查看: 3603|回复: 2
[分享] delete a database link with visual LISP
发表于 2013-6-16 12:45:46 | 显示全部楼层 |阅读模式
Issue
How do I delete a database link from an entity using the CAO API and Visual LISP?
Solution
The following is a short Visual LISP example that prompts the user to select an object. It then deletes any links that are associated with that object.
(defun c:DLink ()
  (vl-load-com)                               ; Get the object and get the object ID
  (setq ent1 (car (entsel "\nSelect entity to erase links")))
  (setq Obj (vlax-ename->vla-object ent1))
  (setq ob_ID (vla-get-objectid Obj))  ; Instantiate the DBConnect object
  (setq dbConnect (vlax-create-object "CAO.DbConnect.16")) ; Get the linkTemplates
  (setq LTs (vlax-invoke-method dbConnect "GetLinkTemplates")) ; Get a linkTemplate named "EmployeeLink1", This
                                       ; linkTemplate
                                       ; can be created from the Employee table in the DB sample that ships with
                                       ; AutoCAD
  (setq LT (vlax-invoke-method LTs "Item" "EmployeeLink1")) ; Get the links using The linkTemplate
  (setq linkSel (vlax-invoke-method dbConnect "GetLinks" LT nil nil nil)) ; Iterate through the links and delete the
                                       ; link
                                       ; if it has the same ObjectID as the link
  (vlax-for thisLink linkSel (setq l_Obj_ID (vlax-get-property thisLink "ObjectID"))
            (if (= l_Obj_ID ob_ID)
              (vla-delete thislink)
GMT+8, 2026-11-22 07:40 , Processed in 0.166152 second(s), 10 queries , Gzip On, File On.
