查看: 3257|回复: 3
[文档类] (XD::Doc:GetFence)获取 Fence 栏选点
发表于 2014-10-30 02:41:19 | 显示全部楼层 |阅读模式
函数发布
函数名称: XD::Doc:GetFence
调用格式: (XD::Doc:GetFence info1 info2 col)
参数说明: info1 --- 第一点提示 or nil
info2 --- 第二点及以后点提示or nil
col --- 虚线颜色 or nil
返回值: 点表(UCS)
函数简介: 获取 Frence 点
函数来源: 原创
函数作者:
适用版本: XDRX API
最后更新时间: 2014-11-04
备注: 鼠标最后点碰到起点利用点监视器技术自动关闭
演示图片: -
  1. (defun XD::Doc:GetFence        (info1            info2      col          /
  2.                          _pnt:projectOnAxis    myerr          _grdraw
  3.                          callback   ret               ptl          tf
  4.                          tf1            fuzz       con
  5.                         )
  6.   (defun _pnt:projectOnAxis (bp p /)
  7.     (if        (zerop (getvar "orthomode"))
  8.       p
  9.       (if (or (< (* pi 0.25) (angle bp p) (* 0.75 pi))
  10.               (< (* pi 1.25) (angle bp p) (* 1.75 pi))
  11.           )
  12.         (list (car bp) (cadr p) 0.)
  13.         (list (car p) (cadr bp) 0.)
  14.       )
  15.     )
  16.   )
  17.   (defun myerr (msg)
  18.     (princ "\n*cancel*")
  19.     (xdrx_sysvar_pop)
  20.     (xdrx_pointmonitor)
  21.     (redraw)
  22.     (princ)
  23.   )
  24.   (defun _grdraw (pts /)
  25.     (if        (>= (length pts) 2)
  26.       (progn
  27.         (redraw)
  28.         (apply 'xdrx_grdraw (cons col (cons con pts)))
  29.       )
  30.     )
  31.   )
  32.   (defun callback (p / ll)
  33.     (if        ptl
  34.       (progn
  35.         (_grdraw
  36.           (cons
  37.             (trans (_pnt:projectOnAxis (car ptl) (trans p 0 1))
  38.                    1
  39.                    0
  40.             )
  41.             (mapcar '(lambda (x) (trans x 1 0)) ptl)
  42.           )
  43.         )
  44.         (if (and (> (length ptl) 1)
  45.                  (equal (trans p 0 1) (last ptl) fuzz)
  46.             )
  47.           (xdrx_document_sendCmdStr "\n")
  48.         )
  49.       )
  50.     )
  51.   )
  52.   ;;main
  53.   (setq        olderr        *error*
  54.         *error*        myerr
  55.         tf        t
  56.         tf1        t
  57.         fuzz        (XD::Doc:GetPickBoxHeight)
  58.   )
  59.   (if (not col)
  60.     (setq col 1)
  61.   )
  62.   (if (minusp col)
  63.     (setq con 0
  64.           col (abs col)
  65.     )
  66.     (setq con 1)
  67.   )
  68.   (xdrx_pointmonitor "callback")
  69.   (xdrx_sysvar_push '("orthomode" 0) '("apbox" 1))
  70.   (while (and tf
  71.               (progn
  72.                 (initget 128 "U")
  73.                 (setq ret (getpoint (if        tf1
  74.                                       (if info1
  75.                                         (strcat "\n" info1 "<退出>: ")
  76.                                         "\r第一点<退出>: "
  77.                                       )
  78.                                       (if info2
  79.                                         (strcat "\r" info2 "[回退(U)]: ")
  80.                                         "\n下一点[回退(U)]: "
  81.                                       )
  82.                                     )
  83.                           )
  84.                 )
  85.                 (cond
  86.                   ((= ret "U")
  87.                    (if (> (length ptl) 1)
  88.                      (setq ret (cadr ptl)
  89.                            ptl (cddr ptl)
  90.                      )
  91.                    )
  92.                   )
  93.                   ((= (type ret) 'LIST)
  94.                    ret
  95.                   )
  96.                   (t nil)
  97.                 )
  98.               )
  99.          )
  100.     (setq tf1 nil)
  101.     (if        (and ptl (equal ret (last ptl) fuzz))
  102.       (setq tf nil)
  103.     )
  104.     (if        ptl
  105.       (setq ptl (cons (_pnt:projectOnAxis (car ptl) ret) ptl))
  106.       (setq ptl (cons ret ptl))
  107.     )
  108.   )
  109.   (setq *error* olderr)
  110.   (xdrx_sysvar_pop)
  111.   (xdrx_pointmonitor)
  112.   (redraw)
  113.   (if (not tf)
  114.     (reverse (cdr ptl))
  115.     (reverse ptl)
  116.   )
  117. )
发表于 2014-10-30 08:29:19 | 显示全部楼层
好函数,正想写个东西要用到。{:soso_e179:}
 楼主| 发表于 2014-11-4 16:03:22 | 显示全部楼层
更新
1 支持 实显或虚显
2 支持回退
发表于 2015-2-23 17:55:42 | 显示全部楼层
好函数,正想写个东西要用到;P;P
GMT+8, 2026-11-22 09:00 , Processed in 0.295444 second(s), 16 queries , Gzip On, File On.
