查看: 2634|回复: 0
AutoCAD Visual LISP Technical Newsletter - October 1999
发表于 2002-1-7 02:16:03 | 显示全部楼层 |阅读模式
This document is part of    Visual Lisp Newsletter Archive
Dear Visual LISP developer,
/Note: the URLs in this posting may be broken into several lines by the
transmission media. Please make sure that you have the full URL before
trying to access it./
Table of Contents
(1) Exchanging data between Visual LISP and VB(A)
(2) New or Updated Solutions
In AutoCAD r14 the only way to exchange data between VB(A) and Visual LISP
was through the use of the USERS1-5, USERR1-5, and USERI1-5 AutoCAD system
variables. Those variables were limited to 3 very basic types (String, Real,
Interger). A solution for more complex data exchange was to create an
In-Process COM server written in VB, Delphi, or C++, and to load that server
into the AutoCAD address space with the getInterface() method. Then both
Visual LISP, and VB(A) applications could read and save shared data into
that server.
However there were some shortcomings with this approach.
- If you were in VBA you could not access Visual LISP and vice versa.
- VBA and Visual LISP had difficulty in understanding each others
   data types (for example the LISP list data type).
In AutoCAD 2000, Visual LISP is now a real ActiveX client as well as a
capable COM server application. Visual LISP has its own COM interface, and
VB(A) provides access to its environment and code to any COM client
application. Because Visual LISP is now a COM server, it means VB(A) can
read
and set LISP variables in the LISP environment, as well as asking Visual
LISP
to execute or evaluate sone LISP code directely from a VB(A) macro.
This is one method.
The second method is to do the same from the Visual LISP environment.
Calling
a VB(A) macro from LISP. This can be done via the
IAcadApplication::RunMacro()
method.
To enable the use of the Visual LISP server from VB(A), you just need to
make
a reference to the 'Visual LISP ActiveX module' (i.e. VL.TLB file from the
AutoCAD root directory).
There is no documentation on the server API, but the Developer Consulting
Group
have produced some sample solutions and will continue to do so.
Please visit the 'AutoCAD - AutoLISP/DCL', 'AutoCAD - Visual LISP', and
'AutoCAD - VBA/VB/ActiveX' sections at the following URL for related
solutions.
http://adn.autodesk.com/techsupp/apikb/acadgrp.htm
INTERACTING WITH EXCEL CELLS
/cgi-bin/solution.pl?SID=37873
Also the Developer Consulting Group is writting a document on the usage of
the
Visual LISP server, as well as extending LISP capabilities via ARX
programming.
This document (when ready) will be published on the ADN WEB site at the
following URL:
http://adn.autodesk.com/techsupp/utilitiestechpapers.htm
CREATING AND MANIPULATING XRECORDS USING AUTOLISP
/cgi-bin/solution.pl?SID=16132
(COMMAND) FUNCTION DOES NOT WORK WITH NEW AND OPEN
/cgi-bin/solution.pl?SID=29417
HOW TO IDENTIFY UNREFERENCED LAYERS IN LISP?
/cgi-bin/solution.pl?SID=30528
CREATION & MANIPULATION OF GROUPS USING AUTOLISP IN R14
/cgi-bin/solution.pl?SID=44942
USING THE SELECTION SET SELECT METHOD IN VISUAL LISP
/cgi-bin/solution.pl?SID=12298
USING A VB ACTIVEX DLL FROM VISUAL LISP OR VB(A)
/cgi-bin/solution.pl?SID=15992
CONSTUCTING VLISP LWPOLYLINE VIA ACTIVEX
/cgi-bin/solution.pl?SID=16152
EXTENSION DICTIONARY TO ASSOCIATE OBJECTS
/cgi-bin/solution.pl?SID=21716
HOW DO I REPLACE THE PLOTTER AND PLOTID SYSTEM VARIABLES
/cgi-bin/solution.pl?SID=41173
NO FUNCTION DEFINITION - XLOAD
/cgi-bin/solution.pl?SID=42013
EXPLODING EACH ENTITY IN A SELECTION SET
/cgi-bin/solution.pl?SID=44926
DBCONNECT.GETLINKS DOESN'T WORK WITH FOR EACH ITERATION OBJECTS
/cgi-bin/solution.pl?SID=36594
To subscribe or unsubscribe, go to
http://adn.autodesk.com/techsupp/docs/newsletters.htm
     You received this message as a result of your registration
     on the ADN List Server subscription page.  If you no longer wish
     to receive these messages, read the next section, How to use this
     mailing list.
     How to use this mailing list:
     You may unsubscribe from this e-mail newsletter, or subscribe to
     a variety of other informative e-mail newsletters, by returning
     to the ADN List Server subscription page at
     and changing your subscription preferences.
     Alternatively, from the subscribed account you can send an e-mail to
     <Majordomo-partnersys@autodesk.com> with the following command in the
     body of your email message:
     unsubscribe <list-name>
     Autodesk Developer Network (ADN) information and events:
     For information on all ADN topics, please visit:
       http://www.autodesk.com/adn
     THIS DOCUMENT IS PROVIDED FOR INFORMATIONAL PURPOSES ONLY.  The
     information contained in this document represents the current view of
     Autodesk Inc. on the issues discussed as of the date of publication.
     Because Autodesk must respond to change in market conditions, it
     should not be interpreted to be a commitment on the part of Autodesk
     and Autodesk cannot guarantee the accuracy of any information
     presented after the date of publication.
     INFORMATION PROVIDED IN THIS DOCUMENT IS PROVIDED 'AS IS' WITHOUT
     WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING BUT NOT
     LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
     PARTICULAR PURPOSE AND FREEDOM FROM INFRINGEMENT.
     The user assumes the entire risk as to the accuracy and the use of
     this document. This  document may be copied and distributed subject to
     the following conditions:
     1.   All text must be copied without modification and all pages must
          be included
     2.   All copies must contain Autodesk's copyright notice and any other
          notices provided therein
     3.   This document may not be distributed for profit
GMT+8, 2026-11-22 09:49 , Processed in 0.320496 second(s), 11 queries , Gzip On, File On.
