查看: 1788|回复: 1
ObjectARX Technical Newsletter - September 1999
已领礼包: 145个
发表于 2002-1-7 02:20:06 | 显示全部楼层 |阅读模式
This document is part of    ObjectARX Newsletter Archive
Dear ObjectARX Developer,
AutoCAD ObjectARX Technical Info
/Note: the URLs in this posting may be broken into several lines by the
transmission media. Please make sure that you have the full URL before
trying to access it./
Table of Contents
(1) ObjectARX Logo Program
(2) New Solutions
(3) Check out our samples for ObjectARX developer
The ObjectARX Logo certification can sounds like a marketing argument. But
the reality is different. The ObjectARX Logo certification indicates how a
developer should implement his application to make sure his ObjectARX
application will run properly in AutoCAD without interfering with any other
third party developer application or definition.
A complete description of all the technical issues, their solution, and a
test toolkit is available for free at the following URL:
http://www.veritest.com/autodesk/
Also the ObjectARX 2000 Wizard has been designed to support these issues.
The Wizard can be downloaded from the ADN WEB site at:
http://adn.autodesk.com/techsupp/utilitieswizards.htm
Finally, you can find samples and solutions on that subject on the ADN WEB
site:
http://adn.autodesk.com/techsupp/utilitiessamples.htm
4675  Demand Loading Logo compliance
/cgi-bin/solution.pl?SID=4675
13619 Reusing custom object class into another ARX module
/cgi-bin/solution.pl?SID=13619
26695 Changing ARX class information for ObjectARX Logo certified
application
/cgi-bin/solution.pl?SID=26695
(2) New Solutions
36613 How to insert multiple block definitions with an AcEdJig
/cgi-bin/solution.pl?SID=36613
39233 RegisterAppNotMdiAware prevents toolbars from showing their buttons
/cgi-bin/solution.pl?SID=39233
40154 AcDbPolyline derived objects cannot save proxy graphics
/cgi-bin/solution.pl?SID=40154
40957 Why the Wizard generated code omits __declspec(dllimport)
/cgi-bin/solution.pl?SID=40957
41693 How to set plot configuration to "NONE"
/cgi-bin/solution.pl?SID=41693
42186 Missing documentation on AcEdInputPointFilter::processInputPoint()
/cgi-bin/solution.pl?SID=42186
42340 Getting an entity's linetype if ByLayer
/cgi-bin/solution.pl?SID=42340
In addition to this ObjectARX CD samples, we have a collection of samples
published on the ADN WEB site that you may find useful.
AutoCAD samples are available at:
You can also find ObjectARX CD samples which have been revised and updated
at:
To subscribe or unsubscribe, go to
http://adn.autodesk.com/techsupp/docs/newsletters.htm
     You received this message as a result of your registration
     on the ADN List Server subscription page.  If you no longer wish
     to receive these messages, read the next section, How to use this
     mailing list.
     How to use this mailing list:
     You may unsubscribe from this e-mail newsletter, or subscribe to
     a variety of other informative e-mail newsletters, by returning
     to the ADN List Server subscription page at
     and changing your subscription preferences.
     Alternatively, from the subscribed account you can send an e-mail to
     <Majordomo-partnersys@autodesk.com> with the following command in the
     body of your email message:
     unsubscribe <list-name>
     Autodesk Developer Network (ADN) information and events:
     For information on all ADN topics, please visit:
       http://www.autodesk.com/adn
     THIS DOCUMENT IS PROVIDED FOR INFORMATIONAL PURPOSES ONLY.  The
     information contained in this document represents the current view of
     Autodesk Inc. on the issues discussed as of the date of publication.
     Because Autodesk must respond to change in market conditions, it
     should not be interpreted to be a commitment on the part of Autodesk
     and Autodesk cannot guarantee the accuracy of any information
     presented after the date of publication.
     INFORMATION PROVIDED IN THIS DOCUMENT IS PROVIDED 'AS IS' WITHOUT
     WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING BUT NOT
     LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
     PARTICULAR PURPOSE AND FREEDOM FROM INFRINGEMENT.
     The user assumes the entire risk as to the accuracy and the use of
     this document. This  document may be copied and distributed subject to
     the following conditions:
     1.   All text must be copied without modification and all pages must
          be included
     2.   All copies must contain Autodesk's copyright notice and any other
          notices provided therein
     3.   This document may not be distributed for profit
发表于 2005-1-21 14:13:42 | 显示全部楼层
请问楼主:
以上地址要求输入用户名和密码,不知该如何申请或注册用户?
该地址目前还有效吗?
先谢了!
GMT+8, 2026-11-6 06:08 , Processed in 0.471527 second(s), 34 queries , Gzip On.
