查看: 2172|回复: 0
[原创] 根据表自动构建字符关键字及提示
发表于 2013-12-1 15:02:02 | 显示全部楼层 |阅读模式
  1. (defun SetInitKey (lst / len i ll)
  2.   (if (< (setq len (length lst)) 26)
  3.     (progn
  4.       (setq i 64)
  5.       (repeat len
  6.         (setq ll (cons (chr (setq i (1+ i))) ll))
  7.       )
  8.       (list (reverse ll)
  9.             (strcat "["
  10.                     (vl-string-trim
  11.                       "()/"
  12.                       (vl-princ-to-string
  13.                         (mapcar        '(lambda (x y)
  14.                                    (strcat x " - " y "/")
  15.                                  )
  16.                                 (reverse ll)
  17.                                 (mapcar 'vl-princ-to-string lst)
  18.                         )
  19.                       )
  20.                     )
  21.                     "]: "
  22.             )
  23.       )
  24.     )
  25.   )
  26. )
_$ (setinitkey '(1 2 3 4 5))
(("E" "D" "C" "B" "A") "[A - 1/ B - 2/ C - 3/ D - 4/ E - 5]: ")
_$
GMT+8, 2026-11-22 08:18 , Processed in 0.594205 second(s), 11 queries , Gzip On, File On.
