查看: 5658|回复: 3
[公告] 曲线和平面求交点
发表于 2013-9-1 16:31:44 | 显示全部楼层 |阅读模式
Intersection between plane and a curve
Here are the steps to find the intersection of a curve and a Plane (based on the explanation provided by my colleague, Krishnamurthy Kalvai). I have provided a sample code that implements these steps to find an intersection between an ellipse and a plane.
1. Determine if the curve lies on the plane. You may query this using Curve::GetPlane( ). Check if the plane returned is the same as / parallel to the intersection plane using Plane::IntersectWith( ).
If the planes are parallel, there can be infinite intersection points or no points of intersection at all. In either case, you may stop here and not go to step 2.
2. Project the curve onto the plane using Curve::GetProjectedCurve( ).
3. Find the intersection between the projected curve and original curve using IntersectWith( ). The intersection points will be the same as points of intersection of the curve with the Intersection plane.
4. As a final check, check to see if the intersection points lie on the plane using AcGeSurface::isOn( )
[CommandMethod("PlaneCurveIntersection")]
public static void PlaneCurveIntersection()
    Document activeDoc
        = Application.DocumentManager.MdiActiveDocument;
    Database db = activeDoc.Database;
    Editor ed = activeDoc.Editor;
    // Create the planar region and the ellipse
    ObjectId regionId = ObjectId.Null;
    ObjectId ellipseId = ObjectId.Null;
    using (Transaction tr
                = db.TransactionManager.StartTransaction())
        BlockTable bt = tr.GetObject(
                                        db.BlockTableId,
                                        OpenMode.ForRead
                                    ) as BlockTable;
        BlockTableRecord modelSpace = tr.GetObject
                            bt[BlockTableRecord.ModelSpace],
                            OpenMode.ForWrite
                        ) as BlockTableRecord;
        Autodesk.AutoCAD.DatabaseServices.Polyline polyline
            = new Autodesk.AutoCAD.DatabaseServices.Polyline();
        polyline.Closed = true;
        polyline.AddVertexAt
                        0,
                        new Point2d(10.0, -10.0),
                        0.0,
                        0.0,
                        0.0
                    (    1,
                        new Point2d(10.0, 10.0),
                        0.0,
                        0.0,
                        0.0
                    (    2,
                        new Point2d(-10.0, 10.0),
                        0.0,
                        0.0,
                        0.0
                        3,
                        new Point2d(-10.0, -10.0),
                        0.0,
                        0.0,
                        0.0
        DBObjectCollection coll = new DBObjectCollection();
        coll.Add(polyline);
        DBObjectCollection rgnColl
                                = Region.CreateFromCurves(coll);
        if (rgnColl.Count > 0)
            Region rgn = rgnColl[0] as Region;
            regionId = modelSpace.AppendEntity(rgn);
            tr.AddNewlyCreatedDBObject(rgn, true);
        Vector3d ellipseNormal
            = Vector3d.ZAxis.RotateBy(
                                        45.0 * Math.PI / 180.0,
                                        Vector3d.XAxis
        Vector3d ellipseMajorAxis = new Vector3d(0, 5, 0);
        ellipseMajorAxis
            = ellipseMajorAxis.RotateBy
                                        Vector3d.XAxis
        Ellipse ellipse = new Ellipse
                                        Point3d.Origin,
                                        ellipseNormal,
                                        ellipseMajorAxis,
                                        0.5,
                                        0,
                                        0
        ellipseId = modelSpace.AppendEntity(ellipse);
        tr.AddNewlyCreatedDBObject(ellipse, true);
        tr.Commit();
    // Find the intersection of the curve and the plane
        Region rgn = tr.GetObject
                                    regionId,
                                    OpenMode.ForRead
                                ) as Region;
        DBObjectCollection exploded = new DBObjectCollection();
        rgn.Explode(exploded);
        Entity firstEntity = exploded[0] as Entity;
        Plane intersectionPlane = firstEntity.GetPlane();
        Curve curve = tr.GetObject
                                    ellipseId,
                                    OpenMode.ForRead
                                ) as Curve;
        Plane curvePlane = curve.GetPlane();
        if (curvePlane.IsCoplanarTo(intersectionPlane))
            ed.WriteMessage("\nInfinite intersections !");
        else if (curvePlane.IsParallelTo(intersectionPlane))
            ed.WriteMessage("\nNo intersections !");
        else
            Curve projectedCurve
                = curve.GetProjectedCurve
                                        intersectionPlane,
                                        intersectionPlane.Normal
            Point3dCollection intPts = new Point3dCollection();
            projectedCurve.IntersectWith
                                        curve,
                                        Intersect.ExtendBoth,
                                        intPts,
                                        IntPtr.Zero,
                                        IntPtr.Zero
            foreach (Point3d pt in intPts)
                if (curvePlane.IsOn(pt))
                    ed.WriteMessage
                        string.Format(
                                        "{0}{1}",
                                        Environment.NewLine,
                                        pt.ToString()
        tr.Commit();
发表于 2013-9-1 20:41:58 来自手机 | 显示全部楼层
这个不像ARX,发错版块了吧
这个是C#  详情 回复 发表于 2013-10-4 21:59
发表于 2013-10-4 21:59:12 | 显示全部楼层
st788796 发表于 2013-9-1 20:41
这个不像ARX,发错版块了吧
这个是C#
发表于 2014-5-5 21:22:20 来自手机 | 显示全部楼层
mark
1 entity.GetPlane
2 curve.GetProjectedCurve
GMT+8, 2026-11-22 08:14 , Processed in 0.625401 second(s), 17 queries , Gzip On, File On.
