查看: 2280|回复: 6
[他山之石] 切地形剖面图程序,望各位小东家园高手修改
发表于 2014-5-26 16:25:59 | 显示全部楼层 |阅读模式
  • jssc_none.gif (defun c:t24 (/ E1 PTS SS E PL PT DIST H MINH MAXH PTLST CURVELEN LOWERH P1 l zoomp)  (xdrx_begin)
  •   (xdrx_document_ucson)
  •   (setq e1 (car (xdrx_entsel "\n选择对象:" '((0 . "*line,arc")))))
  •   (setq pts (xdrx_getsamplept e1))
  •   (if (apply 'xdrx_isptoffscr pts)
  •     (progn
  •       (command "_zoom" "w" (apply 'mapcar (cons 'min pts)) (apply 'mapcar (cons 'max pts)) )
  •       (setq zoomp t)
  •   (setq ss (ssget "_F" pts '((0 . "*POLYLINE"))))
  •   (if zoomp (command "_zoom" "_p"))
  •   (xdrx_setsstodb ss 0)
  •   (xdrx_document_ucsoff)
  •   (while (setq e (xdrx_getentdata 0))
  •     (setq pl (append pl (xdrx_entity_OrthoPrjInterSectWith e1 e 0)))
  •   (setq pl
  •          (vl-sort
  •            pl
  •            (function
  •              (lambda (a b)
  •                (< (vlax-curve-getParamAtPoint e1 (VLAX-CURVE-GETCLOSESTPOINTTO e1 (car a)))
  •                   (vlax-curve-getParamAtPoint e1 (VLAX-CURVE-GETCLOSESTPOINTTO e1 (car b)))
  •    (setq pt (trans (getpoint "\n剖面图摆放位置:") 1 0))
  •   (foreach a pl
  •     (setq dist (vlax-curve-getDistAtPoint e1 (VLAX-CURVE-GETCLOSESTPOINTTO e1 (car a)))
  •           h (last (cadr a))
  •     (if (not minh)
  •       (setq minh h maxh h)
  •       (setq minh (min minh h)
  •             maxh (max maxh h)
  •     (setq ptlst (cons (list dist h 0) ptlst))
  •   (setq curvelen (vlax-curve-getDistAtParam e1 (vlax-curve-getEndParam e1)))
  •   (setq lowerh (- 10 (* 10 (fix (* minh 0.1)))))
  •   (setq ptlst (mapcar '(lambda (x) (mapcar '+ pt x (list 0 lowerh 0))) ptlst))
  •   (apply 'xdrx_line_make ptlst)
  •   (xdrx_line1 pt (setq p1 (polar pt 0 curvelen)))
  •   (xdrx_line1 pt (polar pt (* 0.5 pi) (+ (+ 20 (* 10 (fix (* 0.1 maxh)))) lowerh)))
  •   (xdrx_line1 p1 (polar p1 (* 0.5 pi) (+ (+ 20 (* 10 (fix (* 0.1 maxh)))) lowerh)))
  •   (entmake
  •   (list        '(0 . "TEXT")
  •         '(67 . 0)
  •         '(100
  •           "AcDbText"
  •         (cons 10 pt)
  •         (cons 40 2.0)
  •         (cons 1 (rtos (abs lowerh) 2 0))
  •         (cons 50 0)
  •         (cons 41 0.8)
  •         (cons 51 0)
  •         '(7 . "standard")
  •   (entmake
  •         '(67 . 0)
  •         '(100
  •           "AcDbText"
  •         (cons 10 p1)
  •         (cons 40 2.0)
  •         (cons 50 0)
  •         (cons 41 0.8)
  •         (cons 51 0)
  •         '(7 . "standard")
  •   (xdrx_end)
 楼主| 发表于 2014-5-26 21:53:03 | 显示全部楼层
杜流浪人 发表于 2014-5-26 21:13
自己去找晓东包装函数就可以了
什么意思 晓东包装函数在哪里?
回复 支持 0 反对 1
已领礼包: 1268个
发表于 2014-5-26 18:27:32 来自手机 | 显示全部楼层
需要改什么呢?
程序加载时有问题 提示没有定义  详情 回复 发表于 2014-5-26 20:03
 楼主| 发表于 2014-5-26 20:03:21 | 显示全部楼层
程序加载时有问题 提示没有定义
已领礼包: 1268个
发表于 2014-5-26 20:08:36 来自手机 | 显示全部楼层
加载   xdrxapi
加载 xdrxapi?如何加载它  详情 回复 发表于 2014-5-26 21:55
已领礼包: 720个
发表于 2014-5-26 21:13:57 | 显示全部楼层
自己去找晓东包装函数就可以了
什么意思 晓东包装函数在哪里?  详情 回复 发表于 2014-5-26 21:53
 楼主| 发表于 2014-5-26 21:55:24 | 显示全部楼层
加载   xdrxapi?如何加载它
GMT+8, 2026-11-6 12:17 , Processed in 0.477863 second(s), 53 queries , Gzip On.
