查看: 3800|回复: 5
[每日一码] 五金模板图分板程序
发表于 2013-8-18 13:05:53 | 显示全部楼层 |阅读模式
文件名称:ct1.rar
下载次数:11  文件大小:4.14 KB
(defun c:ct1 ()
   (setvar "cmdecho" 0)
   (setq dcl_id (load_dialog "ct1.dcl"))
   (if(< dcl_id 0) (exit))
   (if(not (new_dialog "ct1" dcl_id)) (exit))
     (setq x (dimx_tile "a1"))
     (setq y (dimy_tile "a1"))
     (start_image "a1")
     (fill_image 0 0  x y -2)
     (slide_image 0 0 x y "yx.sld")
     (end_image)
     (setq x (dimx_tile "a2"))
     (setq y (dimy_tile "a2"))
     (start_image "a2")
     (slide_image 0 0 x y "fh.sld")
     (end_image)
   (action_tile "a3" "(done_dialog 1)")
   (action_tile "a4" "(done_dialog 2)")
   (setq dd (start_dialog))
    (unload_dialog dcl_id)
    (cond ((= dd 1)(c:cty))  ;
          ((= dd 2)(c:ctf))  ;
  (princ "\n模板分层已完成")
  (princ)
功能:分模功能
(defun c:cty ()
    (command "layer" "LO" "*" "")
    (command "layer" "U" "AC" "U" "AM" "U" "Af" "")
    (command "copy" "ALL" "" "0,0" "2000,2000");上模座
    (command "layer" "U" "Uf" "U" "UM" "U" "UC" "LO" "AC" "LO" "AM" "LO" "AF" "")
    (command "copy" "ALL" "" "0,0" "2000,1500");上垫板
    (command "layer" "U" "Hf" "U" "HM" "U" "HC" "LO" "UC" "LO" "UM" "LO" "UF" "")
    (command "copy" "ALL" "" "0,0" "2000,1000");固定板
    (command "layer" "U" "Kf" "U" "KM" "U" "KC" "LO" "HC" "LO" "HM" "LO" "HF" "")
    (command "copy" "ALL" "" "0,0" "2000,500");止高板
    (command "layer" "U" "Sf" "U" "SM" "U" "SC" "LO" "KC" "LO" "KM" "LO" "KF" "")
    (command "copy" "ALL" "" "0,0" "2000,0");脱料板
    (command "layer" "U" "Df" "U" "DM" "U" "DC" "LO" "sC" "LO" "sM" "LO" "sF" "")
    (command "copy" "ALL" "" "0,0" "2000,-500");凹模板
    (command "layer" "U" "Bf" "U" "BM" "U" "BC" "LO" "DC" "LO" "DM" "LO" "DF" "")
    (command "copy" "ALL" "" "0,0" "2000,-1000");下垫板
    (command "layer" "U" "Lf" "U" "LM" "U" "LC" "LO" "bC" "LO" "bM" "LO" "bF" "")
    (command "copy" "ALL" "" "0,0" "2000,-1500");下模座
    (command "layer" "U" "Pf" "U" "PM" "U" "PC" "LO" "LC" "LO" "LM" "LO" "LF" "")
    (command "copy" "ALL" "" "0,0" "2000,-2000");冲子层
    (command "layer" "U" "Nf" "U" "NM" "U" "NC" "LO" "pC" "LO" "pM" "LO" "pF" "")
    (command "copy" "ALL" "" "0,0" "2000,-2500");入块层
    (command "layer" "U" "*" "")
   (alert "欢迎您使用模板分层")
(PRINC)
(defun c:ctf ()
    (command "copy" "ALL" "" "0,0" "500,2000");上模座
    (command "copy" "ALL" "" "0,0" "500,1500");上垫板
    (command "copy" "ALL" "" "0,0" "500,1000");固定板
    (command "layer" "U" "Tf" "U" "TM" "U" "TC" "LO" "HC" "LO" "HM" "LO" "HF" "")
    (command "copy" "ALL" "" "0,0" "500,500");中空板
    (command "layer" "U" "Df" "U" "DM" "U" "DC" "LO" "TC" "LO" "TM" "LO" "TF" "")
    (command "copy" "ALL" "" "0,0" "500,0");凹模板
    (command "layer" "U" "Zf" "U" "ZM" "U" "ZC" "LO" "DC" "LO" "DM" "LO" "DF" "")
    (command "copy" "ALL" "" "0,0" "500,-500");下脱板
    (command "layer" "U" "Wf" "U" "WM" "U" "WC" "LO" "ZC" "LO" "ZM" "LO" "ZF" "")
    (command "copy" "ALL" "" "0,0" "500,-1000");下夹板
    (command "layer" "U" "Lf" "U" "LM" "U" "LC" "LO" "WC" "LO" "WM" "LO" "WF" "")
    (command "copy" "ALL" "" "0,0" "500,-1500");下模座
    (command "layer" "U" "Rf" "U" "RM" "U" "RC" "LO" "PC" "LO" "PM" "LO" "PF" "")
    (command "copy" "ALL" "" "0,0" "1000,2000");打料板
    (command "layer" "U" "Qf" "U" "QM" "U" "QC" "LO" "RC" "LO" "RM" "LO" "RF" "")
    (command "copy" "ALL" "" "0,0" "1000,1500");内脱板
    (command "layer" "U" "Nf" "U" "NM" "U" "NC" "LO" "QC" "LO" "QM" "LO" "QF" "")
    (command "copy" "ALL" "" "0,0" "1000,1000");凸凹模
  (alert "欢迎您使用模板分层")
(PRINC)
发表于 2013-8-18 15:30:46 | 显示全部楼层
楼主这是啥意思?:o
发表于 2013-8-18 20:03:52 | 显示全部楼层
这样写程式不太好吧,如果模板宽度超过500,模板就重叠了。
那如何才能解决这个问题呢,请指点? 我的想法是点选图框左下角,再点 选图框右上角来计算长度和宽度,最后选取放置点,就把模板分离出来,请大师们指点,谢谢  详情 回复 发表于 2013-8-20 13:20
 楼主| 发表于 2013-8-20 13:20:04 | 显示全部楼层
那如何才能解决这个问题呢,请指点?
1,分板复制不用关图层吧,直接用SSGET过滤模板图层选择 2,板间距离直接输入或者取模座尺寸加适当系数也可以  详情 回复 发表于 2013-8-20 13:45
发表于 2013-8-20 13:45:49 | 显示全部楼层
540998812@.com 发表于 2013-8-20 13:20
那如何才能解决这个问题呢,请指点?
我的想法是点选图框左下角,再点 选图框右上角来计算长度和宽度, ...
发表于 2021-5-31 00:08:35 | 显示全部楼层
感谢楼主分享五金模板图分板程序!
GMT+8, 2026-11-22 07:55 , Processed in 0.343357 second(s), 23 queries , Gzip On, File On.
