查看: 3035|回复: 4
[分享] AutoCAD .NET: Define Lisp Functions – Input and Output
发表于 2013-7-25 11:20:30 | 显示全部楼层 |阅读模式
AutoCAD .NET: Define Lisp Functions – Input and OutputAutoCAD .NET API can also define lisp functions. Just like creating commands through specifying the CommandMethod attribute for a method, we can specify the LispFunction attribute for a special kind of methods to define LISP functions.
The method needs to accept a ResultBuffer argument and generally returns a common Object. By the way, the method should be local. It cannot be global or static. It must be public, certainly.
[LispFunction("DoubleMe")]
public Object DoubleMe_LispFunction(ResultBuffer rb)
    Object ret = null;
    if (rb != null)
        TypedValue[] tvArr = rb.AsArray();
        if (tvArr.Count() > 0)
            if (tvArr.Count() == 1)   // a single value
                ret = DoubleValue(tvArr[0]);
            else    // a list
                ret = rb;
    return ret;
Object DoubleValue(TypedValue tv)
    Object ret = null;
    if (tv.TypeCode == (int)LispDataType.T_atom)
        ret = true;
    else if (tv.TypeCode == (int)LispDataType.Int16)
        ret = ((Int16)tv.Value) * 2;
    else if (tv.TypeCode == (int)LispDataType.Int32)
        ret = ((Int32)tv.Value) * 2;
    else if (tv.TypeCode == (int)LispDataType.Double
        || tv.TypeCode == (int)LispDataType.Angle)
        ret = ((double)tv.Value) * 2.0;
    else if (tv.TypeCode == (int)LispDataType.None
        || tv.TypeCode == (int)LispDataType.Nil
        || tv.TypeCode == (int)LispDataType.Void)
        ret = null;
    else if (tv.TypeCode == (int)LispDataType.Text)
        ret = (tv.Value as String) + (tv.Value as String);
    else if (tv.TypeCode == (int)LispDataType.Point2d)
        Point2d p2d = (Point2d)tv.Value * 2.0;
        ret = p2d;
    else if (tv.TypeCode == (int)LispDataType.Point3d)
        Point3d p3d = (Point3d)tv.Value * 2.0;
        ret = p3d;
    else if (tv.TypeCode == (int)LispDataType.ObjectId)
        ret = tv.Value;
    else if (tv.TypeCode == (int)LispDataType.SelectionSet)
        ret = tv.Value;
    else if (tv.TypeCode == (int)LispDataType.ListBegin)
        ret = tv.Value;
        Debug.WriteLine(string.Format("TypeCode: {0}/ListBegin\t\tValue: {1}", tv.TypeCode, tv.Value));
    else if (tv.TypeCode == (int)LispDataType.ListEnd)
        ret = tv.Value;
        Debug.WriteLine(string.Format("TypeCode: {0}/ListEnd\t\tValue: {1}", tv.TypeCode, tv.Value));
    else if (tv.TypeCode == (int)LispDataType.Orientation)
        ret = tv.Value;
        Debug.WriteLine(string.Format("TypeCode: {0}/Orientation\t\tValue: {1}", tv.TypeCode, tv.Value));
    else if (tv.TypeCode == (int)LispDataType.DottedPair)
        ret = tv.Value;
        Debug.WriteLine(string.Format("TypeCode: {0}/DottedPair\t\tValue: {1}", tv.TypeCode, tv.Value));
    else
        ret = tv;
    return ret;
There are totally only around a couple of dozens of lines of code above, but various input types and return types can be exercised by the single same LISP function definition. In fact, the return/output types of the LISP function depend on its input. The function tries to double its input value and return it if possible and convenient.
The following are some example outputs in the AutoCAD command line window when the LISP function is exercised:
Command: (doubleme 1.1 )
2.2
Command: (doubleme 0 )
0
Command: (doubleme 1.5)
3.0
Command: (doubleme 3)
6
Command: (doubleme pi)
6.28319
Command: (doubleme (sin (/ pi 6)))
1.0
Command: (doubleme '( 1 2 3) )
(2.0 4.0 6.0)
Command: (doubleme '( 1 ) )
(1)
Command: (doubleme T )
T
Command: (doubleme nil)
nil
Command: (doubleme )
nil
Command: (doubleme (> 0 1))
nil
Command: (doubleme (> 2 1))
T
Command: (doubleme "ab" "cd" )
("ab" "cd")
Command: (doubleme '(8 . "aabb"))
(8 . "aabb")
Command: (doubleme 1.1 2.2 3.3)
(1.1 2.2 3.3)
Command: (doubleme 1.1 2.2 )
(1.1 2.2)
Command: (setq id (car (entsel)))
Select object: <Entity name: 7ffffb09f10>
Command: (doubleme id)
Command: (setq entlst (entget id))
((-1 . <Entity name: 7ffffb09f10>) (0 . "CIRCLE") (330 . <Entity name:
7ffffb069f0>) (5 . "231") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
"0") (100 . "AcDbCircle") (10 -16.1102 8.8777 0.0) (40 . 9.78317) (210 0.0 0.0
1.0))
Command: (doubleme entlst)
1.0))
Command: (setq pnt (getpoint))
(65.4005 11.0181 0.0)
Command: (doubleme pnt)
(130.801 22.0363 0.0)
Command: (setq angle (getangle))
Specify second point: 0.701371
Command: (doubleme angle)
1.40274
Command: (setq ss (ssget))
11 found
<Selection set: 1e>
Command: (doubleme ss)
<Selection set: 1e>
Command: (doubleme "abcd")
"abcdabcd"
评分
参与人数 1D豆 +5 收起 理由
ScmTools + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2013-7-25 17:08:26 | 显示全部楼层
给NET和LISP间搭桥
这东西有点复杂,lisper给 DLL 就好了  详情 回复 发表于 2013-7-25 17:20
 楼主| 发表于 2013-7-25 17:20:55 | 显示全部楼层
snsj 发表于 2013-7-25 17:08
给NET和LISP间搭桥
这东西有点复杂,lisper给 DLL 就好了{:soso_e100:}
发表于 2013-7-25 19:45:55 | 显示全部楼层
类似依靠一个链表的参数处理
发表于 2013-8-5 10:13:46 | 显示全部楼层
如果楼主能给翻译一下就更好了!这样跟能体现出楼主的创新精神!
GMT+8, 2026-11-22 08:07 , Processed in 0.255828 second(s), 16 queries , Gzip On, File On.
