查看: 1706|回复: 2
[他山之石] Vla 选择集创建 Region
发表于 2013-10-26 14:09:31 | 显示全部楼层 |阅读模式
  1. (defun addregion (space el tf / regions)
  2.   (if (not
  3.     (vl-catch-all-error-p
  4.       (setq    regions    (vl-catch-all-apply
  5.               'vla-addregion
  6.               (list    space
  7.                 (vlax-make-variant
  8.                   (vlax-safearray-fill
  9.                     (vlax-make-safearray
  10.                       vlax-vbobject
  11.                       (cons 0 (1- (length el)))
  12.                     )
  13.                     (mapcar 'vlax-ename->vla-object el)
  14.                   )
  15.                 )
  16.               )
  17.             )
  18.       )
  19.     )
  20.       )
  21.     (progn
  22.       (safearray-value (variant-value regions))
  23.       (if tf
  24.     (mapcar 'entdel el)
  25.       )
  26.     )
  27.   )
  28. )
评分
参与人数 1D豆 +5 收起 理由
炫翔 + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
已领礼包: 75个
发表于 2017-2-24 12:54:25 | 显示全部楼层
举个例子就好了,
已领礼包: 20个
发表于 2017-2-24 14:15:46 | 显示全部楼层
写格选择代码,然后带入函数就行了
(defun c:tt (/ ss el i)
  (if (setq ss (ssget '((0 . "*LINE,CIRCLE,ELLIPSE"))))
    (progn
      (setq i -1)
      (repeat (sslength ss)
        (setq el (cons (ssname ss (setq i (1+ i))) el))
      (addregion (vla-get-ModelSpace
                   (vla-get-ActiveDocument (vlax-get-acad-object))
                 el
                 t
  (princ)
GMT+8, 2026-11-5 22:14 , Processed in 0.470926 second(s), 37 queries , Gzip On.
