楼主: XDSoft
[每日一码] (7)在ARX里模拟INSERT命令实现代码替代acedCommand调用的解决方案
 火 [复制链接]
发表于 2018-1-4 11:15:22 | 显示全部楼层
看看看看看看看看看看
发表于 2018-7-11 10:43:52 | 显示全部楼层
发表于 2018-7-17 09:16:57 | 显示全部楼层
仄仄仄仄仄仄仄仄
发表于 2018-7-18 23:43:53 来自手机 | 显示全部楼层
看看是啥好东西
发表于 2018-10-9 12:29:28 | 显示全部楼层
回复看看
发表于 2018-10-19 16:58:08 | 显示全部楼层
参考下!!!!
发表于 2018-11-8 11:53:40 | 显示全部楼层
学习ARX 努力
发表于 2018-11-8 15:20:02 | 显示全部楼层
学习一下
发表于 2018-11-15 09:08:48 | 显示全部楼层
回复查看隐藏内容
发表于 2019-1-17 10:43:03 | 显示全部楼层
发表于 2019-2-18 17:00:02 | 显示全部楼层
需要回复看看
发表于 2019-5-19 21:42:06 | 显示全部楼层
谢谢楼主分享
发表于 2019-5-20 12:53:57 | 显示全部楼层
这个代码实际上有一句算是bug,希望后面的人避免,
  1.    pAtt->setPropertiesFrom (pAttdef) ;
这句是获取属性定义的一般特性,图层,颜色等等。
实际上属性块不应该使用这个方式,因为在动态块带有属性的时候,就会出问题。
我们应该使用 setAttributeFromBlock 来获取属性定义pAttdef的特性,这个至少在2002开始就有这样的成员函数,我们认为这个才是正确。
AcDbAttribute::setAttributeFromBlock Function
  1. Acad::ErrorStatus
  2. setAttributeFromBlock(
  3. const AcDbAttributeDefinition * pAttdef,
  4. const AcGeMatrix3d& blkXform);
  5. pAttdef Pointer to the attribute definition entity to be used as a data template
  6. blkXform Pointer to the block transformation matrix as returned by the AcDbBlockReference::blockTransform() method of the blockReference that will be the owner of the attribute.
  7. Uses pAttdef as a template for the attributes textual, entity, and starting geometric properties (in other words, it copies this information from the attribute definition into the attribute). It then applies blkXform to transform the position, sizing, and obliquing as would be done by the INSERT command.
  8. The end result is the same as would occur when using the INSERT command. Returns Acad::eOk if successful.
  9. --------------------------------------------------------------------------------
  10. Acad::ErrorStatus
  11. setAttributeFromBlock(
  12. const AcGeMatrix3d& blkXform);
  13. blkXform Pointer to the block transformation matrix as returned by the AcDbBlockReference::blockTransform() method of the blockReference that will be the owner of the attribute.
  14. Applies blkXform to the attribute's geometric data to transform the position, sizing, and obliquing as would be done by the INSERT command. The attribute's textual and entity properties data is left alone. Returns Acad::eOk if successful.
发表于 2019-6-28 09:50:14 | 显示全部楼层
我要看我要看我要看我要看我要看我要看
发表于 2019-7-24 09:06:16 | 显示全部楼层
学习了!!!!!!!!!
GMT+8, 2026-11-22 07:38 , Processed in 0.446903 second(s), 35 queries , Gzip On, File On.
