查看: 2673|回复: 6
[求助] 偏移封闭
已领礼包: 79个
发表于 2014-9-22 09:27:06 | 显示全部楼层 |阅读模式
输入偏移距离,选直线,指定一个方向点,偏移封闭
(注意封闭的地方是垂直或水平线)
已领礼包: 344个
发表于 2014-9-22 10:01:17 | 显示全部楼层
这不是偏移,是相对水平方向或垂直方向复制后再封闭端口!
  1. (defun c:tt (/ e e1 p pt v)
  2.   (if (and
  3.   (setq e (entsel "\n选择曲线:"))
  4.   (setq p  (cadr e)
  5.         e  (car e)
  6.   )
  7.   (WCMATCH (cdr (assoc 0 (entget e))) "*LINE,ARC,ELLIPSE")
  8.       )
  9.     (progn
  10.       (setq p (vlax-curve-getclosestpointto e (trans p 1 0)))
  11.       (while (not (setq pt (getpoint "\n偏移位置点:"))))
  12.       (setq pt (trans pt 1 0))
  13.       (setq v (mapcar '- pt p))
  14.       (if (> (abs (car v)) (abs (cadr v)))
  15.   (setq pt (list (+ (car p) (car v)) (cadr p) 0))
  16.   (setq pt (list (car p) (+ (cadr p) (cadr v)) 0))
  17.       )
  18.       (command "_copy"
  19.          e
  20.          ""
  21.          "non"
  22.          (trans p 0 1)
  23.          "non"
  24.          (trans pt 0 1)
  25.       )
  26.       (setq e1 (entlast))
  27.       (command "line"
  28.          "non"
  29.          (trans (vlax-curve-getStartPoint e) 0 1)
  30.          "non"
  31.          (trans (vlax-curve-getStartPoint e1) 0 1)
  32.          ""
  33.       )
  34.       (command "line"
  35.          "non"
  36.          (trans (vlax-curve-getEndPoint e) 0 1)
  37.          "non"
  38.          (trans (vlax-curve-getEndPoint e1) 0 1)
  39.          ""
  40.       )
  41.     )
  42.   )
  43.   (princ)
  44. )
评分
参与人数 2D豆 +8 收起 理由
newer + 3 技术引导讨论和指点奖!
zhuizhu + 5 技术引导讨论和指点奖!
查看全部评分
已领礼包: 1268个
发表于 2014-9-22 10:14:44 | 显示全部楼层
  1. (defun c:tt (/ ss d)
  2.   (if (and (setq ss (ssget '((0 . "line"))))
  3.            (setq d (getdist "\nOffset dist: "))
  4.       )
  5.     (progn
  6.       (setq _pi2 (/ pi 2)
  7.             _3pi (* 1.5 pi)
  8.       )
  9.       (mapcar '(lambda (ln / an sp ep dis pts)
  10.                  (setq an (xdrx_getpropertyvalue ln "angle")
  11.                        sp (xdrx_curve_getstartpoint ln)
  12.                        ep (xdrx_curve_getendpoint ln)
  13.                  )
  14.                  (if (or (<= (* 0.25 pi) an (* 0.75 PI))
  15.                          (<= (* 1.25 pi) an (* 1.75 PI))
  16.                      )
  17.                    (setq dis (/ d (sin an))
  18.                          pts (list (polar sp 0. dis)
  19.                                    (polar ep 0. dis)
  20.                                    (polar ep pi dis)
  21.                                    (polar sp pi dis)
  22.                              )
  23.                    )
  24.                    (setq dis (/ d (cos an))
  25.                          pts (list (polar sp _pi2 dis)
  26.                                    (polar ep _pi2 dis)
  27.                                    (polar ep _3pi dis)
  28.                                    (polar sp _3pi dis)
  29.                              )
  30.                    )
  31.                  )
  32.                  (apply 'xdrx_polyline_make (cons t pts))
  33.                )
  34.       )
  35.       (xdrx_pickset->ents ss)
  36.     )
  37.   )
  38.   (princ)
  39. )
为什么里面有的用了XDRX,有的曲线用了vlax-curve-xxx,XDRX API里面不也有CURVE相关的函数吗?  详情 回复 发表于 2014-9-22 10:27
评分
参与人数 2D豆 +6 收起 理由
zhuizhu + 3 技术引导讨论和指点奖!
查看全部评分
发表于 2014-9-22 10:27:11 | 显示全部楼层
已领礼包: 1268个
发表于 2014-9-22 10:59:36 | 显示全部楼层
应该用相同的函数,这样才能保证精度一致,已修改
发表于 2017-6-29 16:02:49 | 显示全部楼层
我来测试一下,行不行。。。。
已领礼包: 155个
发表于 2019-9-11 22:58:00 | 显示全部楼层
牢固大哥,能把源码改下吗,设置下偏移距离
GMT+8, 2026-11-5 10:56 , Processed in 0.415974 second(s), 49 queries , Gzip On.
