查看: 2042|回复: 3
[研讨] 建立标注样式,05版通过,2016版出错了。
发表于 2016-6-16 12:02:16 | 显示全部楼层 |阅读模式
建立标注样式2.5B1,05版通过,2016版出错了
  (defun DStyleSub (StyleNum colorNum / StyleStr)
    (setvar "dimlfac" (/ 1.0 StyleNum))
    (setvar "DIMCLRD" colorNum)
    (setq StyleStr (strcat (rtos StyleNum 2 2) "B1"))
    (if        (not (tblsearch "dimstyle" StyleStr))
      (command "_.dimstyle" "s" StyleStr)
      (command "_.dimstyle" "s" StyleStr "y")
发表于 2016-6-16 12:16:25 | 显示全部楼层
没装2016, 出错有什么提示?是不是要你用command_s ?
 楼主| 发表于 2016-6-16 12:46:11 | 显示全部楼层
VVC: Internal Error
command_s也不行。
 楼主| 发表于 2016-6-16 16:44:44 | 显示全部楼层
改为如下形式,为什么影响基准样式呢?百思不得姐
(defun DStyleSub (StyleNum colorNum / NDIM STYLESTR)
    (setq StyleStr (strcat (VL-PRINC-TO-STRING StyleNum) "B1"))
    (if        (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list DimS StyleStr)))
      (setq NDim (vla-add DimS StyleStr))
      (progn
        (vla-delete (vla-item DimS StyleStr))
    (vla-copyfrom (vla-item DimS OName) NDim)
    (vla-copyfrom NDim *DOC*)
    (vla-put-activedimstyle *DOC* NDim)
(or *ACAD* (setq *ACAD* (vlax-get-acad-object)))
  (or *DOC* (setq *DOC* (vla-get-ActiveDocument *ACAD*)))
  (setq OName (getvar "dimstyle"))
  (setq DimS (vla-get-DimStyles *DOC*))
(DStyleSub 5 5)
GMT+8, 2026-11-5 23:32 , Processed in 0.507809 second(s), 35 queries , Gzip On.
