查看: 2535|回复: 4
[分享] OpenDCL 8.0.010 new Lisp API functions
发表于 2014-12-6 22:48:15 | 显示全部楼层 |阅读模式
Alpha 10 includes new Lisp API functions for managing the project picture folder and control image lists, support for dropping files into the image list and picture folder dialogs, and some control background color fixes.
New API functions are documented in English only. They are:
(dcl-Project-GetPictures)
(dcl-Project-SetPicture)
(dcl-ImageList-GetCount)
(dcl-ImageList-GetSize)
(dcl-ImageList-SetAt)
Function Name
Syntax
(dcl-Project-GetPictures <PROJECT> {Password [as String]})
Return Type
List of PictureIDs
This method returns a list of all pictures in the specified project's picture folder. If the project has a password, the optional Password argument must be supplied, and it must match the project's password or the function will fail.
Function Name
Syntax
(dcl-Project-SetPicture <PROJECT> {Password [as String]} Picture [as PictureID] Filename [as String])
Return Type
Boolean (T if successful; otherwise NIL)
This function adds, replaces, or deletes the specified picture from the project's picture folder. If the project has a password, the optional Password argument must be supplied, and it must match the project's password or the function will fail. If Filename is NIL, the picture is deleted.
Function Name
Syntax
(dcl-ImageList-GetCount ImageList [as Image List])
Return Type
Long
This method returns the number of images in the image list.
Function Name
Syntax
(dcl-ImageList-GetSize ImageList [as Image List])
Return Type
List of (Width [as Long] Height [as Long])
This function returns the size (in pixels) of images in the image list. If no size has been set, -1 will be returned for both width and height.
Function Name
dcl-ImageList-SetAt
Syntax
(dcl-ImageList-SetAt ImageList [as Image List] ImageIndex [as Integer] Filename [as String] {Width [as Long] Height [as Long]})
Return Type
Integer (new or deleted image index on success, NIL on failure)
This function adds, replaces, or deletes the image at ImageIndex. The first image is always at index zero. When adding images, an ImageIndex of -1 appends the image to the end of the list. If Filename is NIL, the image is deleted. The optional Width and Height image dimensions may be specified when adding the first image to an empty image list. If image dimensions are specified, the first added image is scaled to the specified dimensions. Subsequent images are always scaled to the same dimensions as the first image. If the Width and Height values are specified for subsequent images, they must match the image list image size or the function will fail.
发表于 2014-12-6 22:51:54 | 显示全部楼层
10出来了啊,下载地址给转帖过来吧。
 楼主| 发表于 2014-12-6 23:06:05 | 显示全部楼层
发表于 2014-12-7 18:01:47 来自手机 | 显示全部楼层
这几个函数可以不把图片先行加入odcl了?
是不是下步直接解析dll资源文件?
发表于 2015-7-3 08:35:50 | 显示全部楼层
不错啊,学习中。。。。。。。。。。。。。。。
GMT+8, 2026-11-22 08:54 , Processed in 0.240402 second(s), 16 queries , Gzip On, File On.
