查看: 3929|回复: 3
[分享] [两套控件]Vsflexgrid8.0和Vsview8.0 最新注册版
发表于 2013-12-7 19:23:22 | 显示全部楼层 |阅读模式
Vsflexgrid8.0(制作网格,树型目录、合并等)
官方最新版下载地址:
1、 http://download3.componentone.com/pub/ActiveX/flex8/Updates/flex8_T205.exe
注册码:S741039-FV-024110
S741022-CW-036700
S741045-TL-089390
2、http://download3.componentone.com/pub/ActiveX/flex8/misc/flex8_8.0.20063.235.zip
安装方法:
下载1中安装文件,输入注册码,就成功注册了。下载2中文件,并拷到
系统目录(XP为system32),就是最新版了
Vsview8.0(输出报表,打印预览、 打印等)
1、http://download3.componentone.com/pub/ActiveX/view8/Updates/view8_t205.exe
上面注册成功后,一般不会再问这个控件的注册码的。如果这个还提示
注册,s/n: 0640200-KD-999999
2、http://download3.componentone.com/pub/ActiveX/view8/misc/view8_8.0.20071.129.zip
安装方法:
同上面Vsflexgrid控件.下载1安装,下载2解压拷到系统目录。
The ComponentOne VSFlexGrid 8.0 package consists of two ActiveX controls:
VSFlexGrid
A powerful, full-featured grid. It provides new ways to display, edit, format, organize, summarize, and print tabular data.
VSFlexGrid gives you several choices of data binding: ADO/OLEDB, DAO, bind to 2-D or 3-D arrays, to other VSFlexGrid controls, create your own data source classes, or use the grid in unbound mode.
It will read and write grids to a compressed binary file or to a text file (compatible with Microsoft Access and Excel). (这条最爽,累人的活你就不用干了)
VSFlexGrid provides all the basics plus advanced features such as outline trees, sorting, cell merging, masked editing, translated combo and image lists, and automatic data aggregation.
VSFlexString
A flexible regular expression engine. It features pattern matching as well as regular expression text matching. VSFlexString's automatic replace capability immediately replaces all matches with the new assigned string. Tag matching capabilities determine which parts of the string matched what parts of the pattern.
The ComponentOne VSView8 package consists of four custom controls:
1) VSPrinter
VSPrinter allows you to create documents that can be previewed, printed, and saved to disk. VSPrinter supports multi-page documents with headers, footers, full character, paragraph, and page formatting, tables, graphics, and pictures. It also supports HTML and RTF formats, and can be used in a Web browser for accurate previewing of documents published on your Web site.(老有人问预览功能,这可能是你的福音)
2) VSDraw
VSDraw allows you to create complex, scalable images such as charts, diagrams, and maps. The images can be previewed, saved to disk, and copied to other documents, including VSPrinter documents.
3) VSViewPort
VSViewport allows you to create scrollable areas within your forms so you can fit large (or many small controls) in your forms. Use it to implement fill-out forms or as an alternative to tab controls.
4) VSPDF8
VSPDF allows you to create and add information to PDF files.
5) Excellent Documentation
VSView8 includes an extensive manual and online help with plenty of tutorials and examples. If you have suggestions on how we can improve our documentation, please email the Documentation team. Please note that e-mail sent to the Documentation team is for documentation feedback only. Technical Support and Sales issues should be sent directly to their respective departments.
发表于 2013-12-31 16:39:13 | 显示全部楼层
感谢分享,正好能用到,这几天在研究这个控件,确实比OpenDCL的Grid控件要强大。
有个问题请教一下。作为ActiveX控件引入OpenDCL中时,如何用Vlisp方式设置以下几个属性:
CellButtonPicture
(dcl_AxControl_Put ghd_docman_pfgrid "CellButtonPicture" NewValue [as IPictureDisp])
"NodeClosedPicture"
(dcl_AxControl_Put ghd_docman_pfgrid "NodeClosedPicture" NewValue [as IPictureDisp])
发表于 2014-10-24 08:59:53 | 显示全部楼层
这些控件用LISP怎么操作呢
发表于 2014-10-25 12:17:33 来自手机 | 显示全部楼层
留存http://m.blog.csdn.net/blog/boovo/594958
GMT+8, 2026-11-22 08:11 , Processed in 0.206564 second(s), 14 queries , Gzip On, File On.
