查看: 11890|回复: 39
[分享] 使用ObjectARX插入图片
发表于 2016-1-24 16:31:14 | 显示全部楼层 |阅读模式
Inside ObjectARX, there are two classes that we use to represent images, one is AcDbRasterImage and the other is AcDbRasterImageDef.
The AcDbRasterImage entity (image entity) works with theAcDbRasterImageDef object (image definition object) to implement rasterimages inside AutoCAD. The relationship between these two classes is much likethe relationship between an AutoCAD block definition object and a block insert entity.
The image entity is a drawable, selectable AutoCAD entity that places a rasterimage in model or ** space at a particular location and orientation. The image entity is linked to exactly one image definition object, to which it sends requests for image processing operations needed for displaying and plotting images. Because the image definition object manages all the image information he image entity is relatively small. Besides the image location and orientation, it contains a clip boundary, image fade, contrast and brightness parameters and other typical AcDbEntity properties like layer and color.
void InsertImage()
    ACHAR* szName = _T(“MyTest”);
    ACHAR *fileName = _T(“C:\temp\newImage.jpeg”);
    AcGePoint3d org(10,10,0);
    AcDbDatabase *pDb =
      acdbHostApplicationServices()->workingDatabase();
     AcDbRasterImageDef* pImageDef = new AcDbRasterImageDef();
     Acad::ErrorStatus es = pImageDef->setSourceFileName(fileName);
     if(es != Acad::eOk)
          delete pImageDef;
          return;
     es = pImageDef->load();
     ASSERT(es == Acad::eOk);
     AcDbObjectId dictID = AcDbRasterImageDef::imageDictionary(pDb);
     if (dictID==AcDbObjectId::kNull)
         es = AcDbRasterImageDef::createImageDictionary(pDb, dictID);
         if(es!= Acad::eOk)
              delete pImageDef;
              ads_printf(_T(“nCould not create dictionaryn”));
              return;
     AcDbDictionary* pDict = NULL;
     es = acdbOpenObject((AcDbObject*&)pDict,
                                            dictID, AcDb::kForWrite);
     if(es != Acad::eOk)
          delete pImageDef;
          ads_printf(_T(“nCould not open dictionaryn”));
          return;
     BOOL bExist = pDict->has(szName);
     AcDbObjectId objID;
     if (!bExist)
          pDict->setAt(szName, pImageDef, objID);
     else
          pDict->getAt(szName,
                    (AcDbObject*&)pImageDef,AcDb::kForWrite);
          objID = pImageDef->objectId();
     // close Dictionary and Definition.
     pDict->close();
     pImageDef->close();
     AcDbRasterImage* pImage = new AcDbRasterImage;
     es = pImage->setImageDefId(objID);
     if (es != Acad::eOk)
          delete pImage;
          return;
    AcDbObjectId modelId;
    modelId = acdbSymUtil()->blockModelSpaceId(pDb);
    AcDbBlockTableRecord *pBTRecord;
    acdbOpenAcDbObject((AcDbObject*&)pBTRecord,
                                    modelId, AcDb::kForWrite);
     es = pBTRecord->appendAcDbEntity(pImage);
     pBTRecord->close();
     AcDbObjectId entID = pImage->objectId();
     AcGePoint3d TempPoint3d(3.0, 0, 0);
     AcGeVector3d LowerRightVector = TempPoint3d.asVector();
     AcGePoint3d TempPoint3d2(0, 1.5, 0);
     AcGeVector3d OnPlaneVector = TempPoint3d2.asVector();
     if (pImage->setOrientation(org,
                LowerRightVector, OnPlaneVector) !=Adesk::kTrue)
          ads_printf(_T(“nSet Orientation failed.”));
          pImage->close();
          return;
     pImage->setDisplayOpt(AcDbRasterImage::kShow, Adesk::kTrue);
     pImage->setDisplayOpt(AcDbRasterImage::kTransparent,
                                                    Adesk::kTrue);
    AcDbObjectPointer<AcDbRasterImageDefReactor>
                                            rasterImageDefReactor;
    // new it
    rasterImageDefReactor.create();
    // Set the entity to be its owner.
    es = rasterImageDefReactor->setOwnerId(pImage->objectId());
    // if ok
    if (es == Acad::eOk)
        AcDbObjectId defReactorId;
        // assign the object an objectId
        es = pDb->addAcDbObject(defReactorId,
                            rasterImageDefReactor.object());
        // if ok
            // set the image reactor id
            pImage->setReactorId(defReactorId);
            AcDbObjectPointer<AcDbRasterImageDef>
                rasterImagedef(pImage->imageDefId(),
                                            AcDb::kForWrite);
            // if ok
            if (rasterImagedef.openStatus() == Acad::eOk)
                rasterImagedef->addPersistentReactor(defReactorId);
     pImage->close();
via AutoCAD DevBlog-Virupaksha Aithal-August 07, 2012 at 08:29PM-http://adndevblog.typepad.com/au ... sing-objectarx.html
Class AcDbRasterImageDef is implemented in an ObjectARX application called acISMui.arx. Your application must link to the ObjectARX API library acISMobj18.lib to use any of the methods specific to this class.
Note that the AcDbObject methods on this class can be accessed without linking to acISMobj18.lib. Simply cast the object pointer (for example, as returned by acdbOpenObject) to class AcDbObject.
The library file is located at acISMobj18.lib
游客,如果您要查看本帖隐藏内容请回复
本帖被以下淘专辑推荐:
发表于 2016-2-24 14:03:32 | 显示全部楼层
xie xie lou zhu
发表于 2016-3-14 16:09:12 | 显示全部楼层
get ! thank you!
发表于 2016-3-15 15:20:01 | 显示全部楼层
xie xie lou zhu
发表于 2016-4-19 14:42:57 | 显示全部楼层
是中文版就好看多了。
发表于 2016-4-22 20:18:25 | 显示全部楼层
还有隐藏的,看看
发表于 2016-4-22 21:35:32 | 显示全部楼层
谢谢楼主分享
发表于 2016-4-30 20:41:19 | 显示全部楼层
支持 支持 支持 支持
发表于 2016-5-17 08:32:42 | 显示全部楼层
看看!学习学习!
发表于 2016-5-17 09:24:16 | 显示全部楼层
好贴,赞 一个!
发表于 2016-5-17 19:20:13 | 显示全部楼层
good good
发表于 2016-5-19 23:10:32 来自手机 | 显示全部楼层
学习学习学习学习
发表于 2016-6-27 09:45:21 | 显示全部楼层
这个我非常想学习
发表于 2016-6-30 10:59:34 | 显示全部楼层
学习!!!!!!!!!!!!!!!!!!!!!!
发表于 2016-9-29 22:10:54 | 显示全部楼层
回复可见,
查看精彩内容
GMT+8, 2026-11-22 07:41 , Processed in 0.448797 second(s), 37 queries , Gzip On, File On.
