查看: 2154|回复: 1
[分享] Creating the smallest possible rectangle around 2D AutoCAD geometry using .NET
已领礼包: 859个
发表于 2014-5-8 15:41:27 来自手机 | 显示全部楼层 |阅读模式
[ 本帖最后由 csharp 于 2014-5-15 10:12 编辑 ]\n\n[ 本帖最后由 csharp 于 2014-5-15 10:11 编辑 ]\n\n[ 本帖最后由 csharp 于 2014-5-9 06:53 编辑 ]\n\n[url=http://through-the-interface.typepad.com/through_the_interface/2012/11/creating-the-smallest-possible-rectangle-around-2d-autocad-geometry-using-net.html]http://through-the-interface.typepad.com/through_the_interface/2012/11/creating-the-smallest-possible-rectangle-around-2d-autocad-geometry-using-net.html[/url]
There was a follow-up comment on this previous post, requesting that it also create a rectangular boundary around selected geometry. This is a much simpler problem to solve that dealing with a minimum enclosing circle, so I was happy enough to oblige. :-)
Rather than duplicate code from the previous implement, I went ahead and generalised it to contain a core set of functions that get called from different commands: MEC in the existing case where circular boundaries are required and MER for the new case of a rectangular polyline boundary.
I’ve also adjusted the prompts and code to be more general – including renaming the system variable to ENCLOSINGBOUNDARYBUFFER, although I only tested via the fallback USERI1 variable – and it all seems to work as expected.
Here’s the updated C# code:
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.DatabaseServices;
  3. using Autodesk.AutoCAD.EditorInput;
  4. using Autodesk.AutoCAD.Runtime;
  5. using Autodesk.AutoCAD.Geometry;
  6. using System.Collections.Generic;
  7. using System.Linq;
  8. using System;
  9. namespace MinimumEnclosingBoundary
  10. {
  11.   public class Commands
  12.   {
  13.     [CommandMethod("MER", CommandFlags.UsePickSet)]
  14.     public void MinimumEnclosingRectangle()
  15.     {
  16.       MinimumEnclosingBoundary(false);
  17.     }
  18.     [CommandMethod("MEC", CommandFlags.UsePickSet)]
  19.     public void MinimumEnclosingCircle()
  20.     {
  21.       MinimumEnclosingBoundary();
  22.     }
  23.     public void MinimumEnclosingBoundary(
  24.       bool circularBoundary = true
  25.     )
  26.     {
  27.       Document doc =
  28.           Application.DocumentManager.MdiActiveDocument;
  29.       Database db = doc.Database;
  30.       Editor ed = doc.Editor;
  31.       // Ask user to select entities
  32.       PromptSelectionOptions pso =
  33.         new PromptSelectionOptions();
  34.       pso.MessageForAdding = "\nSelect objects to enclose: ";
  35.       pso.AllowDuplicates = false;
  36.       pso.AllowSubSelections = true;
  37.       pso.RejectObjectsFromNonCurrentSpace = true;
  38.       pso.RejectObjectsOnLockedLayers = false;
  39.       PromptSelectionResult psr = ed.GetSelection(pso);
  40.       if (psr.Status != PromptStatus.OK)
  41.         return;
  42.       bool oneBoundPerEnt = false;
  43.       if (psr.Value.Count > 1)
  44.       {
  45.         PromptKeywordOptions pko =
  46.           new PromptKeywordOptions(
  47.             "\nMultiple objects selected: create " +
  48.             "individual boundaries around each one?"
  49.           );
  50.         pko.AllowNone = true;
  51.         pko.Keywords.Add("Yes");
  52.         pko.Keywords.Add("No");
  53.         pko.Keywords.Default = "No";
  54.         PromptResult pkr = ed.GetKeywords(pko);
  55.         if (pkr.Status != PromptStatus.OK)
  56.           return;
  57.         oneBoundPerEnt = (pkr.StringResult == "Yes");
  58.       }
  59.       // There may be a SysVar defining the buffer
  60.       // to add to our radius
  61.       double buffer = 0.0;
  62.       try
  63.       {
  64.         object bufvar =
  65.           Application.GetSystemVariable(
  66.             "ENCLOSINGBOUNDARYBUFFER"
  67.           );
  68.         if (bufvar != null)
  69.         {
  70.           short bufval = (short)bufvar;
  71.           buffer = bufval / 100.0;
  72.         }
  73.       }
  74.       catch
  75.       {
  76.         object bufvar =
  77.           Application.GetSystemVariable("USERI1");
  78.         if (bufvar != null)
  79.         {
  80.           short bufval = (short)bufvar;
  81.           buffer = bufval / 100.0;
  82.         }
  83.       }
  84.       // Get the current UCS
  85.       CoordinateSystem3d ucs =
  86.         ed.CurrentUserCoordinateSystem.CoordinateSystem3d;
  87.       // Collect points on the component entities
  88.       Point3dCollection pts = new Point3dCollection();
  89.       Transaction tr =
  90.         db.TransactionManager.StartTransaction();
  91.       using (tr)
  92.       {
  93.         BlockTableRecord btr =
  94.           (BlockTableRecord)tr.GetObject(
  95.             db.CurrentSpaceId,
  96.             OpenMode.ForWrite
  97.           );
  98.         for (int i = 0; i < psr.Value.Count; i++)
  99.         {
  100.           Entity ent =
  101.             (Entity)tr.GetObject(
  102.               psr.Value[i].ObjectId,
  103.               OpenMode.ForRead
  104.             );
  105.           // Collect the points for each selected entity
  106.           Point3dCollection entPts = CollectPoints(tr, ent);
  107.           foreach (Point3d pt in entPts)
  108.           {
  109.             /*
  110.              * Create a DBPoint, for testing purposes
  111.              *
  112.             DBPoint dbp = new DBPoint(pt);
  113.             btr.AppendEntity(dbp);
  114.             tr.AddNewlyCreatedDBObject(dbp, true);
  115.              */
  116.             pts.Add(pt);
  117.           }
  118.           // Create a boundary for each entity (if so chosen) or
  119.           // just once after collecting all the points
  120.           if (oneBoundPerEnt || i == psr.Value.Count - 1)
  121.           {
  122.             try
  123.             {
  124.               Entity bnd =
  125.                 (circularBoundary ?
  126.                   CircleFromPoints(pts, ucs, buffer) :
  127.                   RectangleFromPoints(pts, ucs, buffer)
  128.                 );
  129.               btr.AppendEntity(bnd);
  130.               tr.AddNewlyCreatedDBObject(bnd, true);
  131.             }
  132.             catch
  133.             {
  134.               ed.WriteMessage(
  135.                 "\nUnable to calculate enclosing boundary."
  136.               );
  137.             }
  138.             pts.Clear();
  139.           }
  140.         }
  141.         tr.Commit();
  142.       }
  143.     }
  144.     private Point3dCollection CollectPoints(
  145.       Transaction tr, Entity ent
  146.     )
  147.     {
  148.       // The collection of points to populate and return
  149.       Point3dCollection pts = new Point3dCollection();
  150.       // We'll start by checking a block reference for
  151.       // attributes, getting their bounds and adding
  152.       // them to the point list. We'll still explode
  153.       // the BlockReference later, to gather points
  154.       // from other geometry, it's just that approach
  155.       // doesn't work for attributes (we only get the
  156.       // AttributeDefinitions, which don't have bounds)
  157.       BlockReference br = ent as BlockReference;
  158.       if (br != null)
  159.       {
  160.         foreach (ObjectId arId in br.AttributeCollection)
  161.         {
  162.           DBObject obj = tr.GetObject(arId, OpenMode.ForRead);
  163.           if (obj is AttributeReference)
  164.           {
  165.             AttributeReference ar = (AttributeReference)obj;
  166.             ExtractBounds(ar, pts);
  167.           }
  168.         }
  169.       }
  170.       // If we have a curve - other than a polyline, which
  171.       // we will want to explode - we'll get points along
  172.       // its length
  173.       Curve cur = ent as Curve;
  174.       if (cur != null &&
  175.           !(cur is Polyline ||
  176.             cur is Polyline2d ||
  177.             cur is Polyline3d))
  178.       {
  179.         // Two points are enough for a line, we'll go with
  180.         // a higher number for other curves
  181.         int segs = (ent is Line ? 2 : 20);
  182.         double param = cur.EndParam - cur.StartParam;
  183.         for (int i = 0; i < segs; i++)
  184.         {
  185.           try
  186.           {
  187.             Point3d pt =
  188.               cur.GetPointAtParameter(
  189.                 cur.StartParam + (i * param / (segs - 1))
  190.               );
  191.             pts.Add(pt);
  192.           }
  193.           catch { }
  194.         }
  195.       }
  196.       else if (ent is DBPoint)
  197.       {
  198.         // Points are easy
  199.         pts.Add(((DBPoint)ent).Position);
  200.       }
  201.       else if (ent is DBText)
  202.       {
  203.         // For DBText we use the same approach as
  204.         // for AttributeReferences
  205.         ExtractBounds((DBText)ent, pts);
  206.       }
  207.       else if (ent is MText)
  208.       {
  209.         // MText is also easy - you get all four corners
  210.         // returned by a function. That said, the points
  211.         // are of the MText's box, so may well be different
  212.         // from the bounds of the actual contents
  213.         MText txt = (MText)ent;
  214.         Point3dCollection pts2 = txt.GetBoundingPoints();
  215.         foreach (Point3d pt in pts2)
  216.         {
  217.           pts.Add(pt);
  218.         }
  219.       }
  220.       else if (ent is Face)
  221.       {
  222.         Face f = (Face)ent;
  223.         try
  224.         {
  225.           for (short i = 0; i < 4; i++)
  226.           {
  227.             pts.Add(f.GetVertexAt(i));
  228.           }
  229.         }
  230.         catch { }
  231.       }
  232.       else if (ent is Solid)
  233.       {
  234.         Solid sol = (Solid)ent;
  235.         try
  236.         {
  237.           for (short i = 0; i < 4; i++)
  238.           {
  239.             pts.Add(sol.GetPointAt(i));
  240.           }
  241.         }
  242.         catch { }
  243.       }
  244.       else
  245.       {
  246.         // Here's where we attempt to explode other types
  247.         // of object
  248.         DBObjectCollection oc = new DBObjectCollection();
  249.         try
  250.         {
  251.           ent.Explode(oc);
  252.           if (oc.Count > 0)
  253.           {
  254.             foreach (DBObject obj in oc)
  255.             {
  256.               Entity ent2 = obj as Entity;
  257.               if (ent2 != null && ent2.Visible)
  258.               {
  259.                 foreach (Point3d pt in CollectPoints(tr, ent2))
  260.                 {
  261.                   pts.Add(pt);
  262.                 }
  263.               }
  264.               obj.Dispose();
  265.             }
  266.           }
  267.         }
  268.         catch { }
  269.       }
  270.       return pts;
  271.     }
  272.     private void ExtractBounds(
  273.       DBText txt, Point3dCollection pts
  274.     )
  275.     {
  276.       // We have a special approach for DBText and
  277.       // AttributeReference objects, as we want to get
  278.       // all four corners of the bounding box, even
  279.       // when the text or the containing block reference
  280.       // is rotated
  281.       if (txt.Bounds.HasValue && txt.Visible)
  282.       {
  283.         // Create a straight version of the text object
  284.         // and copy across all the relevant properties
  285.         // (stopped copying AlignmentPoint, as it would
  286.         // sometimes cause an eNotApplicable error)
  287.         // We'll create the text at the WCS origin
  288.         // with no rotation, so it's easier to use its
  289.         // extents
  290.         DBText txt2 = new DBText();
  291.         txt2.Normal = Vector3d.ZAxis;
  292.         txt2.Position = Point3d.Origin;
  293.         // Other properties are copied from the original
  294.         txt2.TextString = txt.TextString;
  295.         txt2.TextStyleId = txt.TextStyleId;
  296.         txt2.LineWeight = txt.LineWeight;
  297.         txt2.Thickness = txt2.Thickness;
  298.         txt2.HorizontalMode = txt.HorizontalMode;
  299.         txt2.VerticalMode = txt.VerticalMode;
  300.         txt2.WidthFactor = txt.WidthFactor;
  301.         txt2.Height = txt.Height;
  302.         txt2.IsMirroredInX = txt2.IsMirroredInX;
  303.         txt2.IsMirroredInY = txt2.IsMirroredInY;
  304.         txt2.Oblique = txt.Oblique;
  305.         // Get its bounds if it has them defined
  306.         // (which it should, as the original did)
  307.         if (txt2.Bounds.HasValue)
  308.         {
  309.           Point3d maxPt = txt2.Bounds.Value.MaxPoint;
  310.           // Place all four corners of the bounding box
  311.           // in an array
  312.           Point2d[] bounds =
  313.             new Point2d[] {
  314.               Point2d.Origin,
  315.               new Point2d(0.0, maxPt.Y),
  316.               new Point2d(maxPt.X, maxPt.Y),
  317.               new Point2d(maxPt.X, 0.0)
  318.             };
  319.           // We're going to get each point's WCS coordinates
  320.           // using the plane the text is on
  321.           Plane pl = new Plane(txt.Position, txt.Normal);
  322.           // Rotate each point and add its WCS location to the
  323.           // collection
  324.           foreach (Point2d pt in bounds)
  325.           {
  326.             pts.Add(
  327.               pl.EvaluatePoint(
  328.                 pt.RotateBy(txt.Rotation, Point2d.Origin)
  329.               )
  330.             );
  331.           }
  332.         }
  333.       }
  334.     }
  335.     private Entity RectangleFromPoints(
  336.       Point3dCollection pts, CoordinateSystem3d ucs, double buffer
  337.     )
  338.     {
  339.       // Get the plane of the UCS
  340.       Plane pl = new Plane(ucs.Origin, ucs.Zaxis);
  341.       // We will project these (possibly 3D) points onto
  342.       // the plane of the current UCS, as that's where
  343.       // we will create our circle
  344.       // Project the points onto it
  345.       List<;Point2d> pts2d = new List<;Point2d>(pts.Count);
  346.       for (int i = 0; i < pts.Count; i++)
  347.       {
  348.         pts2d.Add(pl.ParameterOf(pts[i]));
  349.       }
  350.       // Assuming we have some points in our list...
  351.       if (pts.Count > 0)
  352.       {
  353.         // Set the initial min and max values from the first entry
  354.         double minX = pts2d[0].X,
  355.                maxX = minX,
  356.                minY = pts2d[0].Y,
  357.                maxY = minY;
  358.         // Perform a single iteration to extract the min/max X and Y
  359.         for (int i = 1; i < pts2d.Count; i++)
  360.         {
  361.           Point2d pt = pts2d[i];
  362.           if (pt.X < minX) minX = pt.X;
  363.           if (pt.X > maxX) maxX = pt.X;
  364.           if (pt.Y < minY) minY = pt.Y;
  365.           if (pt.Y > maxY) maxY = pt.Y;
  366.         }
  367.         // Our final buffer amount will be the percentage of the
  368.         // smallest of the dimensions
  369.         double buf =
  370.           Math.Min(maxX - minX, maxY - minY) * buffer;
  371.         // Apply the buffer to our point ordinates
  372.         minX -= buf;
  373.         minY -= buf;
  374.         maxX += buf;
  375.         maxY += buf;
  376.         // Create the boundary points
  377.         Point2d pt0 = new Point2d(minX, minY),
  378.                 pt1 = new Point2d(minX, maxY),
  379.                 pt2 = new Point2d(maxX, maxY),
  380.                 pt3 = new Point2d(maxX, minY);
  381.         // Finally we create the polyline
  382.         var p = new Polyline(4);
  383.         p.Normal = pl.Normal;
  384.         p.AddVertexAt(0, pt0, 0, 0, 0);
  385.         p.AddVertexAt(1, pt1, 0, 0, 0);
  386.         p.AddVertexAt(2, pt2, 0, 0, 0);
  387.         p.AddVertexAt(3, pt3, 0, 0, 0);
  388.         p.Closed = true;
  389.         return p;
  390.       }
  391.       return null;
  392.     }
  393.     private Entity CircleFromPoints(
  394.       Point3dCollection pts, CoordinateSystem3d ucs, double buffer
  395.     )
  396.     {
  397.       // Get the plane of the UCS
  398.       Plane pl = new Plane(ucs.Origin, ucs.Zaxis);
  399.       // We will project these (possibly 3D) points onto
  400.       // the plane of the current UCS, as that's where
  401.       // we will create our circle
  402.       // Project the points onto it
  403.       List<;Point2d> pts2d = new List<;Point2d>(pts.Count);
  404.       for (int i = 0; i < pts.Count; i++)
  405.       {
  406.         pts2d.Add(pl.ParameterOf(pts[i]));
  407.       }
  408.       // Assuming we have some points in our list...
  409.       if (pts.Count > 0)
  410.       {
  411.         // We need the center and radius of our circle
  412.         Point2d center;
  413.         double radius = 0;
  414.         // Use our fast approximation algorithm to
  415.         // calculate the center and radius of our
  416.         // circle to within 1% (calling the function
  417.         // with 100 iterations gives 10%, calling it
  418.         // with 10K gives 1%)
  419.         BadoiuClarksonIteration(
  420.           pts2d, 10000, out center, out radius
  421.         );
  422.         // Get our center point in WCS (on the plane
  423.         // of our UCS)
  424.         Point3d cen3d = pl.EvaluatePoint(center);
  425.         // Create the circle and add it to the drawing
  426.         return new Circle(
  427.           cen3d, ucs.Zaxis, radius * (1.0 + buffer)
  428.         );
  429.       }
  430.       return null;
  431.     }
  432.     // Algorithm courtesy (and copyright of) Frank Nielsen
  433.     // [url=http://blog.informationgeometry.org/article.php?id=164]http://blog.informationgeometry.org/article.php?id=164[/url]
  434.     public void BadoiuClarksonIteration(
  435.       List<;Point2d> set, int iter,
  436.       out Point2d cen, out double rad
  437.     )
  438.     {
  439.       // Choose any point of the set as the initial
  440.       // circumcenter
  441.       cen = set[0];
  442.       rad = 0;
  443.       for (int i = 0; i < iter; i++)
  444.       {
  445.         int winner = 0;
  446.         double distmax = (cen - set[0]).Length;
  447.         // Maximum distance point
  448.         for (int j = 1; j < set.Count; j++)
  449.         {
  450.           double dist = (cen - set[j]).Length;
  451.           if (dist > distmax)
  452.           {
  453.             winner = j;
  454.             distmax = dist;
  455.           }
  456.         }
  457.         rad = distmax;
  458.         // Update
  459.         cen =
  460.           new Point2d(
  461.             cen.X + (1.0 / (i + 1.0)) * (set[winner].X - cen.X),
  462.             cen.Y + (1.0 / (i + 1.0)) * (set[winner].Y - cen.Y)
  463.           );
  464.       }
  465.     }
  466.   }
  467. }
Here’s the MER command in action, using a 15% boundary and choosing to create individual boundaries for each object:
Rectangular boundaries around geometry
已领礼包: 859个
 楼主| 发表于 2014-5-15 10:27:27 | 显示全部楼层
Rectang 对 Spline 有误差
GMT+8, 2026-11-3 06:05 , Processed in 0.487949 second(s), 33 queries , Gzip On.
