查看: 3775|回复: 14
[求助] 用ads改文字内容失败?
已领礼包: 5060个
发表于 2016-4-25 10:17:25 | 显示全部楼层 |阅读模式
  1. BOOL chgEntDxf1(ads_name ent, wchar_t * str)
  2. {
  3.   struct resbuf *rbTargEnt;   // resbuf to hold ent data
  4.   struct resbuf *rbTrav;      // resbuf to traverse linked list
  5.   struct resbuf *tmp;
  6.   int rc;                     // Return code
  7.   wchar_t *sp2;
  8.
  9.   rbTargEnt = acdbEntGet(ent);
  10.   if(!rbTargEnt)
  11.   {
  12.     acutPrintf(_T("\nacdbEntGet失败. "));
  13.     return FALSE;
  14.   }
  15.   rbTrav = rbTargEnt;
  16.   while(rbTrav)
  17.   {
  18.     switch(rbTrav->restype)
  19.     {
  20.     case 1 : // 更改文字内容
  21.       //_tcscpy( rbTrav->resval.rstring,str);
  22.       tmp = acutBuildList(RTSTR, str, 0);
  23.       sp2 = rbTrav->resval.rstring;
  24.       rbTrav->resval.rstring = tmp->resval.rstring;
  25.       tmp->resval.rstring = sp2;
  26.       acutRelRb(tmp);
  27.       break;
  28.     }
  29.     rbTrav = rbTrav->rbnext;
  30.   }//while
  31.   rc = acdbEntMod(rbTargEnt);
  32.   if(rc != RTNORM)
  33.   {
  34.     acutPrintf(_T("\n更改dxf组码1失败,可能是对象图层锁定"));
  35.   }
  36.   //清理resbuf
  37.   if(rbTargEnt)
  38.   {
  39.     acutRelRb(rbTargEnt);
  40.   }
  41.   return TRUE;
  42. }
复制代码
先是直接_tcscpy( rbTrav->resval.rstring,str);   改lisp值,errno系统变量为2 Invalid entity or selection set name
有人说直接改dxf1组码的值会很危险,必须新建resbuf*,但errno系统变量仍然为2 Invalid entity or selection set name。
已领礼包: 145个
发表于 2016-4-25 11:15:43 | 显示全部楼层
怎么还用ADS呢? 都面向对象这么多年了,用ARX改文字实体内容几行代码就行
AcDbText::setTextString Function
Acad::ErrorStatus
setTextString(
const ACHAR* unnamed);
unnamedInput null-terminated text string (256 byte max)
This function makes a copy of newText and uses the copy as the text string to display. The string must be a standard null-terminated string and cannot be more than 256 bytes long (not including the null terminator).
Unicode, multicode, and the AutoCAD special characters (%%d, %%p, etc.) are supported in the same fashion as they are when entering a text string at the AutoCAD command line for the text or dtext commands.
The text string is used for DXF group code 1.
Returns Acad::eOk if successful or Acad::eInvalidInput if the data passed in is not acceptable.
当然是有理由才用,开始的时候是用AcDbText,后来又加上判断AcDbMText,现在发现修改天正文字没有接口,不止是天正单行文字,连天正多行文字、标注标高、索引图名、箭头引注等都是可以改dxf1组码来修改。而天正2004  详情 回复 发表于 2016-4-25 14:37
已领礼包: 5060个
 楼主| 发表于 2016-4-25 14:37:54 | 显示全部楼层
AcDbText::setTextString Fun ...
当然是有理由才用,开始的时候是用AcDbText,后来又加上判断AcDbMText,现在发现修改天正文字没有接口,不止是天正单行文字,连天正多行文字、标注标高、索引图名、箭头引注等都是可以改dxf1组码来修改。而天正2004和T20数据结果完全不同,用面向对象的方法根本行不通或者很难做。
你用LISP entmod函数可以修改天正实体?  详情 回复 发表于 2016-4-25 14:56
这种还是不要猜了,自定义时就没想让你再改,下个版本可能就变了,开发时远离自定义实体操作  详情 回复 发表于 2016-4-25 14:44
已领礼包: 859个
发表于 2016-4-25 14:44:23 来自手机 | 显示全部楼层
xinxirong 发表于 2016-4-25 14:37
当然是有理由才用,开始的时候是用AcDbText,后来又加上判断AcDbMText,现在发现修改天正文字没有接口, ...
发表于 2016-4-25 14:56:18 | 显示全部楼层
已领礼包: 5060个
 楼主| 发表于 2016-4-25 15:02:08 | 显示全部楼层
已领礼包: 5060个
 楼主| 发表于 2016-4-25 15:32:20 | 显示全部楼层
试了一下在32位的cad中可以,在x64下2010和2013确实崩溃了。但一般平时都是用2004-2008画图比较多,大不了在x64下就用回面向对象编辑。
这种单行文字都做自定义实体够恶心的。他不给你提供接口编辑你就不编辑它好了。  详情 回复 发表于 2016-4-25 15:43
发表于 2016-4-25 15:43:01 | 显示全部楼层
xinxirong 发表于 2016-4-25 15:32
试了一下在32位的cad中可以,在x64下2010和2013确实崩溃了。但一般平时都是用2004-2008画图比较多,大不了 ...
已领礼包: 5060个
 楼主| 发表于 2016-4-25 15:51:37 | 显示全部楼层
现在的问题是我连普通的单行文字都修改不了,acdbEntMod返回-5003
普通的单行文字,为什么还用ADS写,不用AcDbText下面的方法?  详情 回复 发表于 2016-4-25 15:58
发表于 2016-4-25 15:58:08 | 显示全部楼层
当然是有原因的,ads比较通用嘛,比如文字、多行文字、标注、等都可以修改组码1来修改内容。  详情 回复 发表于 2016-9-9 08:34
已领礼包: 5060个
 楼主| 发表于 2016-4-25 16:54:38 | 显示全部楼层
这不是说了吗,32位的cad还是可以修改天正文字,64位的把它屏蔽掉就好了。
已领礼包: 5060个
 楼主| 发表于 2016-4-26 11:00:27 | 显示全部楼层
原来是太久没关机了,重启一下连64位的都可以修改天正文字了。
还能这样  详情 回复 发表于 2016-4-26 11:06
发表于 2016-4-26 11:06:01 | 显示全部楼层
还能这样:P
已领礼包: 5060个
 楼主| 发表于 2016-4-26 13:03:49 | 显示全部楼层
        //Lock当前文档
        AcApDocument *pDoc=acDocManager->curDocument();
        acDocManager->lockDocument(pDoc,AcAp::kWrite);
        //UnLock当前文档
        acDocManager->unlockDocument(pDoc);
已领礼包: 5060个
 楼主| 发表于 2016-9-9 08:34:49 | 显示全部楼层
GMT+8, 2026-11-3 04:03 , Processed in 0.720505 second(s), 60 queries , Gzip On.
