查看: 3953|回复: 4
[求助] 怎么就不对呢???如何真正关闭对话框!!!!!!!!!
发表于 2016-3-20 11:05:35 | 显示全部楼层 |阅读模式
(defun c:PDPBZ_Form1_TextButton10_OnClicked (/ tem f c)  ; 非模态对话框 的返回返回
(dcl_Form_Close pdpbz_form1 1)
(dcl_Project_Unload "pdpbz" T)     ; 非模态对话框
(setq doContinue T)
(while doContinue
  (setq doContinue nil)
  (setq intResult (dcl_FORM_SHOW PDPBZ1_Form1))
  (cond
     ((= intResult 1) (setq doContinue nil))
     ((= intResult 2) (setq doContinue nil))
     ((= intResult 3) (PDS_QY_DCL))
     ((= intResult 4)
         ;(dcl_Project_Unload "pdpbz")
         (setq c 1)
         ;(PDP-HZdcl)        PDP-HZdcl中有CAD的(command ....  在这里也试了
   ); cond
(dcl_Project_Unload "pdpbz1" T)
(if (= intResult 4)(PDP-HZdcl))
(defun c:PDPBZ1_Form1_GraphicButton3_OnClicked (/ )  ; 准备执行PDP-HZdcl
(dcl_Form_Close pdpbz1_form1 4)
)执行PDP-HZdcl子程序出错了,不能执行(command ....
怎么彻底地关闭这两个对话框????????????????????????????????
发表于 2016-3-20 15:45:01 | 显示全部楼层
ONCLOSE事件处理函数里面关闭对话框
 楼主| 发表于 2016-3-20 19:20:55 | 显示全部楼层
(defun c:PDPBZ_Form1_OnClose (i1 i2 /)
;(dcl_Form_Close pdpbz_form1 1)
没得要领,请指教...
把Studio里面 OnClose OnCancel 事件都给勾上。你按ESC键就应该退出对话框的  详情 回复 发表于 2016-3-20 21:44
发表于 2016-3-20 21:44:12 | 显示全部楼层
挚友01 发表于 2016-3-20 19:20
(defun cDPBZ_Form1_OnClose (i1 i2 /)
(dcl_Project_Unload "pdpbz" ...
 楼主| 发表于 2016-3-20 22:25:21 | 显示全部楼层
全都勾上试过了,不行,是想要正常退,从一个非模态对话框返回到主模态对话框...
GMT+8, 2026-11-3 11:14 , Processed in 0.462454 second(s), 40 queries , Gzip On.
