查看: 6788|回复: 17
[求助] 请教TextBox如何在SetFocus时,让焦点自动跳到行末
发表于 2014-12-6 21:49:40 | 显示全部楼层 |阅读模式
请教TextBox如何在SetFocus时,让焦点自动跳到行末,也就是有两个TextBox,当setfocus textbox2时,里面有字"12"程序默认将焦点设置在"1"前面,请问如何将其设置在"2"后面,谢谢
发表于 2014-12-6 21:56:21 | 显示全部楼层
Function Name dcl-TextBox-SetSel
Syntax   (dcl-TextBox-SetSel ÎÞ±êÌâ/Form1/TextBox1 Start [as Long] End [as Long] {NoScroll [as Boolean]})
Return Type Boolean (T if successful; otherwise NIL)
Applies To Text Box
This method selects a range of characters in the edit box. Start and End are the character positions (zero based), respectively, of the first selected character and the character following the last selected character. If Start is -1, all selections are removed. If End is -1, all characters from Start to the last character in the edit box are selected. The replacement text is automatically scrolled into view unless NoScroll is T.
发表于 2014-12-6 21:57:13 | 显示全部楼层
Function Name
dcl-TextBox-SetSel
Syntax
(dcl-TextBox-SetSel xxx/Form1/TextBox1 Start [as Long] End [as Long] {NoScroll [as Boolean]})
Return Type
Applies To
Text Box
谢谢了,是setsel函数,还有请问下要在textbox中多行输入,应该进行什么处理呢?试了很多方法不行  详情 回复 发表于 2014-12-7 09:15
谢谢,昨天可能是刷新的问题,未看到您的回复,我试试  发表于 2014-12-7 08:50
发表于 2014-12-6 21:57:27 | 显示全部楼层
试试:dcl-Control-SetPos
Function Name
dcl-Control-SetPos
Syntax
(dcl-Control-SetPos ÎT±êìa/Form1/TextBox1 Left [as Long] Top [as Long] {Width [as Long]} {Height [as Long]})
Return Type
Applies To
All Controls and Forms
This method sets the position and size of a form or control. If the control is a child window, the specified coordinates are relative to the upper left corner of the parent window's client area; otherwise they are screen coordinates. If the optional Width and Height arguments are omitted, the control's size will remain unchanged. Both Width and Height must be greater than zero.
谢谢,实验了一下,仿似不对,这个函数应该是控制控件的位置  详情 回复 发表于 2014-12-6 22:12
 楼主| 发表于 2014-12-6 22:12:15 | 显示全部楼层
是的,看错了,不好意思。你试试ST的方法,setsel后,在清除,看看光标是在最后不?  详情 回复 发表于 2014-12-6 22:17
发表于 2014-12-6 22:17:25 | 显示全部楼层
谢谢,辛苦了,我明天试试。  发表于 2014-12-6 22:18
 楼主| 发表于 2014-12-7 09:15:45 | 显示全部楼层
st788796 发表于 2014-12-6 21:57
This method selects a range of characters in the edit box. Start and End are the character positions ...
你用setsel函数怎么写的,把代码贴出来吧。  详情 回复 发表于 2014-12-7 12:10
发表于 2014-12-7 09:28:33 | 显示全部楼层
没有多行,启用垂直滚动条
启用了垂直滚动条,它不换行  详情 回复 发表于 2014-12-7 09:34
 楼主| 发表于 2014-12-7 09:34:06 | 显示全部楼层
st788796 发表于 2014-12-7 09:28
没有多行,启用垂直滚动条
启用了垂直滚动条,它不换行
 楼主| 发表于 2014-12-7 09:52:37 | 显示全部楼层
filter style设置成multiline string,这个要回车,不回车碰到边就换行可以在EditChanged事件中加入\r\n
发表于 2014-12-7 12:10:18 | 显示全部楼层
我只有一个字符,写成(dcl-TextBox-SetSel file/Form/TextBoxn1 1)就行了  详情 回复 发表于 2014-12-7 14:14
 楼主| 发表于 2014-12-7 14:14:42 | 显示全部楼层
发表于 2014-12-7 17:59:19 来自手机 | 显示全部楼层
不明白你为什么捉摸这些?像输注册码一样自动跳?
类似于文字自动排版,实际上很简单的功能,想让其自动化。 [attachimg]11930[/attachimg]  详情 回复 发表于 2014-12-7 20:23
 楼主| 发表于 2014-12-7 20:23:25 | 显示全部楼层
GMT+8, 2026-11-22 08:58 , Processed in 0.354177 second(s), 35 queries , Gzip On, File On.
