查看: 3957|回复: 3
[每日一码] 填充花纹面积求和程序
发表于 2014-6-10 15:48:35 | 显示全部楼层 |阅读模式
填充花纹的面积累加求和,不同于曲线面积求和,因为填充花纹有时直接查面积是查询不到的,如玫瑰花瓣甚至更复杂的填充等。
(defun c:tcmj ( / ss index txh ename obj el haif nn )
(vl-load-com)
(setq modelspace (vla-get-Modelspace (vla-get-activeDocument(vlax-get-acad-object))))
(setq ss (ssget))
(setq index 0 totalarea 0 nn 0)
(repeat (sslength ss)
   (setq ename (ssname ss index))
   (setq en (entget ename))
   (setq index (+ 1 index))
   (setq haif (strcase (cdr (assoc 0 en))))
   (if (= "HATCH" haif)
    (progn
      (setq nn (+ nn 1))
      (command "-hatchedit" ename "B" "P" "Y")    ; 根据重创边界求面积
      (setq el (entlast))
      (setq obj (vlax-ename->vla-object el))
      (setq at 0)
      (if (vlax-property-available-p obj "area")
       (setq at (vlax-get-property obj 'area))
      (if (< at 0.0001)                           ; 如果重创边界面积为0,直接求面域面积
        (progn
           (command "AREA" "O" ename)
           (setq at (getvar "AREA"))
      (setq totalarea (+ at totalarea))
      (entdel el)
) ; end repeat
(if (> nn 0)
  (progn
     (setq atext (strcat "\n总面积为: " (rtos totalarea 2 4) " 平方单位"))
     (princ atext)
  (princ "\n无有效的花纹填充对象,请重新选择")
(princ)
发表于 2014-6-10 20:50:08 | 显示全部楼层
学习,谢谢提供,正需要
发表于 2014-6-14 14:17:02 | 显示全部楼层
试了,没有效果,在这句上产生了问题:
“ (command "-hatchedit" ename "B" "P" "Y")    ; 根据重创边界求面积”
已领礼包: 1094个
发表于 2021-6-23 00:06:11 | 显示全部楼层
感谢分享填充花纹面积求和程序!
GMT+8, 2026-11-3 15:17 , Processed in 0.838037 second(s), 39 queries , Gzip On.
