查看: 1956|回复: 1
[分享] AutoCAD.net: 求空间两曲线交点
已领礼包: 859个
发表于 2014-6-1 16:00:35 | 显示全部楼层 |阅读模式
引自:http://www.objectarx.net/bbs/archiver/?tid-410.html
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Text;
  4. using Autodesk.AutoCAD.ApplicationServices;
  5. using Autodesk.AutoCAD.Colors;
  6. using Autodesk.AutoCAD.DatabaseServices;
  7. using Autodesk.AutoCAD.EditorInput;
  8. using Autodesk.AutoCAD.Geometry;
  9. using Autodesk.AutoCAD.Runtime;
  10. using AsApp = Autodesk.AutoCAD.ApplicationServices.Application;
  11. using DsTM = Autodesk.AutoCAD.DatabaseServices.TransactionManager;
  12. using Autodesk.AutoCAD.GraphicsInterface;
  13. using Autodesk.AutoCAD.Interop;
  14. namespace ObjectArxNet.Test
  15. {
  16.     /**//// <summary>
  17.     /// 求空间两曲线交点
  18.     /// </summary>
  19.     public class Intersection
  20.     {
  21.         [CommandMethod("IntersectionTest")]
  22.         public void IntersectionTest()
  23.         {
  24.             Editor m_ed = Application.DocumentManager.MdiActiveDocument.Editor;
  25.             Database m_db = HostApplicationServices.WorkingDatabase;
  26.             PromptEntityOptions m_peo = new PromptEntityOptions("\n请选择第一条曲线:");
  27.             PromptEntityResult m_per = m_ed.GetEntity(m_peo);
  28.             if (m_per.Status != PromptStatus.OK) { return; }
  29.             ObjectId m_objid1 = m_per.ObjectId;
  30.             m_peo = new PromptEntityOptions("\n请选择第二条曲线:");
  31.             m_per = m_ed.GetEntity(m_peo);
  32.             if (m_per.Status != PromptStatus.OK) { return; }
  33.             ObjectId m_objid2 = m_per.ObjectId;
  34.             using (Transaction m_tr = m_db.TransactionManager.StartTransaction())
  35.             {
  36.                 Curve m_cur1 = (Curve)m_tr.GetObject(m_objid1, OpenMode.ForRead);
  37.                 Curve m_cur2 = (Curve)m_tr.GetObject(m_objid2, OpenMode.ForRead);
  38.                 Point3dCollection m_ints = new Point3dCollection();
  39.                 m_cur1.IntersectWith(m_cur2, Intersect.OnBothOperands, new Plane(), m_ints, 0, 0); //得出的所有交点在c1曲线上
  40.                 foreach (Point3d m_pt in m_ints)
  41.                 {
  42.                     m_ed.WriteMessage("\n第一条曲线与第二条曲线交点:{0}", m_pt);
  43.                 }
  44.                 m_ed.WriteMessage("\n===");
  45.                 m_ints.Clear();
  46.                 m_cur2.IntersectWith(m_cur1, Intersect.OnBothOperands, new Plane(), m_ints, 0, 0); //得出的所有交点在c2曲线上
  47.                 foreach (Point3d m_pt in m_ints)
  48.                 {
  49.                     m_ed.WriteMessage("\n第二条曲线与第条曲线一交点:{0}", m_pt);
  50.                 }
  51.                 m_tr.Commit();
  52.             }
  53.         }
  54.     }
  55. }
发表于 2020-6-11 15:26:53 | 显示全部楼层
学习了,谢谢!!!!!!
GMT+8, 2026-11-3 01:44 , Processed in 0.421747 second(s), 34 queries , Gzip On.
