查看: 20563|回复: 82
[每日一码] (7)在ARX里模拟INSERT命令实现代码替代acedCommand调用的解决方案
 火 [复制链接]
发表于 2014-12-7 12:23:55 | 显示全部楼层 |阅读模式
How to mimic the AutoCAD insert command in ARX without acedCommand call
Issue
How do I mimic the AutoCAD INSERT command in ARX without an acedCommand() call?
Solution
This operation needs to be divided into two different steps. The first step is to have an AcDbBlockTableRecord, which contains the block definition. You could either create, edit an existing one, or import it from another drawing file. The following example shows how to import a block definition from an external drawing file:
游客,如果您要查看本帖隐藏内容请回复
发表于 2014-12-7 16:41:41 | 显示全部楼层
回复,看看!
发表于 2014-12-7 21:49:57 | 显示全部楼层
看看学习!
发表于 2014-12-9 17:29:50 | 显示全部楼层
知识只有传授给别人才是知识{:soso_e179:}
发表于 2015-2-1 22:53:11 | 显示全部楼层
发表于 2015-2-1 23:41:53 来自手机 | 显示全部楼层
哈哈~我来也~~~
发表于 2015-2-2 16:22:33 | 显示全部楼层
大量回复学习
发表于 2015-5-10 15:28:02 | 显示全部楼层
发表于 2015-5-26 16:19:35 | 显示全部楼层
:Q:Q:Q:Q:Q:Q:Q:curse::curse::curse::curse::curse::curse::curse::loveliness::loveliness::loveliness::loveliness:
发表于 2015-5-26 22:51:54 | 显示全部楼层
啥好东西!!!!!!!!!!!!
发表于 2015-11-21 15:56:25 | 显示全部楼层
学习下 我主要还是想看看 属性图块是怎么处理的
发表于 2015-11-21 17:07:09 | 显示全部楼层
是不是用了gr函数
发表于 2015-11-24 17:23:20 | 显示全部楼层
看看,学学
发表于 2016-3-19 16:49:07 | 显示全部楼层
ffffffffffffffffffffffffffffffffffffffffffffffff
发表于 2016-3-22 10:10:12 | 显示全部楼层
GMT+8, 2026-11-22 07:19 , Processed in 0.276556 second(s), 36 queries , Gzip On, File On.
