查看: 1442|回复: 0
[分享] Add prefix and suffix to the text or mtext
已领礼包: 859个
发表于 2014-6-7 03:06:16 | 显示全部楼层 |阅读模式
        #region "Add prefix and suffix to the text or mtext multiply"
        [CommandMethod("PSUF")]
        public static void UpdateMultipleTexts()
            Database db = HostApplicationServices.WorkingDatabase;
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            Transaction tr = db.TransactionManager.StartTransaction();
            string pref = GetstringDflt(ed, "Enter a Prefix: ", "A-");
            string suff = GetstringDflt(ed, "Enter a Suffix: ", "-B");
            using (tr)
                try
                    Entity ent;
                    PromptEntityResult per;
                    ObjectId id;
                    do
                        PromptEntityOptions peo = new PromptEntityOptions("\nSelect Text >>");
                        peo.SetRejectMessage("\nMust be selected a Text or Mtext only!");
                        peo.AddAllowedClass(typeof(DBText),false);
                        peo.AddAllowedClass(typeof(MText),false);
                        per = ed.GetEntity(peo);
                        if (per.Status != PromptStatus.OK)
                            break;
                        id = per.ObjectId;
                        ent = id.GetObject(OpenMode.ForRead) as Entity;
                        ed.WriteMessage("\nObject Selected:\t{0}", ent.GetRXClass().DxfName);
                        if ((!(ent is DBText)) && (!(ent is MText)))
                            ed.WriteMessage("\nNot a Text or MText");
                            continue;
                        DBText txt= ent as DBText;
                        if (txt!= null)
                            txt.UpgradeOpen();
                            string text = txt.TextString;
                            txt.TextString = pref + text+ suff;
                            txt.DowngradeOpen();
                        MText mtxt = ent as MText;
                        if (mtxt != null)
                            mtxt.UpgradeOpen();
                            string text = mtxt.Contents;
                            mtxt.Contents = pref + text + suff;
                            mtxt.DowngradeOpen();
                        db.TransactionManager.QueueForGraphicsFlush();
                    while (per.Status == PromptStatus.OK);
                    tr.Commit();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    ed.WriteMessage("\n" + ex.StackTrace + "\n" + ex.Message);
        #region "Helpers"
        public static string GetstringDflt(Editor ed, string msg, string dflt)
            string answer = string.Empty;
            PromptStringOptions pso = new PromptStringOptions("\n" + msg);
            if (dflt != string.Empty)
                pso.DefaultValue = dflt;
            pso.AllowSpaces = true;
            PromptResult pr = ed.GetString(pso);
            if (pr.Status == PromptStatus.OK)
                answer = pr.StringResult;
            return answer;
        #endregion
        #endregion
GMT+8, 2026-11-3 01:50 , Processed in 0.712501 second(s), 34 queries , Gzip On.
