strcat "AutoCAD.AcCmColor." acver)
   (setq col2 (vla-GetInterfaceObject
   (vla-SetRGB col1 255 0 0)
   (vla-setrgb col2 0 0 255)
   (vla-put-gradientcolor1 myhatch col1)
   (vla-put-gradientcolor2 myhatch col2)
   (VLA-AppendOuterLoop myhatch myloop)
   (VLA-Evaluate myhatch)
Update : Thanks to Oleg for suggesting the use of acadVer instead of using "AutoCAD.AcCmColor.19" to get the color object.
发表于 2013-7-20 06:38:20 | 显示全部楼层
太给力了,好,赞一个
GMT+8, 2026-11-22 08:35 , Processed in 0.309533 second(s), 13 queries , Gzip On, File On.
