查看: 2878|回复: 4
[分享] Offset Objects
已领礼包: 859个
发表于 2014-6-11 23:25:03 | 显示全部楼层 |阅读模式
public static class AlgerbraicArea
        public static double GetArea(Point2d pt1, Point2d pt2, Point2d pt3)
           return (((pt2.X - pt1.X) * (pt3.Y - pt1.Y)) -
                        ((pt3.X - pt1.X) * (pt2.Y - pt1.Y))) / 2.0;
        public static double GetArea(this CircularArc2d arc)
            double rad = arc.Radius;
            double ang = arc.IsClockWise ?
                arc.StartAngle - arc.EndAngle :
               arc.EndAngle - arc.StartAngle;
           return rad * rad * (ang - Math.Sin(ang)) / 2.0;
        public static double GetArea(this Polyline pline)
            CircularArc2d arc = new CircularArc2d();
            double area = 0.0;
            int last = pline.NumberOfVertices - 1;
            Point2d p0 = pline.GetPoint2dAt(0);
            if (pline.GetBulgeAt(0) != 0.0)
                area += pline.GetArcSegment2dAt(0).GetArea();
            for (int i = 1; i < last; i++)
                area += GetArea(p0, pline.GetPoint2dAt(i), pline.GetPoint2dAt(i + 1));
                if (pline.GetBulgeAt(i) != 0.0)
                    area += pline.GetArcSegment2dAt(i).GetArea(); ;
            if ((pline.GetBulgeAt(last) != 0.0) && pline.Closed)
               area += pline.GetArcSegment2dAt(last).GetArea();
            return area;
      [CommandMethod("OFIN")]
        public void OffsetInside()
            OffsetPolyline(true);
        [CommandMethod("OFOUT")]
        public void OffsetOutside()
            OffsetPolyline(false);
        private void OffsetPolyline(bool inside)
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptDistanceOptions pdo =
                new PromptDistanceOptions("\nSpecify the offset distance: ");
            pdo.AllowNegative = false;
            pdo.AllowZero = false;
            PromptDoubleResult pdr = ed.GetDistance(pdo);
            if (pdr.Status != PromptStatus.OK)
                return;
            double offsetDist = inside ? pdr.Value : -pdr.Value;
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect a polyline: ");
            peo.SetRejectMessage("Selected object is not a polyline.");
            peo.AddAllowedClass(typeof(Polyline), true);
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTableRecord btr =
                    (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                while (true)
                    PromptEntityResult per = ed.GetEntity(peo);
                    if (per.Status != PromptStatus.OK)
                        break;
                    Polyline pline = (Polyline)tr.GetObject(per.ObjectId, OpenMode.ForRead);
                    DBObjectCollection offsets =
                        pline.GetOffsetCurves(pline.GetArea() < 0.0 ? offsetDist : -offsetDist);
                    foreach (DBObject obj in offsets)
                        Entity ent = (Entity)obj;
                        btr.AppendEntity(ent);
                        tr.AddNewlyCreatedDBObject(ent, true);
                        db.TransactionManager.QueueForGraphicsFlush();
                tr.Commit();
已领礼包: 7个
发表于 2016-12-7 11:08:39 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
已领礼包: 12个
发表于 2017-12-17 20:39:42 | 显示全部楼层
感谢楼主分享!
发表于 2018-2-5 13:35:11 | 显示全部楼层
感谢,感谢,正好要写个这样的东西
发表于 2018-8-22 13:01:17 | 显示全部楼层
很好的偏移函数
GMT+8, 2026-11-3 00:12 , Processed in 0.458133 second(s), 36 queries , Gzip On.
