查看: 1750|回复: 3
[求助] 程序报错:参数太多
发表于 2013-12-31 14:44:54 | 显示全部楼层 |阅读模式
(defun c:gujin()
  (command "layer" "n" "小于箍筋" "")
  (command "layer" "c" 1 "小于箍筋" "")
  (setq num1 (getreal "请输小于的数值:"))
  (setq num2 (getreal "请输小于的数值:"))
  (setq ReinGroup(ssget '((0 . "*TEXT")(8 . "21000"))))
  (setq i 0)
  (setq LenRein(sslength ReinGroup))
  (repeat LenRein
    (setq ent(entget (ssname ReinGroup i)))
     (if(/= ent nil)
        (progn
       (setq str(cdr(assoc 1 ent)))
(setq jsjtype(substr str 1 1))
    (if(and(/= ent nil)(= jsjtype "G"))
(setq strmid str)
        (setq numa(atof(substr strlist 2 3)))
(setq numb(atof(substr strlist 6 3)))
  (if(and(<= numa num1)(<= numb num2))
    (setq Result_layer "小于箍筋")
  (setq ent(subst(cons 8 Result_layer)(assoc 8 ent)ent))
  (entdel(ssname ReinGroup i))
        (entmake ent)
  (setq i (1+ i))
处理类似“G1.0-0.5”这样的数据
望各位大神看下,到底是什么问题
 楼主| 发表于 2013-12-31 14:45:53 | 显示全部楼层
  1. <P>(defun c:gujin()
  2.   (command "layer" "n" "小于箍筋" "")
  3.   (command "layer" "c" 1 "小于箍筋" "")
  4.   (setq num1 (getreal "请输小于的数值:"))
  5.   (setq num2 (getreal "请输小于的数值:"))
  6.   (setq ReinGroup(ssget '((0 . "*TEXT")(8 . "21000"))))
  7.   (setq i 0)
  8.   (setq LenRein(sslength ReinGroup))
  9.   (repeat LenRein
  10.     (setq ent(entget (ssname ReinGroup i)))
  11.      (if(/= ent nil)
  12.         (progn
  13.        (setq str(cdr(assoc 1 ent)))
  14. (setq jsjtype(substr str 1 1))
  15.
  16.     (if(= jsjtype "G")
  17. (setq strmid str)
  18.         (setq numa(atof(substr strmid 2 3)))
  19. (setq numb(atof(substr strmid 6 3)))
  20.       )
  21.   (if(and(<= numa num1)(<= numb num2))
  22.     (setq Result_layer "小于箍筋")
  23.     )
  24.        )
  25.        )
  26.
  27.   (setq ent(subst(cons 8 Result_layer)(assoc 8 ent)ent))
  28.   (entdel(ssname ReinGroup i))
  29.         (entmake ent)
  30.   (setq i (1+ i))
  31.   )
  32. )
  33. </P>
 楼主| 发表于 2013-12-31 15:03:13 | 显示全部楼层
发现一些低级错误。。可是还是有问题。。。求大神指导
已领礼包: 12493个
发表于 2013-12-31 20:07:58 | 显示全部楼层
  1. (defun c:gujin()
  2.   (command "layer" "n" "小于箍筋" "c" 1 "小于箍筋" "")
  3.   (setq num1 (getreal "请输小于的数值: "))
  4.   (setq num2 (getreal "请输小于的数值: "))
  5.   (setq ReinGroup (ssget '((0 . "*TEXT")(8 . "21000"))))
  6.   (setq i 0)
  7.   (setq LenRein(sslength ReinGroup))
  8.   (repeat LenRein
  9.    (setq ent(entget (ssname ReinGroup i)))
  10.    (setq str(cdr(assoc 1 ent)))
  11.    (setq jsjtype(substr str 1 1))
  12.    (if(= jsjtype "G") (progn
  13.     (setq strmid str)
  14.     (setq numa(atof(substr strmid 2 3)))
  15.     (setq numb(atof(substr strmid 6 3)))
  16.    ))
  17.    (if(and(<= numa num1)(<= numb num2))
  18.     (setq Result_layer "小于箍筋")
  19.    )
  20.    (entmod (subst(cons 8 Result_layer)(assoc 8 ent)ent))
  21.    (setq i (1+ i))
  22.   )
  23.   (princ)
  24. )
GMT+8, 2026-11-6 15:50 , Processed in 0.386767 second(s), 39 queries , Gzip On.
