查看: 3104|回复: 1
[每日一码] 自动提取图中字体软件
发表于 2013-11-30 19:04:59 | 显示全部楼层 |阅读模式
;;;    |            自动提取图中字体软件           |
;;;    |              Update: 03.06.12             |
;;;以下内容定义程序加载时提示加载次数、版权等信息
;;;(setq cm (getvar "cmdecho"))
;;;(setvar "cmdecho" 0)
;;;(while (= nil (findfile "acad.fnt"))
;;;  ;(setq fp (open "c:\acad.fnt" "w"))
;;;  ;(setq fp (open "acad.fnt" "w"))
;;;  ;(write-line "3" fp)
;;;  ;(close fp)
;;;  ;(command "sh" "attrib acad.fnt +h")
;;;;(setq fp (open "acad.fnt" "r"))
;;;;(setq count (read (read-line fp)))
;;;;(close fp)
;;;;(command "sh" "attrib acad.fnt +h")
;;;;(if (or    (= count 3)
;;;;    (= count 9)
;;;;    (= count 27)
;;;;    (= count 81)
;;;;    (= count 243)
;;;;    (= count 729)
;;;;    (= count 2187)
;;;;    (= count 6561)
;;;;    (= count 19683)
;;;;    (= count 59049)
;;;;    (= count 177147)
;;;;    (= count 531441)
;;;;  (progn
;;;;;;    (if    (= count 3)
;;;;;;      (setq alc "1 time.")
;;;;;;    (if    (= count 9)
;;;      (setq alc "2 times.")
;;;    (if    (= count 81)
;;;      (setq alc "3 times.")
;;;    (if    (= count 243)
;;;      (setq alc "4 times.")
;;;    (if    (= count 729)
;;;      (setq alc "5 times.")
;;;    (if    (= count 2187)
;;;      (setq alc "6 times.")
;;;    (if    (= count 6561)
;;;      (setq alc "7 times.")
;;;    (if    (= count 19683)
;;;      (setq alc "8 times.")
;;;    (if    (= count 59049)
;;;      (setq alc "9 times.")
;;;    (if    (= count 177147)
;;;      (setq alc "10 times.")
;;;    (if    (= count 531441)
;;;      (setq alc
;;;         "11 (bonus) times.  After this use AUTOFONT.LSP will become inoperative."
;;;    (setq prmt (strcat "\n AUTOFONT.LSP has already been loaded "
;;;               alc
;;;               " \n"
;;;  (setq    prmt
;;;     (strcat
;;;       "\n ** LSP program has already been loaded 10 times and is become inoperative ** ;\n"
;;;(close fp)
;;;    (= count 9)
;;;    (= count 27)
;;;    (= count 81)
;;;    (= count 243)
;;;    (= count 729)
;;;    (= count 2187)
;;;    (= count 6561)
;;;    (= count 19683)
;;;    (= count 59049)
;;;  (progn
;;;    (command "sh" "attrib acad.fnt -h")
;;;    (setq fp (open "acad.fnt" "w"))
;;;    (setq aaa (* count 3))
;;;    (princ aaa fp)
;;;    (write-line aaa fp)
;;;    (close fp)
;;;    (command "sh" "attrib acad.fnt +h")
;;;以下定义从关联表“elist”中搜索含有元素“code”的条目
(defun dxf (code elist) (cdr (assoc code elist)))
;;;以下定义得到所有指定类型“tbname”的集合
(defun tnlist (tbname / tdata tblist)
  (while (setq tdata (tblnext tbname (not tdata)))
    (setq tblist (append tblist (list (dxf 2 tdata))))
  ) ;_ 结束while
) ;_ 结束defun
;;;以下定义得到关键字提示
(defun ukword (bit kwd msg def / inp)
  (if (and def (/= def ""))
    (setq msg (strcat "\n" msg "<" def ">: ")
      bit (* 2 (fix (/ bit 2)))
    ) ;_ 结束setq
    (if    (= " " (substr msg (strlen msg) 1))
      (setq msg (strcat "\n" (substr msg 1 (1- (strlen msg))) ": "))
      (setq msg (strcat "\n" msg ": "))
    ) ;_ 结束if
  ) ;_ 结束if
  (initget bit kwd)
  (setq inp (getkword msg))
  (if inp
    inp
    def
  ) ;_ 结束if
) ;_ 结束defun
;;;    (defun ustr    (bit msg def spflag / inp nval)
;;;      (if (and def (/= def ""))
;;;    (setq msg (strcat "\n" msg "<" def ">: ")
;;;          inp (getstring msg spflag)
;;;          inp (if (= inp "")
;;;            def
;;;            inp
;;;    (progn (if (= " " (substr msg (strlen msg) 1))
;;;         (setq
;;;           msg (strcat "\n" (substr msg 1 (1- (strlen msg))) ": ")
;;;         (setq msg (strcat "\n" msg ": "))
;;;           (if (= bit 1)
;;;         (while    (= "" (setq inp (getstring msg spflag)))
;;;           (prompt "\nInvalid string.")
;;;         (setq inp (getstring msg spflag))
;;;    (prompt "\nType AF to run autofont.LSP \n")
(defun C:AF (/        cm       l      ll     counts    countn countp fp
         x        test   testl  n     fnts    fntb   fntl   uk
         fntf   fntc   countp si     sii    stt    fntll
  (princ (strcat "\n***自动提取图中字体软件V031212***"))
  (princ (strcat "\n       [它山之石修正版]"))
  (princ)
    l      (tnlist "style")        ;列出本图中定义的所有字体
    ll     (length l)        ;所有的字体数
    counts 0
    countn 1
    countp 0
  ) ;_ 结束setq
  (command "shell" (strcat "md c:gelei"))
;;;建立备份字体的文件夹
  (while (setq n (nth counts l))
    (setq counts (+ counts 1))
    (setq fnts (dxf 3 (tblsearch "style" n)))
    (setq fntb (dxf 4 (tblsearch "style" n)))
    (if    (or (eq "txt" fnts) (eq "txt.shx" fnts))
      (setq err 1)
      (setq fntl (append fntl (list (strcase fnts))))
    ) ;_ 结束if
    (if    (not (eq "" fntb))
      (setq fntl (append fntl (list (strcase fntb))))
    ) ;_ 结束if
  ) ;_ 结束while
  (setq fntl (append fntl (list (strcase (getvar "dwgname")))))
  (setq dwgn (findfile (getvar "dwgname")))
  (if err
    (alert
      (strcat
    "\n                     ******  友  情  提  醒  ******"
    "\n\n        本图中使用了“txt.shx”字体,在移动或复制实体时"
    "\n\n可能会导致AutoCAD系统崩溃或其它未可知的致命错误!"
    "\n\n共享版本不提供自动提取该字体文件的功能!"
    "\n\n                                                    ----它山之石") ;_ 结束strcat
    ) ;_ 结束alert
    (setq err nil)
  ) ;_ 结束if
  (foreach x fntl
    (if    (not (member x fntll))
      (setq fntll (append fntll (list x)))
    ) ;_ 结束if
  ) ;_ 结束foreach
  (setq sty (length fntll))
  (foreach x fntll
    (progn
      (if x
    (progn
      (if (findfile x)
        (setq x x)
        (progn
          (if (eq "TTF" (setq qq (substr x (- (strlen x) 2))))
        (progn
          (alert
            (strcat
              "\n\n        字体 " x " 可能是WINDOWS的系统字体,"
              "\n\n使用此类字体会导致图形文件狂大,少用为宜。"
          ) ;_ 结束alert
          (setq ttf 1)
        ) ;_ 结束progn
        (setq x (strcat x ".shx"))
          ) ;_ 结束if
        ) ;_ 结束progn
      ) ;_ 结束if
      (if (setq fntf (findfile x))
        (progn
          (setq fntc " c:\GELEI\")
          (setq si 1
            sii    0
          ) ;_ 结束setq
          (setq txt 1)        ;得到要查找字符串的长度
          (while            ;在一个被查找字符串中循环查找
        (= txt (strlen (setq st (substr fntf si txt))))
         (if (or (eq st "") (eq st "."))
                    ;如果查找到相匹配的字符串
           (setq sii (+ si 1))
         ) ;_ 结束if
         (if (> (- si sii) 7)    ;如果查找到相匹配的串
           (progn
             (setq stt (substr fntf sii (- si sii)))
             (setq stt (strcat (substr stt 1 6) "~1"))
             (setq fntf    (strcat    (substr fntf 1 (- sii 1))
                    stt
                    (substr fntf (+ 1 si))
                ) ;_ 结束strcat
             ) ;_ 结束setq
             (setq si (- si sii 8))
             (command "SHELL"
                  (strcat "XCOPY " fntf fntc " /y")
             ) ;_ 结束command
           ) ;_ 结束progn
         ) ;_ 结束if
         (setq si (+ 1 si))
          ) ;_ 结束while
          (setq countp (+ countp 1))
        ) ;_ 结束progn
        (progn
          (if ttf
        (setq ttf nil)
        (alert
          (strcat "n        在AutoCAD的搜索路径下未找到字体 "
              x
              " ,n"
              "n本图可能也无法正确显示使用该字体的文本!n"
          ) ;_ 结束strcat
        ) ;_ 结束alert
          ) ;_ 结束if
        ) ;_ 结束progn
      ) ;_ 结束if
    ) ;_ 结束progn
      ) ;_ 结束if
    ) ;_ 结束progn
  ) ;_ 结束foreach
  (command "shell"
       "DIR c:GELEI*.shx /s/a/B >C:GELEIGELEI"
  ) ;_ 结束command
  (setq lujing (open "C:GELEIGELEI" "r"))
                    ;LUJING--保存带完全路径的文件名
  (setq n 0)
  (while
    (read-line LUJING)
     (setq n (+ n 1))
  )                    ;WENJIAN--带完全路径的文件名
  (close LUJING)
  (command "shell" "del C:GELEIGELEI")
  (alert (strcat "n       本图中共定义了 "
         (rtos ll 5)
         " 个文字式样,使用到了"
         (rtos sty 5)
         " 个字体文件,nn其中"
         (rtos n 5)
         "个被提取到了 "
         "C:GELEI 目录下"
     ) ;_ 结束strcat
  ) ;_ 结束alert
  (princ (strcat "n***自动提取图中字体软件V031212***"))
  (princ (strcat "n       [它山之石修正版]"))
  (princ)
) ;_ 结束defun
已领礼包: 1094个
发表于 2021-5-23 06:30:17 | 显示全部楼层
感谢楼主分享自动提取图中字体软件!
GMT+8, 2026-11-3 13:52 , Processed in 0.442390 second(s), 35 queries , Gzip On.
