查看: 5138|回复: 10
[分享] 实体ToolTip显示XData
已领礼包: 1268个
发表于 2013-12-22 22:00:48 | 显示全部楼层 |阅读模式
http://379910987.blog.163.com/blog/static/335237972010111332519131/ 实体ToolTip显示XData
首先要说明,实现方式不是我的原创,其中ToolTip的实现转自这里,然后XData的设置和获取来自Kean的博客,当然我自己也做了点研究,在这里,然后把这两个技术结合起来就是你将要看到的东西。
先上效果吧。
下面是实现的代码:
public class Class1:IExtensionApplication
        void IExtensionApplication.Initialize()
            Mytooltip();
        void IExtensionApplication.Terminate()
        public void Mytooltip()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            ed.PointMonitor += new PointMonitorEventHandler(MytooltipOn);
        private void MytooltipOn(object sender, PointMonitorEventArgs e)
            Database db = Application.DocumentManager.MdiActiveDocument.Database;
            FullSubentityPath[] ePaths = e.Context.GetPickedEntities();
            if (ePaths.Length > 0)
                FullSubentityPath ePath = ePaths[0];
                using (Transaction trans = db.TransactionManager.StartTransaction())
                    ObjectId entId = ePath.GetObjectIds()[0];
                    Entity ent = (Entity)trans.GetObject(entId, OpenMode.ForRead);
                    e.AppendToolTipText(GetXData(ent));
                    trans.Commit();
            else
                e.AppendToolTipText("\n未指向实体");
        static public string GetXData(Entity ent)
            string ret = "";
            ResultBuffer rb = ent.XData;
            if (rb == null)
                return "该实体不包含XData.";
            else
                int n = 0;
                foreach (TypedValue tv in rb)
                    ret += string.Format("类型值{0} - 类型: {1}, 值: {2}\n", n, tv.TypeCode, tv.Value);
                    n++;
                rb.Dispose();
                return ret;
        [CommandMethod("SetXD")]
        static public void SetXData()
            PromptEntityOptions peo = new PromptEntityOptions("\n请选择实体:");
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status == PromptStatus.OK)
                Transaction trans = doc.TransactionManager.StartTransaction();
                DBObject obj = trans.GetObject(per.ObjectId, OpenMode.ForWrite);
                AddRegAppTableRecord("Test");
                ResultBuffer rb = new ResultBuffer();
                rb.Add(new TypedValue(1001, "Test"));
                rb.Add(new TypedValue(1000, "Greeting! I am the XData"));
                rb.Add(new TypedValue(1000, "Today is very Cold"));
                obj.XData = rb;
                rb.Dispose();
                trans.Commit();
                trans.Dispose();
        static void AddRegAppTableRecord(string regAppName)
            Database db = doc.Database;
            RegAppTable rat = (RegAppTable)trans.GetObject(db.RegAppTableId, OpenMode.ForRead, false);
            if (!rat.Has(regAppName))
                rat.UpgradeOpen();
                RegAppTableRecord ratr = new RegAppTableRecord();
                ratr.Name = regAppName;
                rat.Add(ratr);
                trans.AddNewlyCreatedDBObject(ratr, true);
            trans.Commit();
            trans.Dispose();
命令SetXD用于设置XData,不然新建的实体是不包含XData的。指向一个实体后,将会自动显示该实体的XData
已领礼包: 604个
发表于 2016-8-17 15:36:07 | 显示全部楼层
lisp怎么实现呢?  只有用“超级连接”吗?
LISP的实现可以去看看这个帖子 http://bbs.xdcad.net/thread-671343-1-3.html  详情 回复 发表于 2016-8-17 16:19
lisp只有超链,tooltip没有autolisp实现,只能借助arx/c#拓展pointmonitor,如xdapi或高飞那个arx(已加入xdapi)  详情 回复 发表于 2016-8-17 15:42
已领礼包: 859个
发表于 2016-8-17 15:42:55 来自手机 | 显示全部楼层
评分
参与人数 1D豆 +5 收起 理由
/db_自贡黄明儒_ + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2016-8-17 16:19:06 | 显示全部楼层
LISP的实现可以去看看这个帖子
已领礼包: 604个
发表于 2016-8-17 16:25:14 | 显示全部楼层
newer 发表于 2016-8-17 16:19
LISP的实现可以去看看这个帖子
显示对象本身一些东西,这个我知道。不用XD也可实现。我的想法是显示自己加进去的一东西,比如什么时间因什么修改。。。。
那东西 你能读出什么,就能显示出什么,看你怎么写。  详情 回复 发表于 2016-8-17 17:08
发表于 2016-8-17 17:08:17 | 显示全部楼层
/db_自贡黄明儒_ 发表于 2016-8-17 16:25
显示对象本身一些东西,这个我知道。不用XD也可实现。我的想法是显示自己加进去的一东西,比如什么时间因 ...
已领礼包: 12个
发表于 2017-12-17 23:22:27 | 显示全部楼层
感谢楼主分享!
已领礼包: 9个
发表于 2018-11-20 22:24:12 | 显示全部楼层
感谢分享,学习了
发表于 2020-5-29 16:07:43 | 显示全部楼层
学习!!!!!!!!!!!谢谢!!!
发表于 2020-10-11 20:44:02 | 显示全部楼层
来学习学习
发表于 2021-11-3 09:07:24 | 显示全部楼层
看看好你把
GMT+8, 2026-11-3 01:47 , Processed in 0.608707 second(s), 51 queries , Gzip On.
