查看: 4006|回复: 7
[分享] Tracing a boundary defined by AutoCAD geometry using .NET
已领礼包: 859个
发表于 2014-5-8 15:31:52 来自手机 | 显示全部楼层 |阅读模式
http://through-the-interface.typepad.com/through_the_interface/2010/06/tracing-a-boundary-defined-by-autocad-geometry-using-net.html
As alluded to in this previous post, today we’re going to see some code that makes use of a very cool new API feature in AutoCAD 2011: the Editor.TraceBoundary() function. This little gem performs something developers have struggled with – and have asked us for – for many years. Previously you had to jump through significant hoops (or should that be loops? <groan>) to get this to work: one common approach would be to drive the BOUNDARY command programmatically and check the results appended to the database. All very messy.
Anyway, we got there eventually. This function takes a “seed” point and returns a collection of newly-created entities that define our boundary. We can then either pump these through the transient graphics sub-system or – and this is the approach we’re going to take – add them to the drawing to make them persistent.
You need to bear in mind that this function ultimately has similar constraints to the BOUNDARY and BHATCH commands: it also works off AutoCAD’s display list and so the user will need to be appropriately ZOOMed into the geometry that is to be used for boundary detection.
Here’s some C# code to create boundaries – with a lineweight applied and of an automatically incremented colour index – for points the user selects:
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.EditorInput;
  3. using Autodesk.AutoCAD.DatabaseServices;
  4. using Autodesk.AutoCAD.Runtime;
  5. namespace TraceBoundary
  6. {
  7.   public class Commands
  8.   {
  9.     static int _index = 1;
  10.     [CommandMethod("TB")]
  11.     public void TraceBoundary()
  12.     {
  13.       Document doc =  Application.DocumentManager.MdiActiveDocument;
  14.       Database db = doc.Database;
  15.       Editor ed = doc.Editor;
  16.       // Select a seed point for our boundary
  17.       PromptPointResult ppr =  ed.GetPoint("
  18. Select internal point: ");
  19.       if (ppr.Status != PromptStatus.OK)        return;
  20.       // Get the objects making up our boundary
  21.       DBObjectCollection objs =  ed.TraceBoundary(ppr.Value, true);
  22.       if (objs.Count > 0)
  23.       {
  24.         Transaction tr =
  25.           doc.TransactionManager.StartTransaction();
  26.         using (tr)
  27.         {
  28.           // We'll add the objects to the model space
  29.           BlockTable bt =
  30.             (BlockTable)tr.GetObject(
  31.               doc.Database.BlockTableId,
  32.               OpenMode.ForRead
  33.             );
  34.           BlockTableRecord btr =
  35.             (BlockTableRecord)tr.GetObject(
  36.               bt[BlockTableRecord.ModelSpace],
  37.               OpenMode.ForWrite
  38.             );
  39.           // Add our boundary objects to the drawing and
  40.           // collect their ObjectIds for later use
  41.           ObjectIdCollection ids = new ObjectIdCollection();
  42.           foreach (DBObject obj in objs)
  43.           {
  44.             Entity ent = obj as Entity;
  45.             if (ent != null)
  46.             {
  47.               // Set our boundary objects to be of
  48.               // our auto-incremented colour index
  49.               ent.ColorIndex = _index;
  50.               // Set the lineweight of our object
  51.               ent.LineWeight = LineWeight.LineWeight050;
  52.               // Add each boundary object to the modelspace
  53.               // and add its ID to a collection
  54.               ids.Add(btr.AppendEntity(ent));
  55.               tr.AddNewlyCreatedDBObject(ent, true);
  56.             }
  57.           }
  58.           // Increment our colour index
  59.           _index++;
  60.           // Commit the transaction
  61.           tr.Commit();
  62.         }
  63.       }
  64.     }
  65.   }
  66. }
Here’s our TB command in action.
Before…
已领礼包: 604个
发表于 2014-5-9 11:41:53 | 显示全部楼层
LZ,没有lisp版的?
可以写成一个lisp函数,就如xdrxapi  详情 回复 发表于 2014-5-9 11:46
已领礼包: 859个
 楼主| 发表于 2014-5-9 11:46:38 来自手机 | 显示全部楼层
/db_自贡黄明儒_ 发表于 2014-5-9 11:41
LZ,没有lisp版的?
低版本的Net没有这个函数,2011以上
已领礼包: 5060个
发表于 2019-4-23 09:02:48 来自手机 | 显示全部楼层
hpgaptol系统变量不能自动找到封闭区域,有办法自定义traceboundary吗?
来自: 微社区
发表于 2019-6-30 16:26:41 | 显示全部楼层
非常感谢楼主,学习一下
发表于 2019-9-1 11:51:54 来自手机 | 显示全部楼层
感谢楼主分享!学习中!
来自: 微社区
发表于 2019-9-1 11:53:36 来自手机 | 显示全部楼层
感谢楼主分享!学习中!
来自: 微社区
已领礼包: 58个
发表于 2019-10-17 19:48:11 来自手机 | 显示全部楼层
图很大的时候 这个会很慢吧
来自: 微社区
GMT+8, 2026-11-3 00:56 , Processed in 0.505731 second(s), 48 queries , Gzip On.
