查看: 8999|回复: 34
[每日一码] 转换3DFACE到POLYLINE
发表于 2014-12-6 22:11:33 | 显示全部楼层 |阅读模式
Converting 3dface to a polyline
Issue
How do I convert 3dFaces to polylines ?
Solution
There's no mechanism available to do this directly. What you'll need to do is
collect the 3dFace vertex data, and create a polyline using that information.
Since a 3dFace will probably be construced with differing X,Y, and Z coordinates
you can only re-create them as a 3dPolyline. If the face's Z coordinates are on
the same elevation, you could re-create them as a 2d polyline. Here's some lisp
code to demonstrate this:
游客,如果您要查看本帖隐藏内容请回复
评分
参与人数 1D豆 +5 收起 理由
牢固 + 5 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2014-12-6 22:29:46 | 显示全部楼层
辛苦了,因为你们有更多的人进步
已领礼包: 4044个
发表于 2014-12-6 22:54:56 | 显示全部楼层
回复看看!:lol
发表于 2014-12-6 23:21:22 | 显示全部楼层
还有更简单的?
  1. (defun c:tt ()
  2.   (fy:begin)
  3.   (if (ssget '((0 . "3dface")))
  4.     (progn (mapcar '(lambda (x)
  5.                       (vlax-put        (vlax-invoke
  6.                                   (fy:acspace)
  7.                                   'Add3dPoly
  8.                                   (vlax-get x 'Coordinates)
  9.                                 )
  10.                                 "Closed"
  11.                                 :vlax-true
  12.                       )
  13.                     )
  14.                    (fy:cset->objs)
  15.            )
  16.            (vl-cmdf ".erase" "P" "")
  17.     )
  18.   )
  19.   (princ)
  20. )
已领礼包: 344个
发表于 2014-12-6 23:40:07 | 显示全部楼层
代码还应考虑下ucs和捕捉的问题!
(command "3DPOLY" "non" (trans pt1 0 1) "non" (trans pt2 0 1) "non" (trans pt3 0 1))
已领礼包: 33个
发表于 2014-12-7 06:54:17 | 显示全部楼层
xuexi Le
已领礼包: 2476个
发表于 2014-12-7 07:52:55 | 显示全部楼层
看看什么方法....
已领礼包: 720个
发表于 2014-12-7 11:46:12 | 显示全部楼层
学习了
已领礼包: 2965个
财富等级: 家财万贯
发表于 2014-12-7 12:22:37 | 显示全部楼层
看看学习一下
已领礼包: 394个
发表于 2014-12-7 12:46:35 | 显示全部楼层
3d线转pline?
已领礼包: 2226个
发表于 2014-12-8 00:08:28 | 显示全部楼层
回复看看!
发表于 2014-12-25 14:34:28 | 显示全部楼层
谢谢分享~~~
发表于 2015-3-24 22:00:53 | 显示全部楼层
这东西不错
发表于 2015-3-25 12:59:02 | 显示全部楼层
学习学习学习学习学习学习
已领礼包: 2759个
财富等级: 家财万贯
发表于 2015-3-26 09:44:47 | 显示全部楼层
学习!!!!!!!!!!!!!!!!!!!!!
GMT+8, 2026-11-2 04:58 , Processed in 0.533285 second(s), 58 queries , Gzip On.
