查看: 2199|回复: 1
[公告] 列出已Load的Project中所有的Control名称
发表于 2014-1-11 19:49:30 | 显示全部楼层 |阅读模式
先暂存下
  1. (defun ODCL::Project:List (/ lst el)
  2.   (setq        lst (dcl_getprojects)
  3.         el  (mapcar
  4.               'list
  5.               lst
  6.               (mapcar 'dcl_project_getforms lst)
  7.             )
  8.   )
  9.   (mapcar
  10.     '(lambda (x)
  11.        (cons
  12.          (car x)
  13.          (mapcar
  14.            '(lambda (a)
  15.               (cons
  16.                 (dcl_control_getname a)
  17.                 (mapcar 'dcl_control_getname (dcl_form_getcontrols a))
  18.               )
  19.             )
  20.            (cadr x)
  21.          )
  22.        )
  23.      )
  24.     el
  25.   )
  26. )
_$ (ODCL::Project:List)
(("xdcad" ("MainMenu" "BackGround" "PictureBox" "Tab01" "Tab11" "Tab21" "Tab31" "Tab41" "Tab51" "Tab61" "Tab71" "Tab81" "Tab91" "Split0" "Split1" "Split2" "Split3" "Split4" "Split5" "Split6" "Split7" "Split8" "Split9" "Split01" "Split11" "Split21" "Split31" "Split41" "Split51" "Split61" "Split71" "Split81" "Split91" "Button0" "Button1" "Button2" "Button3" "Button4" "Button5" "Button6" "Button7" "Button8" "Button9" "Button10" "Button11" "Button12" "Button13" "Button14" "Button15" "Button16" "Button17" "Button18" "Button19" "Button20" "Button21" "Button22" "Button23" "Button24" "Button25" "Button26" "Tab0" "Tab1" "Tab2" "Tab3" "Tab4" "Tab5" "Tab6" "Tab7" "Tab8" "Tab9")))
_$
发表于 2014-1-12 01:23:36 | 显示全部楼层
真迅速啊,提前解决烦恼
GMT+8, 2026-11-22 09:54 , Processed in 0.241938 second(s), 10 queries , Gzip On, File On.
