查看: 3058|回复: 0
[分享] Accessing extension dictionary of an overruled entity while dragging
发表于 2014-6-13 02:22:51 | 显示全部楼层 |阅读模式
By Balaji Ramamoorthy
When an entity that is being overruled is dragged, AutoCAD only creates a shallow copy of it. For this reason, the extension dictionary of the cloned entity is inaccessible from within the overrule class. One way to ensure that we get access to the extension dictionary is to drag the original entity and not its clone using the "TransformOverrule::CloneMeForDragging" and return false. Using this technique is not suggested as it is only meant for use with complex entities that can cause performance issues when cloned for dragging purposes.
The workaround is to override the "TransformOverrule::CloneMeForDragging" and continue to return "true" and use the original entity which is a parameter to this method to access the extension dictionary.
Here is a sample code to demonstrate this.
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.GraphicsInterface;
public class HelperClass
    const String _extDictName = "myExtDict";
    const String _XRecName = "myXRec";
    List<TypedValue> _data = new List<TypedValue>();
    public List<TypedValue> Data
        get { return _data; }
    private static HelperClass _instance;
    public String DictionaryName
        get { return _extDictName; }
    public String XRecordName
        get { return _XRecName; }
    protected HelperClass()
    public static HelperClass GetSingleton
        get
            if (_instance == null)
                _instance = new HelperClass();
            return _instance;
    public void CaptureXRecordData(DBObject obj)
        Xrecord xRec = null;
        ObjectId id = obj.ExtensionDictionary;
        _data.Clear();
        if (! id.IsValid)
            return;
        Database db
        = Application.DocumentManager.MdiActiveDocument.Database;
        using (Transaction tr
            = db.TransactionManager.StartOpenCloseTransaction())
            DBDictionary extDict = tr.GetObject(
                                    id,
                                    OpenMode.ForRead,
                                    false) as DBDictionary;
            if (extDict.Contains(DictionaryName))
                ObjectId dictId = extDict.GetAt(DictionaryName);
                DBDictionary myDict = tr.GetObject(
                                    dictId,
                                    OpenMode.ForRead,
                xRec = tr.GetObject(
                                    myDict.GetAt(XRecordName),
                                    OpenMode.ForRead,
                                    false) as Xrecord;
                if (xRec != null)
                    ResultBuffer rb = xRec.Data;
                    if (rb != null)
                        TypedValue[] tvArray = rb.AsArray();
                        foreach (TypedValue tv in tvArray)
                            _data.Add(
                                    new TypedValue(
                                                   tv.TypeCode,
                                                   tv.Value
                        rb.Dispose();
            tr.Commit();
public class MyCommands
    static CMyDrawableOverrule lineOverrule = null;
    static CMyTransformeOverrule transformOverrule = null;
    [CommandMethod("OT")]
    public void OverruleTest()
        Editor ed
        = Application.DocumentManager.MdiActiveDocument.Editor;
        PromptEntityResult per;
        per = ed.GetEntity("Pick a line to overrule");
        if(per.Status != PromptStatus.OK)
            return;
        Database db = HostApplicationServices.WorkingDatabase;
                    = db.TransactionManager.StartTransaction())
            Entity ent = (Entity)tr.GetObject(
                            per.ObjectId, OpenMode.ForWrite);
            RegAppTable regTable = (RegAppTable)tr.GetObject(
                    db.RegAppTableId, OpenMode.ForRead, false);
            if (!regTable.Has("TEST"))
                regTable.UpgradeOpen();
                RegAppTableRecord app = new RegAppTableRecord();
                app.Name = "TEST";
                regTable.Add(app);
                tr.AddNewlyCreatedDBObject(app, true);
            ent.XData = new ResultBuffer(
                                new TypedValue(1001, "TEST"),
                                new TypedValue(1070, 100));
            string extDictName = "myExtDict";
            string xRecName = "myXRec";
            if (ent.ExtensionDictionary == ObjectId.Null)
                ent.CreateExtensionDictionary();
            DBDictionary xDict = tr.GetObject(
                            ent.ExtensionDictionary,
                            OpenMode.ForWrite) as DBDictionary;
            xDict.TreatElementsAsHard = true;
            if (!xDict.Contains(extDictName))
                DBDictionary newDict = new DBDictionary();
                newDict.TreatElementsAsHard = true;
                xDict.SetAt(extDictName, newDict);
                tr.AddNewlyCreatedDBObject(newDict, true);
                Xrecord xRec = new Xrecord();
                xRec.Data = new ResultBuffer(
                            new TypedValue((int)DxfCode.Text,
                                            "Autodesk"));
                newDict.SetAt(xRecName, xRec);
                tr.AddNewlyCreatedDBObject(xRec, true);
            tr.Commit();
        if (lineOverrule == null)
            transformOverrule = new CMyTransformeOverrule();
            Overrule.AddOverrule(
                RXObject.GetClass(typeof(Line)),
                transformOverrule,
                true);
            transformOverrule.SetXDataFilter("TEST");
            lineOverrule = new CMyDrawableOverrule();
                lineOverrule,
                true);
            lineOverrule.SetXDataFilter("TEST");
            Overrule.Overruling = true;
        Application.DocumentManager.MdiActiveDocument.Editor.Regen();
public class CMyDrawableOverrule : DrawableOverrule
    [DllImport("acdb19.dll",
                CharSet = CharSet.Unicode,
                CallingConvention = CallingConvention.Cdecl,
                EntryPoint = "?fromAcDbTextStyle@@YA?AW4ErrorStatus@Acad@@AEAVAcGiTextStyle@@AEBVAcDbObjectId@@@Z")]
    private static extern Autodesk.AutoCAD.Runtime.ErrorStatus
        fromAcDbTextStyle(System.IntPtr style, ref ObjectId id);
    public override bool WorldDraw(Drawable drawable, WorldDraw wd)
        base.WorldDraw(drawable, wd);
        Line line = drawable as Line;
        if (line == null)
            return true;
        using (LineSegment3d seg = new LineSegment3d(
                    line.StartPoint, line.EndPoint))
            if (wd.IsDragging)
                wd.SubEntityTraits.Color = 1;
                // Retrieve the extension dictionary
                // values retrieved using helper class
                List<TypedValue> tvList
                       = HelperClass.GetSingleton.Data;
                foreach (TypedValue tv in tvList)
                    ObjectId textStyleId =
                    Application.DocumentManager.MdiActiveDocument.Database.Textstyle;
                    Autodesk.AutoCAD.GraphicsInterface.TextStyle iStyle
                    = new Autodesk.AutoCAD.GraphicsInterface.TextStyle();
                    if (fromAcDbTextStyle
                            iStyle.UnmanagedObject,
                            ref textStyleId
                        ) == Autodesk.AutoCAD.Runtime.ErrorStatus.OK)
                        wd.Geometry.Text(
                                        seg.MidPoint,
                                        line.Normal,
                                        Vector3d.XAxis,
                                        tv.Value.ToString(),
                                        true, iStyle);
            else
                wd.SubEntityTraits.Color = 2;
            wd.Geometry.Circle(seg.MidPoint,
                               seg.Length * 0.25,
                               line.Normal);
        return true;
public class CMyTransformeOverrule : TransformOverrule
    public override bool CloneMeForDragging(Entity entity)
        // Retrieve the extension dictionary from the original
        // entity. While dragging, the clone created is a
        //shallow clone and the extension dictionary isnt accessible
        HelperClass.GetSingleton.CaptureXRecordData(entity);
        // Permit cloning while dragging
        return true;
Here is a screenshot that displays the content of the extension dictionary while the entity is being dragged
ExtensionDictDuringDragging
GMT+8, 2026-11-22 08:34 , Processed in 0.364578 second(s), 11 queries , Gzip On, File On.
