楼主: wowan1314
[已解决] 哪位大大来解释下这个函数为什么是这样的写法?
发表于 2014-12-7 01:56:35 | 显示全部楼层
有意思,对lisp感兴趣,时间短,对lisp有些概念还不明白
查字典翻译下板凳的意思,不对的请指正
以下是原作者的解释(我蹩脚的翻译)
The use of defun-q will help to explain the difference:
这个函数的使用将帮助解释其不同之处:
Consider the following functions:
看看接下来的功能:
(defun-q f1 nil
    (vla-get-activedocument (vlax-get-acad-object))
(defun-q f2 nil
    (eval (list 'defun-q 'f2 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (f2)
Before function evaluation, the respective function definitions are as follows:
函数求值前,其各自的函数定义如下:
_$ (f1)   (注:应该是!F1吧)
(nil (vla-get-ActiveDocument (vlax-get-acad-object)))
_$ (f2)   (注:应该是!F2吧)
(nil (eval (list (quote defun-q) (quote F2) (quote nil) (vla-get-ActiveDocument (vlax-get-acad-object)))) (F2))
When evaluated, both functions will return the Active Document object:
求值后,二者将返回激活的Document对象
_$ (f1)
#<VLA-OBJECT IAcadDocument 0ceb5b6c>
_$ (f2)
However, observe the respective function definitions following function evaluation:
好啦,仔细观察各自的函数定义接下来的函数值
_$ f1
_$ f2
(nil #<VLA-OBJECT IAcadDocument 0ceb5b6c>)
Note that function f2 now no longer retrieves the Application Object (vlax-get-acad-object)
before retrieving the Active Document Property (vla-get-activedocument),
but simply returns the Active Document object directly.
The method is similar to setting a global variable pointing to the Active Document Object.
注意,那个函数f2在取回激活的Document属性(vla-get-activedocument)之前,
没有取回应用程序对象 (vlax-get-acad-object)的过程,
但却直接简单地返回激活的Document对象。
这种方法是类似于去设置一个全局变量去指向激活的Document对象
Of course, for this program, I could have equivalently used a local variable assigned with the Active Document Object, however, such local variable would then be re-assigned this value for every use of the program.
&#171; Last Edit: June 04, 2013, 07:53:20 am by Lee Mac &#187;
当然,针对这个程序,我本来可以同样使用一个局部变量非配给激活的Document对象,
不管怎样,如此的局域变量然后将会为每个程序的使用重新分配这个值
&#171; 最后编辑: 2013年6月4日 上午07:53:20  作者 Lee Mac &#187;
已领礼包: 195个
发表于 2014-12-7 02:42:05 来自手机 | 显示全部楼层
问题问的好!
已领礼包: 396个
发表于 2015-5-21 19:24:24 | 显示全部楼层
好文章,虽然没看懂,做个标记吧,以后再过来学习!
已领礼包: 602个
发表于 2016-2-19 15:42:23 | 显示全部楼层
学习了,学习楼主!
已领礼包: 2226个
发表于 2016-11-21 22:08:02 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2017-7-20 12:24:40 | 显示全部楼层
谢谢分享
已领礼包: 780个
发表于 2017-7-20 14:07:37 | 显示全部楼层
到底应该怎么理解呢?
已领礼包: 14个
发表于 2017-7-20 17:05:48 | 显示全部楼层
把所有回贴都观摩学习过了,然后开始迷糊
发表于 2018-9-30 14:09:09 | 显示全部楼层
嗨,在我看来,LM大师使用另一种方式来定义acdoc变量功能!
楼上 @wzg356: f1 f2 的分别 , 对应该是 f2
(vla-propagate ‘f2) 变量可以传播至另一dwg文件,
而f1却不能!
我在其它论坛看过使用LM:acdoc的类似帖子在此分享
但没有权限发布链接url
只能复制源码:
(defun err:config ( prog lst )
;hanhphuc
'*error*
'(msg)
prog
(list 'if (list 'and '(eval msg)
(list 'vl-every ''not
(vl-list* 'list '(wcmatch (strcase msg) "*CANCEL*,*EXIT*,*BREAK*")
         lst )
'(princ (strcat "\n; error: " msg))
'(princ)
'*error*
  1. (err:config '(ai_sysvar nil)  nil)
调试:
(vl-propagate '*error*) ;不行
(setq *error* *olderror*)
(err:config);注意:刮号不可忽例!
(vl-propagate '*error*) ;变量也可以传播至另一dwg文件了。
GMT+8, 2026-11-5 13:03 , Processed in 0.440590 second(s), 42 queries , Gzip On.
